druxey
Everything posted by druxey
  1. The reverse curve is an optical illusion. As seen from the side, the curve continues up to the bow. However, if you plot this curve in three dimensions (the bow is curving away fro the viewer in plan view), the curve flattens out. The rounder the bow, the more apparent is this effect.
  2. SilkSpan worked well for me. You might want to get the supplement to Volume IV, The Fully Framed Model from SeaWatchBooks. It describes a method of working with this material.
  3. No, that is a pirated version - and not a very good one - lifted from the book that you see advertised, I'm afraid.
  4. That looks right to my eye now, Mark. It's a critical point that many modelers miss. Later it comes back to bite as the headwork won't articulate properly with the bow of the model. I'm glad you posted those photos in time to catch it!
  5. This continues to be a beautiful piece of craftsmanship, Amalio!
  6. Your assumption that the smooth upward curve on the sheer drawing (in one plane) is the same projected on the 3D shape of the bow is misleading. That is the trap!
  7. I still enjoy my DB200 Unimat, circa 1970. It is a very versatile power tool. Thoroughly recommended, and other accessories are available on eBay.
  8. Beware of the line rising too far at the bow. Check the height from the baseboard to the wale edge at the bow rabbet. Usually the curve of the wale flattens or even appears to reverse at the bow. If the wale ends up too high on the bow, it will throw off all the headwork. You won't want that!
  9. It doesn't look too heavy visually to me, Mike.
  10. I would not want to speculate at a distance from a single photograph. As this is apparently a 'decorative model', I would simply leave things as they are with the lightest of cleaning.
  11. Very nicely done. If the fish bother you, try bending a couple of them and coat them all with a gloss finish; that will help a lot.
  12. Some colors are more transparent than others and need more coats to cover adequately.
  13. Thank you for filling in the details of your modelling-against-the-clock marathon! That deck looks very nice to my eye.
  14. I used to use UHU many, many years ago. If it's still the same, it is a solvent-based glue. This makes clean-up or de-bonding an issue. If you are working with wood, use white (polyvinyl) or yellow (aliphatic) glue. Use water to clean up, and there are less health issues!
  15. I'd be inclined to show the correct house flag and ensign rather than the presumed replacements. Otherwise you'll continue to confuse future folk looking at the model!
  16. Coming along very nicely, despite what Kurt said. Those slight steps in the floors will disappear when you complete the final fairing. It's not an unusual thing to see at this stage.
  17. The running soldering along the line of plates sounds like a tricky operation to coordinate properly. Lovely results, though. Best wishes for the New Year, Gerald.
  18. Not a great idea. Wood will shrink, particularly across the grain as it dries, leaving gaps between the strakes. Bend and let the plank dry out in place, then adjust for final fit before gluing it.
