Everything posted by druxey
It doesn't look too heavy visually to me, Mike.
- 968 replies
- hahn
- oliver cromwell
Very nicely done. If the fish bother you, try bending a couple of them and coat them all with a gloss finish; that will help a lot.
- 17 replies
- beykoz caique
- fishing
Thank you for filling in the details of your modelling-against-the-clock marathon! That deck looks very nice to my eye.
- 346 replies
- terror
- polar exploration
I used to use UHU many, many years ago. If it's still the same, it is a solvent-based glue. This makes clean-up or de-bonding an issue. If you are working with wood, use white (polyvinyl) or yellow (aliphatic) glue. Use water to clean up, and there are less health issues!
I'd be inclined to show the correct house flag and ensign rather than the presumed replacements. Otherwise you'll continue to confuse future folk looking at the model!
- 749 replies
- albertic
- ocean liner
The running soldering along the line of plates sounds like a tricky operation to coordinate properly. Lovely results, though. Best wishes for the New Year, Gerald.
- 281 replies
- falls of clyde
- tanker
Gluing Planks When Wet
druxey replied to mikiek's topic in Building, Framing, Planking and plating a ships hull and deck
Not a great idea. Wood will shrink, particularly across the grain as it dries, leaving gaps between the strakes. Bend and let the plank dry out in place, then adjust for final fit before gluing it. -
Consider replacing the flag using SilkSpan, Michael. Pre-stretch it on a frame rather like watercolor paper. (I know you know all about that!) I use acrylic paints on SilkSpan.
- 749 replies
- albertic
- ocean liner
Pandora by marsalv - FINISHED - 1:52
druxey replied to marsalv's topic in - Build logs for subjects built 1751 - 1800
Very nice blocks, strops and spans! -
And to you also, Ed! Thank you for your contributions to our knowledge this year.
- 3,618 replies
- young america
- clipper
Looks like you need to find the piece and glue it back, if you can. Otherwise, yes, a replacement. You need a solid 'landing' for the planks later. Be extremely light on those cross-grain areas!
- 90 replies
- english pinnace
- Finished
ancre Chebece 1750 by Jeronimo - FINISHED
druxey replied to Jeronimo's topic in - Build logs for subjects built 1501 - 1750
Beautifully made and finished, Karl. -
The ornamental serving - called puddening - was an anti-chafing measure to prevent iron rubbing directly against the anchor cable.
- 525 replies
- anchor hoy
- hoy
