Everything posted by druxey
Aie! That is some complex mini-machining. Good to see you back at work on Wespe, Wefalck.
Please take care of yourself first, Michael!
- 749 replies
- albertic
- ocean liner
That's impressive freehand work on the lifelines. I'd have used a curved template as a steady!
- 749 replies
- albertic
- ocean liner
'Scooch' is a new term to me, Toni! Very nice work on the turning stairs and handrails. Is it the angle of the photo or is the posterior aspect of the rudderhead cover skewed?
- 1,449 replies
And the season's greetings to you as well, Dick. I look forward to seeing how you solve the half deck issue.
I suppose you will need to balance 'conservation' with 'restoration' on those lines. I'd be inclined to replace the obvious bad repairs and line that are not original to the model. You will still have the photographic record of them anyway. Does your client have an opinion on this?
- 749 replies
- albertic
- ocean liner
Neatly done. Are you happy with the color match now?
- 749 replies
- albertic
- ocean liner
Looking forward to seeing the completed case, Mike! Happy holidays.
- 968 replies
- hahn
- oliver cromwell
Keith: you have a good point there! Although the draw-back is that a good single malt is very expensive in Canada. Michael: If the line is stiff I find a little water on it where it reeves through the block softens it temporarily to mold and 'sit down' nicely where it enters and emerges. And water is a good deal cheaper than a 25 year old Macallan.... Jim: I'd use microcrystalline wax rather than beeswax. The latter is acidic, the former pH neutral.
- 749 replies
- albertic
- ocean liner
It's called a top, not a thimble, Michael. Can you modify the shade of the line with dilute watercolor? Tea will eventually rot fiber.
- 749 replies
- albertic
- ocean liner
Yes, humidity change will do that. Keep the place humidified once you get heat back and the wood should expand again. Slightly higher humidity in winter will be better for your respiratory health as well!
