druxey
Everything posted by druxey
  1. No dumb question: is the glue water and heatproof? If not....
  2. Acrylic resin? Stable wood is a nice thought, but how much vacuum might be needed?
  3. Keith: you have a good point there! Although the draw-back is that a good single malt is very expensive in Canada. Michael: If the line is stiff I find a little water on it where it reeves through the block softens it temporarily to mold and 'sit down' nicely where it enters and emerges. And water is a good deal cheaper than a 25 year old Macallan.... Jim: I'd use microcrystalline wax rather than beeswax. The latter is acidic, the former pH neutral.
  4. It's called a top, not a thimble, Michael. Can you modify the shade of the line with dilute watercolor? Tea will eventually rot fiber.
  5. Planks usually thin to the width of the stem rabbet. Sure will help!
  6. Yes, humidity change will do that. Keep the place humidified once you get heat back and the wood should expand again. Slightly higher humidity in winter will be better for your respiratory health as well!
  7. All you need is a ply sheet with the correct shape cut out and mounted at the correct height on a building board. The model sits vertically inside the cut-out.
  8. Copper is described as 'ductile' and will stretch a good way before reaching (and exceeding!) its elastic limit.
  9. Ah! I see you were able to move Albertic safely to your new home. Looking forward to your progress reports, Michael.
  10. Welcome back, Gary! It's nice to see your beautiful model beginning to progress again. Nice workbench too!
  11. Ideally internal stringers would solve the issue (while still retaining the cross-spalls) However, in your case perhaps an external jig will be required to maintain hull form until you can install stringers and permanent cross-members.
  12. Time spent fine-tuning tools is well spent!
  13. Check the factory primary bevel. Keep it as recommended by Mike Y and add a secondary edge bevel.
  14. Lovely work and photography as well!
  15. Congratulations on completing a lovely gem of a model, Rusty.
  16. Mark: for various odd-shaped spaces, I've seen wedge-shaped ledges rather like the ones in my illustration.
  17. There is no 'correct' or 'wrong': it has to be something that you are satisfied with.
  18. I concur with Mark: this was probably experimental. Obviously it was not successful as it was not generally adopted!
