Everything posted by druxey
There are some differences between the photographed prototype and the production model. As noted, the end result is the same.
- 37 replies
- Model Shipways
- muscongus bay lobster smack
It is more than likely that Wolf was steered by tiller alone. No reflection on your work at all, but on the kit design! Some of these smaller sixth rates were retrofitted with wheels in the position mentioned.
Ship’s Bell
druxey replied to acaron41120's topic in Discussion for a Ship's Deck Furniture, Guns, boats and other Fittings
What country, era, type of ship? -
Very neatly done, Clare! The tiller/wheel set-up is unlike any I've seen - usually if a wheel is present, it is on the quarterdeck where the funnel-like structure is sitting.
Research in the HMS Ulysses 1797, a Roebuck class ship
druxey replied to Kevin Kenny's topic in Nautical/Naval History
Did you not recieve my two pm's, Kevin? -
At miniature scales 'cheats' to fool the eye are necessary. Perhaps at least try some of the suggested methods that the experts use to see if you can get a result that pleases you.
Brass wire: it bends, it breaks!
druxey replied to Mollusc's topic in Metal Work, Soldering and Metal Fittings
The brulée torch is perfect for modelmaking as well. Heat the metal in dim light to cherry red and then let it air-cool to room temperature. Take care not to burn yourself - or anything else, for that matter. -
First, you've done a very neat and workmanlike job of your first wooden model build. Well done! Clamping parts on a model where nothing is square is always a challenge in this hobby. Your solution worked well - not one I've seen before. As you work your way through more models, problem solving is half the challenge and fun!
- 5 replies
- Lowell Grand Banks Dory
- Model Shipways
Too thin for wood poles: those appear to be lines (ropes).
- 40 replies
- Speeljacht
- Card
(and 3 more)
Nice! It's amazing with accurate mark-out and the correct hand tool what one can accomplish.
- 969 replies
- hahn
- oliver cromwell
Jaguar XK-E by CDW - Gunze Sangyo High Tech Model - 1:24 Scale
druxey replied to CDW's topic in Non-ship/categorised builds
Is that a pair, but one mounted the wrong way around? -
Don't be too hard on yourself, Mike. These parts look deceptively easy, but they are not - as you've discovered.
- 969 replies
- hahn
- oliver cromwell
