Everything posted by druxey
Well, that's an interesting change of pace! Thanks for the update.
- 144 replies
- Harriet Lane
- Model Shipways
Exemplary miniature work as usual, Daniel! Looks like it was a great exhibition and meeting as well.
Both those weathered looks seem fine on camera, even if the first was unintended!
- 40 replies
- Nautilus
- Heinkel Models
Every model is a learning process and it looks as if you are doing well.
- 69 replies
- Lowell Grand Banks Dory
- Model Shipways
British Pathe film: Model Boat Building, 1956.
druxey replied to uss frolick's topic in Nautical/Naval History
Don't laugh at these batchelors: many if these rather eccentric but highly skilled men men were PTSD sufferers from WWII. This was their self-prescribed therapy. -
L'Amarante by marsalv - 1:36 - POF
druxey replied to marsalv's topic in - Build logs for subjects built 1501 - 1750
Are those wooden plugs in the hawse holes? -
It was articles on builders like him in The Model Engineer that inspired me as a kid. -
Welcome back and enjoy your new home, Ben!
- 399 replies
- winchelsea
- Syren Ship Model Company
Scraping moldings: some tricks I found helped me: 1) Glue the blank strip down on a solid backing piece. I use PVA white glue. This may be soaked off in 95% isopropanol (rubbing alcohol) when complete. 2) Make the strip no deeper than the deepest dimension of the finished molding. 3) Scrape lightly and gently. If you apply pressure, the scraper will wander with the wood grain. As the molding develops, you can add a bit more pressure. 4) When the blank edge of the scraper runs against the backing board, you are at the correct depth and the scraper will not bite in deeper.
For scuppers: My method (waterway in place) is, first accurate mark-out both inboard and out. Drill with a very small diameter bit from both sides. Hopefully the holes will meet - at least partially. Then progressively enlarge using larger diameter bits and needle files, making minor corrections as you go until you reach the diameter of the scupper. I've not drilled hawseholes in years. I file the half-holes in the hawse pieced before assembly. Again, I make them slightly under final size, then file them out once planking is complete.
New member and brand new (Paper) modeller!
druxey replied to Marcel1981's topic in New member Introductions
Welcome aboard, Marcel!
