druxey
Everything posted by druxey
  1. Naturally aging brass seems like a good idea, Michael. Nice to read that you are getting back your groove.
  2. Lovely! You are making good progress, Albert.
  3. Greg: Longitude was written by Dava Sobel. Her book is a great read, highly recommended!
  4. I see your dead flat is composed of thee singles: an odd number is always required to reverse the frame pair floors fore and aft.
  5. It was wonderful to see both models in actuality at the Conference: thank you for bring them for inspection, Ed!
  6. Ah! I wondered when we'd hear more from you, Michael. She's looking good.
  7. No, file it when cooled! You don't want to scorch yourself accidentally. Heat to cherry red and let air cool. This softens the metal. After filing you could re-harden it by heating and oil quenching, but this really is not necessary.
  8. Only a hardwood like boxwood will hold the detail of a miniature moulding. Basswood is too soft and fuzzy. I use a piece of heat-softened hacksaw blade for filing in my moulding profiles.
  9. Beautiful mouse for your stay!
  10. I'd like to add my applause to Mitch, Kurt, Mary, Toni, Phil, Chuck and everyone else involved behind the scenes for an outstanding Conference!
  11. With all due respect, Rob, the beautifully drawn isometric drawings of bow and stern you posted appear to be of another vessel.
  12. Some excellent advice there from Mark and Richard.
  13. Thank you, translators! Viele danken!
  14. That metalwork was really labour-intensive! Lovely result, even if the pawl rim detail is mostly hidden. Your (b)log is very nicely presented as well, E&T. Good stuff!
  15. Going into the era of composite ships, there was often a mix of old and (then) new technology. For instance, Cutty Sark has iron frames, wooden hull and riveted iron bulwarks. So is it not possible, at the time of the photographs in question, that iron bulwarks had replaced original wooden ones?
  16. The brass I use has to be more than 60 years old and was my father's stock. Perhaps the percentage composition of it has changed since then.
  17. They are only 'mandatory' if you actually need them! For instance, if you build kits with laser or CNC cut parts, you won't need a scroll saw. Get a scroll saw only if you have a lot of curved parts you need cut out yourself.
  18. Jaager: the use of pH-neutral PVA and natural fibre is the best possible solution. Good suggestion!
  19. Congrats on installing the shutter plank: time to wet your whistle!
  20. This topic comes up time and time again. Apart from cleaning the brass well, the blackening agent need to be diluted with water about 8:1. It works more slowly, but the black will not come off as you are experiencing.
  21. Your experience with brass chips makes me wonder if the type of brass you are using is 'free-machining brass' or another type? I've found that, at the right feed rate and speed, the brass comes off in long curls. Those embryo guns look very nice.
