Everything posted by druxey
The extra 'frames', parallel to the keel, are called hawse timbers. If you look at other framed models on this site, you will see how that works. Of course, Hahn has stylized real world framing. Usually there are four or five hawse timbers per side.
- 969 replies
- hahn
- oliver cromwell
Great start(s) to your project, Glenn! There were a lot of board feet of wood in those vessels.
Clever technique with copper plates and tape! Looking lovely.
- 106 replies
- Japanese boat
- Wasen
Sawdust Dave: All I was trying to say was consider the idea: I wasn't pushing that you go in that direction. I certainly didn't mean to criticize your work! If you took me wrong, I apologize. Please don't immolate anyone!
- 1,051 replies
- cheerful
- Syren Ship Model Company
So, consider a little change in direction, Sawdust Dave. Do you want to leave five sub-standard models or one really good one? I know which way I jump!
- 1,051 replies
- cheerful
ancre Le Francois by cabrapente
druxey replied to cabrapente's topic in - Build logs for subjects built 1501 - 1750
If that dark wood is ebony, be very careful of your lungs! I would never use it myself. Try holly or pear that is dyed black. Either bends and glues much more easily and is less toxic. -
I think Chuck has it absolutely right: you cannot rush and be sloppy if you want a great result.
- 1,051 replies
- cheerful
ancre La Belle 1684 by Nenseth - 1:36 scale
druxey replied to Nenseth's topic in - Build logs for subjects built 1501 - 1750
Nice work so far, Hans Christian. Use a water-based glue and wash off any excess before it sets. Then there won't be any glue stains. If it's any help, I built my first big framed model (over a metre long) on my dining room table! -
Sitzbank aus Eisen (Bench made of iron)
druxey replied to merchen's topic in Metal Work, Soldering and Metal Fittings
Bitten sie: in Englisch schreiben! (Please write in English.) A beautiful result! -
Flush rivet heads? In any case, hardly visible at scale size, in my opinion.
- 2,625 replies
- kaiser wilhelm der grosse
- passenger steamer
Unfortunately, 'bad ideas' are still around and always will be. Sure, CA is a great idea for those in a rush and want a quick fix, but they are generally not interested in the longevity of their work. If you are spending months or years on a model anyway, spend just a little more time and the model will, hopefully, last for a century or more without needing extensive repair work.
planking question
druxey replied to lionfish's topic in Building, Framing, Planking and plating a ships hull and deck
Have you read the 'pinned' Primer on Planking here? Usually narrow tick strips are used to measure girth at various points along the hull (in your case along the bulkhead edges). Be aware that after mathematically dividing the hull surface into bands, you will still need to finesse the resulting curves until everything looks smooth from all angles. Then you can sub-divide each band into the individual strakes. -
Frégate d'18 par Sané , la Cornélie
druxey replied to JohnE's topic in CAD and 3D Modelling/Drafting Plans with Software
Oh, excellent! Much more filling than an amuse-bouche! Bon appetite, monsieur. -
Certainly there are a number of tricks to learn when centering anything in an independent 4-jaw chuck!
- 1,449 replies
Clever work on mounting and stabilizing the boats, Dan.
- 108 replies
- andrea doria
- ocean liner
Surely you are not going to put the model in the garbage, Gaetan! If so, let me know which night it will be put out....
- 728 replies
- le fleuron
- 64 gun
The Georgian first rate model's deck looks distinctly 20th century in style with its tree nailing and lack of signs of age. As Mark mentioned, usually that style of model had scored sheet decking. Also, decks below the weather deck on other Georgian 'takeapart' models I've seen are often unplanked. I'm skeptical of that one! However, the 1770's cutter deck certainly looks authentic and the nibbed planking cannot be discounted. The question with the latter model is whether the planking is also tapered - it's hard to tell from Chuck's photo.
Your funnel grille is very convincing, Dan, but wouldn't photo etching have been an easier route to have taken here?
- 108 replies
- andrea doria
- ocean liner
Nice to see the deck planking done as it actually was in those days! No excuses any more, folks....
- 1,051 replies
- cheerful
Best of wishes for tomorrow, Jonny. And, as far as puppies and training them go, I've been there, done that! Not much to see in the way of models at the NMM now (now renamed Royal Museums Greenwich), but the view from Maze Hill and the Observatory is still well worth the visit. The pub on Park Vista east of the Museum, The Plume of Feathers, is a good spot too!
Animated figures aboard really make a difference! Good stuff, Magnus.
ancre Le Fleuron 1729 by rekon54 - 1:24
druxey replied to rekon54's topic in - Build logs for subjects built 1501 - 1750
Superb metalwork, Giorgio!
