Everything posted by druxey
Today I made a Light (box) Stand
druxey replied to AON's topic in Modeling tools and Workshop Equipment
Nicely done. I feel my own method much inferior now; I simply hold the pieces up to the window (daytime) or task light (night)! -
Nice looking bulkhead, Toni, although I was puzzled that you applied a comedian to both sides of the basswood. Perhaps you meant to type 'Castello'?
- 1,449 replies
I would think that deadlights that swing up would be more likely. The more elaborate hidden sliding versions would be for Admiral's quarters on a first rate!
endeavour shrouds & ratlines (moved by admin)
druxey replied to geoff's topic in Masting, rigging and sails
Interesting question. Steel (1794) states that the ratlines only go across every 6th lower shroud. However, contemporary models show all the ratlines going all the way across. -
Tom's idea is a good one, but I'd try this out on a sample of fabric before you make a whole suit of sails, just in case it doesn't work!
Fastening of the false keel
druxey replied to dafi's topic in Building, Framing, Planking and plating a ships hull and deck
While I'm sure that staple spacing was calculated using some proportional formula, Alex, the photos I was looking at showed much closer spacing than you suggest. -
The photos seem to indicate a spacing of about 12", judged from the length of the staples. -
Good question. I've not come across any specification, but think 18" to 24" would be reasonable. -
Your model is looking very good, Fam. Might I suggest you look at your lining out with the hull right way up? I found that things looked very good while the hull was upside down, but more adjustments were needed once I was looking at it as one would normally see the model. I like the method you are developing for scupper linings. However, as the holes come through at an angle, would the flared ends be more oval in shape than round?
Lovely! But would she have had royal yards?
Scratchbuilt Hull Decision
druxey replied to CDR_Ret's topic in Building, Framing, Planking and plating a ships hull and deck
Ah: thanks for the clarification, Terry. One composite method of forming the hull would be bulkheads with filler pieces between to form a solid landing for the planks. This would avoid flat spots. (see the Hohenzollern 1660 model thread by Mr. Hollum). -
Well, I suppose fidelity means plank on frame. This is a challenging project that other methods avoid. If you wish to go this route, I strongly recommend you try a cross-sectional model first. This will give you a good idea (and lots of practice!) in building accurate frames. There are several c/s models on offer right now. For instance, there is the Triton c/s on this site, or the Echo c/s from Admiralty Models. I'd consider either of these to get you up to speed before you tackle the complexities of even a 'straightforward' full hull. -
Your best sail cloth and technique
druxey replied to steven sturgis's topic in Masting, rigging and sails
There's more on using SilkSpan for sails in a new booklet by SeaWatchBooks, or as a new chapter in a new edition of Swan IV. -
Landlubber Mike's technique for furled sails
druxey replied to Landlubber Mike's topic in Masting, rigging and sails
There's a booklet on realistic looking sailmaking now available from SeWatchBooks, or as a chapter in the new edition of Swan IV. -
Somehow, I missed your January 3 posting and am a bit bothered about that fifth deadeye and chain. Usually if modifications are made, these are drawn out in detail neatly, using either a different color ink or with dashed lines. This rough pencil addition looks like a proposal that was not, in fact, carried out. Just my opinion.
The plug is not wrong: the upper edge is the top of the removable wash boards, not the top of the sheer strake. Marking the plug out first will take care of this.
The foremost fore and main shrouds would have been served all over. The others would be served along the middle ¼ of the pair's overall length.
Sounds like a rarity, Alan. Perhaps a major collection, such as the British Library, holds a copy? Certainly nothing showed up on abebooks.com
