Everything posted by druxey
Setting up deadeyes to shrouds
druxey replied to Lost and Confused's topic in Masting, rigging and sails
I appreciate your problem - we've all been through this at one time or another! There are a number of ways to deal with this. Ideally there is a small amount of stretch in the shrouds that will allow for micro-adjustment. However, don't overdo it or either the lanyard will give way or the mast will pull out of line. For the main part of the process I will loop the end of the shroud up (once it is in place over the masthead) until the bottom of the loop is at the level you want the deadeye to be. (A bit of water on a brush applied to the shroud at the bend will help it behave.) I then secure the deadeye in this loop with a spot of glue. Take the shroud off again and complete the lashings around the deadeye on the bench rather than in the air. Then re-install the shroud pair and reeve the laniard. Other folk will doubtless provide you with other remedies. One size doesn't fit all - try them until you find one that works for you. -
Looking very good, Toni. It helps to use your chisel bevel down to control depth of cut when eight-squaring the spar.
- 80 replies
- rigging/masts
- NRG
I've used many different methods over the years. I began with black tissue, graduated to Allan's paint/PVA mix, and now use dark brown acrylic paint (burnt umber) along the outer (show) edges of joints on one side before gluing up. I find black a little too visually contrasty, but that's a personal preference. For minor seams such as planking, soft pencil along the show edge does the trick for me. Try different methods until you settle on the one(s) that you like.
Miniature Russian carving tools
druxey replied to druxey's topic in Modeling tools and Workshop Equipment
Patrick: Unfortunately, due to the current international situation, you will be unable to get these. -
Wrinkled paper suggests that you were using a water-based varnish. Paper does not like moisture. For the length of a build, rubber cement is a good alternative 'glue'. Eventually it will turn paper brown and peel, but that usually takes more than ten years! Enjoy the process of buldign up a model like the real thing.
- 92 replies
Sorry to contradict, but regular beeswax is acid! Use Renaissance (conservators') wax, if you have to.
I quote a retired civil engineer (I hope she won't mind) who designed bridges world wide: I saw the newsreel of the bridge collapse in Baltimore yesterday. I had always felt that these American 'girder bridges' were too lightweight (part of America's planned obsolesce design practice in place in those years). But I was astonished to see how little protection was provided to the main supports. It's a no brainer - if you knock out a main support, the bridge collapses! And the main supports next to the navigation channel require special attention. On the Queensferry Bridge, which was downstream of the Forsyth Naval Dockyard where they build and maintain aircraft carriers, we carried out a study, including model simulation, of just such an event and designed the main pier caissons not to fail. Luckily, the Americans loved simple span construction for their approach viaducts and this acted as a fuse . . . [for] progressive collapse of the whole crossing! . . . . what happened using 'the past is a foreign country' adage. It was opened in 1977! I was working on the Itchen Bridge then in a similar, but not as exposed, location upriver from the port of Southampton. Our River piers were protected by a massive caisson that extended out from the main columns by sufficient distance to guard against the superstructure hitting the bridge even as the hull of the vessel crumpled onto the caissons. So, there you have it.
On a smaller vessel, the bowsprit was sometimes constrained by an iron hoop attached to the bulwark. The heel was secured to the bowsprit step with an iron fid.
The bow ports were not armed: no space for working a gun! The were used as bridle ports for anchor handling. The vertical half-port lids illustrated were 'for example' and not drawn for all the other ports. You could not have a conventional lid as there was nothing but the rail above the port opening. There was no place to fit a hinge to! The advantage of these lids was that in a heavy sea you would not ship as much water over the decks as would happen with open ports.
mnl is correct; watercolor is a transparent medium. You can also see the background through the ships' masts and the knee of the head.
There are several suggested routes you might take. Try this first, though: If you used white glue, rubbing alcohol will soften it so that you can disassemble the planks and try again. Wetting the planks , you can re-shape them, then let them dry. The second time you now know what to look for and check on. It's always a learning process, no matter how long you've been building models! 'Sea' what you can do! (groan)
- 9 replies
- Lowell Grand Banks Dory
- Model Shipways
