Everything posted by druxey
You need a tissue that will stand up to wetting without disintegrating. Also, shiny would be distracting, I think.
You figurehead might look like Kermit to you, Omega, but at that scale the overall effect or impression is what matters. In this case, the effect looks very good.
50-gun ship by newbee - 1/72 scale
druxey replied to newbee's topic in - Build logs for subjects built 1751 - 1800
Good things do take time, you know! Looks like you are on your way, Newbee. -
Terrific work, as usual, Ed! Would marking, say, the top timber height of every third or fourth toptimber and running a light batten to get the intermediate ones have been a option? I'm curious as to why you used the height gauge to measure every last one.
- 3,618 replies
- young america
- clipper
Sorry about your early snowfall, Michael. Fire up that wood stove! Great way to use up your scrap wood....
- 2,215 replies
So, one of your ships has finally been found! I guess you'll need to rename yourself EorT, for the moment.
- 346 replies
- terror
- polar exploration
This framing photo shows you how the wing transom is shaped at the outer corners. (This model is of a sixth rate, so is smaller and has less transoms than a 74, but is essentially similar.) Note the smooth run of the filling transoms' surfaces up to the margin line. There is no sharp turn or bend, which appears on your frame grab.
Ah, 'twas ever thus in pursuit of perfection.... Hopefully the re-do will satisfy you. Look forward to seeing your progress.
- 1,449 replies
Oh, dear. Your disease is worse than I thought. I'm so sorry, E&T....
- 346 replies
- terror
- polar exploration
Terrific research, E&T. How did you determine the number and titles of the books Crozier had along? Just kidding.
- 346 replies
- terror
- polar exploration
Cutting Lap joints for Deck Furniture, etc.
druxey replied to Stuntflyer's topic in Modeling tools and Workshop Equipment
Any reasonable brand of chisel will do. Lee Valley Tools have a good selection. The key is sharpening it. Take a look at Lee Valley's sharpening jig (Mark II Honing Guide) and water stones. Until I got these (many years ago now!) I could never cut a good clean joint. Once I learned how to properly sharpen and hone my tools I amazed myself at what I could do with them. They also have a good book on sharpening tools properly. Start out with a ⅜" or ½" bevel edged chisel, then add others as and when you need them. Disclaimer: other than as a long-time customer of LV, I have no other connection with them. -
With practice and a sharp chisel, you should be able to cut consistent joints. Accurate mark-out is also critical. -
Possibly consider using your computer to print this out at very high resolution?
Nice corrective surgery, Ed. The beams and knees will ensure that the hull form stays put later, right?
- 3,618 replies
- young america
- clipper
Thanks for sharing your research and findings, E&T. Excellent sleuthing!
- 346 replies
- terror
- polar exploration
