Everything posted by druxey
There's strength in numbers, Ian! Try them out, say I.
Flying Cloud by eyfeinsod - RESTORATION
druxey replied to eyfeinsod's topic in - Build logs for subjects built 1851 - 1900
I note that you've started two separate logs. Can you please amalgamate them into one for us? Thank you. So, a major job started! Fine chain is best obtained form a jeweler's supply house. In the U.S. Gesswein is a reliable source. Might I strongly recommend Rob Napier's new book on the subject of conservation/restoration of old models? It will address your questions well, I think. Available at: https://seawatchbooks.com/collections/new-arrivals -
Prize Papers lecture from the National Archives, U.K.
druxey replied to druxey's topic in Nautical/Naval History
My link should then send you to: https://www.eventbrite.co.uk/e/the-prize-papers-a-new-frontier-in-global-and-maritime-history-tickets-482335688027?aff=em&utm_source=emailmarketing&utm_medium=email&utm_campaign=wo_presale__8_dec_2022&utm_content=2022-12-11 -
Sounds like an Ottawa Ship Model Society is about to form! Welcome aboard, Eugene.
Bienvenue ici, aurelein! Welcome aboard. You'll find a lot to look at here and advice if you need it.
An easy mistake to make if you haven't been told or seen the process done.
- 257 replies
- pegasus
- Swan-class
Ways to reduce breakage: 1) Use bamboo with its long, parallel fibers. Split it first into smaller cross-sections by halving and re-halving the lengths. 2) Use parallel pliers to draw the pieces through the plate. The fibers aren't crushed which happens with regular pliers. 3) Draw steadily and in a straight line. 4) Only use the hard part of the bamboo just under the glassy outer layer.
- 257 replies
- pegasus
- Swan-class
Apart from the "Honey, I shrunk the ship" shot, superb rendering work, Ron.
- 542 replies
- Sphinx
- Vanguard Models
(and 3 more)
You have achieved an excellent result with your 'wood' trim. Well done, Bob!
- 111 replies
- Nonsuch 30
- Model Shipways
Bienvenue and welcome aboard, Patrick!
The 'alligatored' pebble-grain paint surface looks as if the model was exposed to extreme heat. Is this attic in a hot climate?
Just catching up to you, Steven. Fascinating research and interpretation of those images.
- 508 replies
Thank you for educating us, Dick. I wonder wherher the ladder-like iconography represents internal thwarts or even frames?
- 142 replies
