Posts posted by Amalio
Thank you very much Ed.
Yes, the port side is left unlined as seen in the photo.
Thank you- mtaylor, FriedClams, Obormotov and 1 other
4
Good morning.
I use a lot to remove the tail, these circular brushes from Dremel. When two hours have passed after having glued. There are corners where it does not arrive and you have to take it into account so that it does not overflow in those places.
It is necessary to put the machine at the lowest possible speed so as not to burn the nylon of the brush. -
- PeteB, mtaylor, Jorge Diaz O and 1 other
4
Thank you very much, I will remember you when I use it with my eighth arm.
Jaja.......... thanks.- vossiewulf and mtaylor
2
On 15/3/2019 at 11:42, Gaetan Bordeleau said:
Como se suele decir, esto es calidad.
Ordené uno de este sitio canadiense. Lo probé y efectivamente hace el trabajo de una manera más eficiente, más rápido que una piedra de agua. Se llama piedra de cristal Shapman y el fondo de la piedra está hecho de vidrio. Así que ordené otro para el acabado y estoy seguro de que estaré contento con él. De hecho, la piedra de agua también es efectiva, pero hay un aspecto que no me gustó de esto, especialmente para el grado más bajo. Antes de usar, debes empapar la piedra de agua en el agua durante unos minutos y, literalmente, ves burbujas saliendo de la piedra.
Good morning, Gaetan.
First I want to congratulate you for what is one of the greatest works for me that can be seen here.
Secondly I would like to know if these stones that work with dry samples or with any element such as water or oil. I just ordered a 1000 grain, and I would like to know more about your experience.
I encourage your model, because it is good.
A greeting from Spain.
Amalio. -
MONTAÑES by Amalio
Good morning.
