Posts posted by rlb
Thanks Rick.
Continuing with rough shaping of the Bollard and Hawse timbers, they are glued together, and sanded. After they are close to the right shape, they will be separated and will be filed to form the correct gaps between them. To the left, the first cant frame "Z (Forward)" is also cut out--
The second cant frame "Z (After)" is made up of two pieces each, with a chock. This is my first time building a chocked frame, and the chocks need to be skewed to accommodate the inner and outer bevels of the frame--
The skewed chock is made oversize and glued to the first piece--
Then it is sanded flush on the side without the paper pattern--
Here are the frames with the second piece ready to be glued. However, I discovered that the upper starboard futtock (the one on the left in the photo) is misshapen. The paper pattern became distorted when I glued it down. I had had to lift and reposition it on the wood billet, and during that process it warped. I will need to make some more paper copies, and cut another one--
Ron
I have a little bit more work to show. Final shaping is not done, but I've glued together some of the pieces that make up the bow and stern framing--
The bow assembly-
The sternposts and deadwood assembly--
And the rough cutting out of the bollard timbers and hawse pieces--
Ron
- tlevine, bruce d, Wintergreen and 16 others
- 19
Thank you cisco. Thank you, Johann--your model is extraordinary, and I can only aspire to the accuracy and detail that you are able to accomplish!
I have been working--very slowly.
First, I realized that I need to remove the carronades to make the breeching ropes. Unfortunately, I had glued them to the deck!! Fortune smiled though, and the upper part of the carriages were NOT glued to the lower bed (except for one), and I was able to remove the carronades--
Here they are, with breeching ropes partly done. They need to have the correct knot and iron ring attached to each end of the rope. The first five (including the one carronade that I had to forcibly remove from the deck) are done. Beyond those are the rest which have the first end done, then the line threaded through the breeching ring, and the beginning loop of the second knot lightly glued to hold it for seizing--
This is my method for completing the breeching knot after the first seizing is done. Using a short piece of line, and tweezers, form a simple overhand knot--
Get it oriented correctly--
Position it at the right spot and pull it tighter--
Finish up by giving it a good tug--
The loose ends are then wrapped a turn around, and glued with a dab of white glue. After dry, the ends are snipped close. It's a shortcut, I know, but looks fine.
Now the carronades can be reinstalled, and the eyelets glued into predrilled holes (done many years ago now!!) in the bulwarks--
Next, I will need to make about 30 more of these training tackles--
Closing with a couple photos of Oneida--
Ron
Thanks everyone for the compliments! Yes, Michael, you said that well.
Ron
- Knocklouder and mtaylor
- 2
Andrew,
I have a friend who once owned a Lightning (I don't recall the number), and he built a very fine model based off the Dumas kit. Everything more accurate to the actual boat--I was impressed with his details on the mast. He's the guy who actually got me into modeling. Good luck with yours.
Ron
Just catching up on your build, Håkan. I can tell it's going to be a beautiful model.
Ron
- ct mike, Wintergreen and mtaylor
- 3
Piotrek,
I wish I hadn't missed seeing this before now! You have built a beautiful model in every aspect.
Ron
- Dave_E, Dali and Mirabell61
- 3
Thanks all for looking in, comments, and hitting the like.
Continuing with the rudder work, here are the rudder chains, and tiller parts--
The chains are test for the length and drape--
And after blackening, attached--
I cringe at the poor planking of the transom (some shrinkage gaps), and my less-than-precise painting!
After gluing the tiller to the rudder head, I realized I need to drill some holes for eyebolts for the tiller rope. Of course, this should have been done before gluing the tiller on--
Here are the eyebolts and tiller ropes attached--
Then threaded through the blocks on the bulwarks, and back through the blocks on the tiller--
Ah, but what to do with the loose ends? In the Charles G. Davis illustration that I followed for this, the ropes go to a ship's wheel. But there is no wheel in this case. I reasoned that there should be cleats on the bulwarks to fasten the ropes to. These had to be added--
I'm not sure why Lieutenant Woolsey decided to take a nap during this work. Maybe he overindulged last night.
After tying the rope off to the cleat, a rough coil was made by wrapping the rope (wet with diluted PVA) around a drill bit--
This was draped over the cleat, with much massaging and rewetting, to try and get it to hang sort of realistically--
After finishing this (of course), I remembered that one of Bernard Frolich's brig models with a tiller may have shown me what to do here. I checked, and yes, there are cleats on the bulwarks. However, the arrangement of the blocks and rope is a little different, and it looks functionally superior to what I did.
Here is yours truly working--
Ron
I'm not sure if anyone can help, but 6-9 months ago, someone posted their method for stropping an eyehook to a block that looked miles better than the frustrating, fiddly way I was doing it. There was some sort of looping knot that they started with. I thought I copied the page, or the instructions, or saved an image, but I can't seem to find anything now. I'd be interested to see how you do it, or if you know what I'm talking about, before I start down the road of doing about 60 of these.
Thanks for any help,
Ron
- Ryland Craze, AJohnson and mtaylor
- 3
Thank you, Roger.
Some activity in the shipyard!!
Euryalus has left my living room and has come upstairs to join Oneida in the workshop. This displaces Oneida to a smaller area, but I think that will be okay--
The carronades have been glued in place--
Next, they will all be "stowage rigged" as the one third from the right on the starboard side in the photo. I just have to remember how I did that one--about 10 years ago.
The rudder has been glued on--
That's all for now,
Ron
Hi Hakan,
Yes, Allan and Wayne, the authors of the Euryalus books and plans, were able to help me out. But I am still looking for a used copy of Vol 1 (with the plans included).
Ron
- davec, Wintergreen and mtaylor
- 3
Thanks Hakan, you are welcome to pull up a chair, though not much is happening at the moment! This is going to be a real learning experience for me--hope to make some more progress soon.
Ron
- Wintergreen, mtaylor and davec
- 3
Ben, that's amazing. I remember feeling a shortness of breath on Pike's Peak.
Ron
Ben,
I cannot guess where (though I know it's not Queensbury), but it is stunning.
Ron
hamilton,
I am so glad you are able to play guitar again! I am also a guitar player, and I would be crushed if I could never play again (as I would be if I couldn't build models anymore) .
Ron
HMS Euryalus 1803 by rlb - 1:48 scale
in - Build logs for subjects built 1801 - 1850
Posted · Edited by rlb
That's smart, Greg. On this frame I'm using the paper copy underneath to make sure my frame keeps the right shape, and finessing the chock cut-out on the second futtock if the chock is slightly off. I'll experiment with other methods as I go forward.
Ron
