Posts posted by rlb
I am wondering how to go about cutting down a piece of lumber into usable billets (approx. 2" x 20" x say 1/4").
I hope this diagram makes sense--
My question is--is A or B the preferred method for the "final" cutting, in view of how the grain runs? Does it matter whether the billet will be used for framing, or if it is going to be further cut into planking strips?
Ron
- Archi, mtaylor and thibaultron
- 3
You might add Nona to the list. I think it was a pilot cutter, owned and sailed by Hilaire Belloc.
Belloc wrote a great little book titled "The Cruise of the 'Nona'", in which he sails along the coast of Southwestern England (if I remember correctly), ruminating about the wonders of sailing, among other things.
I've thought of trying to model this, but there is little information I've found. Just this photo (on a card from a friend who introduced me to Belloc) and some minimal description in the book.
Ron
I'm calling this done. Sometimes you get to a point where you're afraid of going just too far, and messing up what you've done to that point.
The beak never really materialized, there's no feather texture on the neck and body, and the wing feathers could be better (well, everything could be better), but I'm happy with this, and I'm going to stop before I slip and make an irretrievable mistake--
Isopropyl alcohol is repeatedly swabbed over and around the eagle to loosen it--
And after a while, the eagle is released--
This afternoon, from my porch, I surprisingly saw this guy (or gal) hanging out in a tree across the street--
It stayed put long enough for me to run inside, grab my camera and move a little closer for a couple of shots--
Now, that's what the beak should look like! Still, I took it as an good omen that I was done.
Ron
Thanks Phil! So many things to learn in this hobby. I'm enjoying the carving, though I can't imagine doing a ship with a lot more. It's very slow going at this point.
Continuing to work on the overall relief areas--
At this point, I began thinking that the thickness of this piece from the "ground plane" of the flattened area was about right, and I needed to get rid of that "ground" and to reduce the overall height. Rather than shave everything down from the top, I unglued this from the base, and rubbed it on sandpaper until that "ground" was paper thin and translucent (guessing I removed about 3/128ths of an inch!). Then I glued it back, and trimmed what was left of the "ground" away. Now I am continuing to work on developing the relief--
If you compare this to the last photo of the previous post, I think I improved the shape of the shield (the curve of the right side and top, which were too flattened before), but I may have somehow reduced the width of the eagle's neck too much.
Ron
Working VERY slowly on the eagle. At this rate it will take me a good week to finish it.
As I've worked, I've discovered details I missed at first (one important one being the talon gripping the shield), and I've sanded down the surface of my carving to be able to recapture those details. My model image is very low resolution, and if I look at it too enlarged, the details (like the talon) blur too much to be apparent. I have to look at it small, to see more!
The outline is basically there now, and I am working on developing the basic relief areas--
I am realizing that the beak is critical to this piece, and I am holding off on its definition. It's what will distinguish this from being an eagle, seagull, donkey, or an aardvark.
Ron
Thanks, Martin.
I am using a small piece of Castello Boxwood, temporarily glued to a hunk of wood. Here is a photo with some scale context--
The eagle itself will be 13/16ths of an inch across.
My birthday was last month, and I treated myself to a very nice set of micro carving tools. It was that or the Byrnes saw, and these won (and they were less expensive). I feel a bit foolish, as they are for folks way beyond my talent level, but the carving is something I want to get better at.
Here is my model for the eagle--
Ron
Change of pace.
I began carving an eagle for the transom--
- Ebomba, CiscoH, Duanelaker and 6 others
- 9
Now that the anchors have been cast, I still have to figure out how to deal with the iron stock. I'm not going to attempt soldering near the casting, and I would like to be able to use the stock I already made. I thought of hammering the "foot" end narrow enough to pass through the hole in the anchor, and then hammering it flat again, but I have doubts about that working well.
I decided to saw the stock in half, with the thought of epoxying it together after blackening (I'm not sure how epoxy would hold up to the blackening process--has anyone tried that?)--
While sawing I had the thought of drilling a hole in both ends, and soldering a small bit of wire as a pin, to make a more secure joint--
Here is the pin soldered in--
My hole was drilled a bit off center (I'm a terrible machinist!), but so is the hole in the other half of the stock, so as long as I get them rotated correctly, the halves should line up well--
This is dry fit--I admit I am tempted to try soldering the halves together, using heat sinks and wet paper towels. Maybe I'll do some experiments with an extra anchor. But most likely I'll epoxy them. The shank will be lashed down with the anchor; there should be minimal stress on the joint.
Ron
Thank you so much, Dowmer, Steve, Dave, Dan, and Martin for you words of condolence and encouragement.
Martin, you are so right. These failures are a big part of model building, and I must remember they will never end! Best of luck on your workshop drawers, you will get it right!
Dave and Dan, if I had thought about a heat sink (as I should have), it might have helped, though the tin alloy has a melting point MUCH lower than the silver.
A little surprising to me (and maybe a result of your encouragement), I am back at it today.
I decided to go back and correct the mold (thanks again Dowmer) before casting another anchor.
Here is the mold in question--
On the right half, you can see flaps of silicone at the bottom tip of the anchor that cause trouble with the casting. As I mentioned before, the depth might also be suspect.
I took the left half, built a new mold box around it, placed the anchor, made a pour head, and cut new wires to fit in the air vents. These were particularly difficult to match up with the mold, getting them to settle in correctly with all their irregular curvatures--
Here is more detailed description of the mold material mixing and pouring. I use disposable cups because after my first trial, I discovered that the two parts before mixing are messy and not easy to clean. Easier to just throw away the containers. The center cup though, can be reused, since once cured, the remnants of mixed, cured material, can easily be removed.
Here I have poured the two halves, estimating the amount I need--
Now the 5 minute timer begins as I combine the halves--
I use a regular kitchen teaspoon to clean out each cup, not wanting to waste any of the material--
Using the same spoon, it is mixed in the cup--
And finally, poured into the mold--
My estimate was just a bit over, I didn't mean to fill right to the top. But better a little too much than too little--
After an hour or so of curing, the mold can be separated. First, peeling away the cardboard box--
Then peeling apart the mold. This looks a little ugly here, past instances have been cleaner--
But it's not so bad. There is a little bit of "overage" on the lower part of the anchor, but I think I can clean that up--
Here are the halves, cleaned up and powdered, ready to assemble and pour. I'm not worried about the extra flaps of silicone on the air vents, that doesn't seem to affect things--
The result of the pour--
This looks fantastic, actually. Much better than the old mold. However, there was some funky stuff going on at the head of the anchor, with the pour cap, that made this unusable in the end. But the basic mold was good, and I set about pouring some more, in this size, as well as the other sizes--
Though I never got another one of that third size without any flash at the bottom (as in the previous photo), I now have a complete supply of good anchors; and unless I have another disaster, these should do me well--
Great job, Chris.
Congratulations on finishing!
Ron
In between gluing the channels to the hull in preparation for test fitting the chain plate assemblies, I worked on the second iron-stock anchor.
In the first anchor, I made the right angle bend and spread the end after soldering the stopper flange in place. It was not easy to make the bend and detail the end after it was part of the anchor, so I decided to do it the other way round, and make the bend and flatten the end first, while I had better access--
Then, I can slip the anchor on, and then fashion and solder the flange ring--
Instead of simple wire, this time I drilled a hole in a piece of brass bar stock, cut it out, and filed the flange round--
It test fit nicely on the iron stock, and I was feeling pretty good about the whole thing--
Here it is ready to solder--
I held the torch to the ring, and waited for it to glow and the solder to run. It never happened, but what did happen is this--
After it was cool enough to touch, I discovered that the ring had been soldered. Maybe before the anchor melted, I don't know. I'm not used to soldering larger pieces of brass like this.
First the deadeye burning, then melting the anchor. Both through mistakes that could have easily been avoided. It's easy enough to cast another anchor. The stock is more work. This one can't be used because it can't be fit with both the flange soldered and the flattened end already done! Additionally, this was one of the anchors that would benefit from a better mold, so do I take it back that far and redo the mold?
My battery of mental energy is depleted. I may take a few days to recharge.
Ron
Hi Mark,
You always have the most interesting questions! I'm not sure this is any help, again photos from Victory--not your ship--but the first photo shows the access door to the roundhouse as a small vestibule with a door at the deck level. You can just see the ladder steps (look under the hammocks that are in the way), and that horizontal gleam just below eye level inside is the "seat".
Here is the interior of the roundhouse (looking from deck level)--
And finally from a little farther back showing the vestibule and door on the left, and on the right edge the steps leading up to the bow platform--
Ron
PS. If you would rather not have these photos cluttering your excellent log, let me know, I'll delete them.
Heh, heh,
Well, only a small update. I didn't do much on the ship today. Just work on fine tuning the shape of the binding links, and the middle links. When stretching out the middle link of the last assembly, the joint gave way. No problem, I'll just solder it back, better than ever. I laid it out with the dab of silver paste, fired up the torch and applied heat. I watched as the flux melted, the link turned red, and the silver melted across the joint. Then I smelled it--burning wood. As I moved the torch away, I could see the little deadeye glowing red around it's circumference where it was held by its binding link. I licked my fingers and gingerly pinched the deadeye, hoping to cool it and stop any damage. It was hot and still glowing as I released it. I pinched it again but dropped it on the floor. When I picked it up, it was no longer burning, but the damage was done, the perimeter had burnt away and it fell out of the binding link! In the center of the photo, one burnt deadeye, and one crushed--
I replaced it with my one remaining spare, and now I have my 20 chain link assemblies, ready to test fit. And if I have to re-solder any of them, I will remove the deadeye first!!
Ron
I am imagining your house filled with display cases. First you see one filled with military aircraft (superbly done, by the way). The next you see is all dolls. Then another with aircraft. Then more dolls. And so on. Not aircraft in one room and dolls in another. All in one room.
Ron
- Javlin, Canute, Old Collingwood and 5 others
- 8
Thanks to all who have taken a look, and those who have hit the like button. Thank you, Dowmer. It is very satisfying to have learned something new, and cast the anchors out of real metal, instead of making them painted wood.
The first, smallest one, actually came out the best! There are some minor problems with the molds, especially on the middle two sizes, having to do (I think) with not having the anchor forms securely and fully bedded in the first half of the mold before pouring the second, which resulted in the anchors coming out a sliver too "deep". I'm not positive that's why because I thought I was being very careful on that point. It's also possible there was some flexing in the mold with the way I held the halves together. In any event, the anchors look good, and I am almost out of mold material, so I'm not going to try redoing the molds at this time.
I want to blacken the anchors with the chain plates and links, so I need to continue on with those.
I have the binding links, toe links, and chain plates made, so all that is left are the middle links. With tweezers I held a test deadeye and binding link in the chain plate, and pinned a toe link to it's location on the wale--
Then I bent a piece of wire to bridge between them--
Using this piece I then put two pins in some wood, to bend a link around-
I only made one, as a trial, and after removing the deadeye from the binding link, assembled all three links together, and soldered the middle link closed--
The safe way would have been to use higher melting solder on the binding and toe links, to avoid them coming unsoldered when heating the middle link. I only have one type (I think it's the lowest type, or maybe middle) but I had no problems with the other links.
I replaced the deadeye, and the assembly was then test fit. On my first try the link was too long, so I shortened it by snipping it, trimming it, and re-soldering it. This time I soldered it with the deadeye still in the binding link, as an experiment, and there was no damage (meaning I didn't burn it up), so if I have to make adjustments on the rest of the middle links after the fact, I should be able to do so without too much fear. Here is the test chain link assembly--
And here it is test fit--
I made 20 or so more middle link loops, assembled them with the other links, and prepared to solder them--
I had a relatively large number of failed solder joints (six or seven). Not the already soldered joints, but the new ones. One link actually melted, and I had to replace it with one of the extra loops I had bent. One link I had to re-solder three times before I got it right! Eventually they were all solid joints.
I will temporarily put all the deadeyes in, and test fit them all before blackening. Technically many of those middle links should be different lengths to account for the increasing angle of the shrouds. Actually, I'm sure many of my toe links and middle links vary slightly, so I'm hoping I can match all the assemblies to the place they fit best. And if I have to snip and redo some links, so be it.
On the left is the first test assembly that is pretty much bent "to spec". The second is not finished; its binding link is only roughly to shape, and the middle link hasn't been "stretched" and straightened. And of course the third hasn't even had the deadeye bent into place--
In the course of fitting the deadeyes (so far), I crushed one. Its remnants are in the middle of the photo below. To the left of it is my one remaining extra. In the container to the left are the matching upper deadeyes that the shrouds will be attached to, and in the lid are the smaller topmast deadeyes and their binding loops. Those may wait for a later time, though it would probably make more sense to do them now also--
I'll finish putting these together, then test fit and adjust them. Somewhere in there I'll fabricate the iron stock on the larger of the two round arm anchors. Then I can blacken everything.
Ron
- usedtosail, Dubz, BETAQDAVE and 9 others
- 12
Carrying on with the anchor molding and casting:
The second RTV pour, completing the molds--
After separating, these were not quite as well done as my first mold. Mostly, I had to clean up some of the air vents, but there were some other irregularities as well--
Then I talcum powdered the molds and taped them up--
I heated up the metal (and heated the molds in the oven, before taking them out for this picture)--
When the metal was ready, I poured. At this point, the back end of beginner's luck reared it's ugly head--
On the third mold, the metal just ran completely through the mold!!--
Opening this third mold I was quite surprised to see there was nothing cast. The metal had all run through the mold--
The second mold also didn't look good. There was excessive "flash", indicating that the mold halves were not in close contact--
The third mold (first poured) seemed okay--
These two might be keepers, if I could trim the excess metal from the anchor on the right--
I couldn't. The anchor snapped in two while I was trying to trim the metal. Redo. So, I figured my cardboard and tape hadn't pressed the two halves of the mold together well enough (even though I had done the same as I had done on that first successful small anchor). I changed my tactic a bit, using two layers of cardboard, with the innermost matching the dimensions of the mold, and less tape holding the mold together--
These were poured--
And the results were much better--
Then, I re-poured the third mold from the first try which had seemed good. I just wondered if with my new method it might be even better--
It was about the same as before. But all-in-all I am done casting!--
These should clean up okay, I have a couple of spares, and I am very pleased to have learned a new skill (though far from mastered it!).
Ron
Chris,
I like the new ones much better, if it's any consolation.
Ron
- ccoyle, mtaylor and popeye the sailor
- 3
Part two of anchor casting.
After successfully casting the first anchor, it is full steam ahead for the other three.
This photo shows the three stages of working the clay around the wooden mold. First the clay base is roughly leveled and smoothed, and a cutout made for the anchor. Then clay bits are added and mushed up against the anchor form. Then the clay is carefully smoothed against the anchor form (with a small screwdriver, and the point of some tweezers), trying roughly to put the surface of the clay at the halfway depth of the anchor, and make sure it is "tight" to every profile of the anchor. It is important to avoid any stray bits of clay that may cling to the anchor form. Then wire air vents, the pour head, and the registration dimples are added--
After painting all the surfaces with mold release, these will be ready for the silicone pour-
I find it difficult to guess the amount to mix up. Too much and it will go to waste--it is fairly expensive material, and I hate wasting anything anyway! Using the amount I used for the first anchor, adjusted for my slightly bigger box for these larger anchor molds, I mixed up a batch and started pouring--
As I got to the end, I realized I wasn't going to make it. The pour caps remained uncovered--
It's the quick setting (5 minute) variety, so hoping I wasn't too late, I hastily mixed up a small amount of additional silicone, poured, and it was just enough to cover--
Unboxing the molds. I had added two layers (one still sticking to the clay) of cardboard under the clay so I wouldn't need to use as much clay--without the spacers I wouldn't have had enough clay for all three molds--
Interesting that they peeled apart in three different versions. One with the anchor and vents with the silicone, one with the anchor but NOT the vents, and one with the anchor and vents sticking with the clay--
Doesn't matter, the parts stuck in the clay are positioned back in the silicone. I need to rebuild the boxes around these, fill in and add some more clay for the pour heads, and they will be ready for the second silicone pour--
Oh, I also made the twenty (plus some extra) toe link loops for the chain plates, and bent them into shape. In the picture they look very irregular. Some of the angle bends I can redo better, but the squiggle irregularities
I'm not sure I can eliminate. They were a pain to make--
Ron
Those are all great subjects, and I look forward to seeing them develop!
- mtaylor and thibaultron
- 2
US Brig Oneida 1809 by rlb - The Lumberyard - 1:48 scale - POF - Lake Ontario Warship
Posted · Edited by rlb
Hello All!
It's been a while, about 6 months, since I've done any work on Oneida. I felt I botched some work, and it sapped my motivation completely. It's only in the last few days that I've felt ready to start (yet) again.
Back in June, after finishing the eagle carving, I made preparations to paint the ship's name on the transom. I wanted to actually paint the letters, not use a decal, or transfer letters. I knew I was going to have to turn the hull upside down to do this, so I wanted to do it now, before finishing anything else.
I experimented printing the name is some different fonts, and different sizes to arrive at something that looked about right.
Here is the printed name, taped to the transom with a small piece of white transfer paper underneath--
At this point, I nervously turned the hull upside down, hoping I wouldn't break or lose anything. I left the ship's boat lashed down, and removed anything that could be taken off easily. This photo is after I then "colored" the lettering with a sharp pencil, which transferred the letters onto the planking. You can barely see it there on the transom--
Here's a close-up. Not too pretty. But enough to give me a reasonable guide for painting--
I used some artist oil paint, and the finest brush I have, and did the best I could. It was not very good. I didn't even take a photo. For some reason, this completely deflated me. And, unfortunately, I gave up the ship. I turned it right side up, and left it alone.
Fast forward: I'm working from home due to Covid, don't get out much except to grocery shop, and when it was warmer, do some walking/hiking on the weekends. I finally got bored enough to look at the ship (actually I have looked at it often enough, but without any desire to do anything), and see if I could make some improvements to that attempt at painting the name.
I turned the hull upside down again-
And I set about with a knife to trim and scrape at the edges of the painted letters, trying to clean up the serifs, and the uneven thicknesses of the strokes. In this photo, all of the letters have already been given some work. It was worse before--
All the letters needed some surgery, but the ones that needed the most work were the "O", the "N", and the "D".
After cleaning this up, it looked better. Not as good as I would have liked, but enough better to accept. I also had to glue a transom molding that had become detached at one end, and I glued the eagle-
You can see a nasty gap in the transom planking. It was the first planking I had done on the whole ship, and it looks it. I think I can fill it with some darkened sawdust and glue.
Here she is back right side up--
I've also continued working on the anchors. Here the wood anchor stock pieces are shaped, treenailed (for appearance only, for they should have been drilled through the companion piece also; but that would require a precision in which I have not the confidence), and carved out for the shank. I've cut a thin sliver of brass sheet for the iron bands that help hold it together-
All for now--Happy Holidays and Joyous New Year, if I don't post before then.
Ron
