Everything posted by mtaylor
WWII Aircraft by Javlin - PLASTIC - The Unfinished to Finish
mtaylor replied to Javlin's topic in Completed non-ship models
Your display looks great, Kevin. Is there an admission price to visit your museum? -
Fairing the bulkhead
mtaylor replied to Worldway's topic in Building, Framing, Planking and plating a ships hull and deck
Emory boards here also among other ones made of wood. I use the flexible type sold by beauty supply shops. As for the ones made of wood.. generally a piece of scrap tweaked to the size and shape needed and then sandpaper glued to it. -
Hi SeaDoc, Welcome to MSW. I would suggest that you go to the kit build area and you'll see an index of all logs.... https://modelshipworld.com/forum/130-build-logs-for-ship-model-kits-by-era-launch-date/ Also, if you scroll down a bit, you'll see indexes by era. Go to the appropriate era for your models and you can search for logs from there. The best way to clamp is one of long debate as everyone basically has figure out which way works for them and for their particular model. There is a section for "tools" but it's not specific on the application to a particular ship, so the best way is look at the logs and see what others have done. Also, open a log of your own so that others can follow along help out when needed.
Hi Mark, welcome to MSW. I'll just second the motion of the others about a build log. It really is the best way to go.
I think it's your choice. At the size you're building and dimensions of the blocks, both will look good but ever so slightly different as much of the detail will be lost by the rope going through them. The other thing is the stropping will hide some of the detail also. I do like the look of the last picture you posted. Best thing might to strop one of each type, them run some line through them and see how each looks.
Greetings! Long time lurker coming out of the bushes!
mtaylor replied to EKE's topic in New member Introductions
Dornier Do-217K-1 by Papa - FINISHED - Revell - 1/72 - PLASTIC
mtaylor replied to Papa's topic in Non-ship/categorised builds
Definitely looks the part. Ready for the hanger now. -
Beautiful work, Eberhard. Even pointed out, I'm not seeing the errors. As for uploading... if something happens like a server move, all your photos will disappear so there's one good reason to upload them. Over the years, more than few logs had be deleted as the owner and the photo storage site went away.
That plate looks like a field upgrade, Joe. Very similar to what we did for the gunners in the CH-53's. On the window side it was riveted to the fuselage, on the door side, it riveted to the gun mount. As a field upgrade there probably isn't any "official" drawings. Probably just some sketches done by the metal shop so they could make what they needed and also replacements.
Larry, could your post the images using the .jpg format? The HEIC format is one that only Apple uses. We Window users can't see the photos. Thanks.
- 84 replies
- nimblet
- knockabout
Wolf, you've done a wonderful realization of this this model. Beautiful.
- 197 replies
- santa maria
- carrack
New member from Johnstone, Nr Paisley, Scotland
mtaylor replied to Marshall54's topic in New member Introductions
Welcome to MSW. I suggest you have a look at this topic before starting Supply as it has some great advise. -
Russ, I thought the plastic was an advantage as they're crisper than most metal parts and also the reworking to get them to fit the curves. A little hot water goes a long way to improve the fit. I used cherry wood (very thin) over the kit planking and it came out quite well.
Edge Gluing Planking
mtaylor replied to Neil10's topic in Building, Framing, Planking and plating a ships hull and deck
One a POB, the spacing of the bulkheads can be a problem when planking depending on how far apart the bulkheads are. Filling in between bulkheads will solve this issue. With a POF, it's not a problem as the frames are fairly close to each other. -
In use, the inhaul was usually not in place on the guns as it got in the way while serving the gun. This, of course, was dependent on the officer in charge. If not fitted, they could use one of the training tackles for this or (again subject to practices) there would be one hung near the gun in case it was needed. The only reason it was really needed would be if for some reason the gun didn't recoil during firing or to remove the shot and powder after action.
