Everything posted by mtaylor
B-25 Mitchell "Meet Miss Runyon" by Javlin-HK-1/32
mtaylor replied to Javlin's topic in Non-ship/categorised builds
I hope you'll open a log for it. -
SBD-3 Dauntless 1:48 Hasegawa - Edwardkenway-FINISHED
mtaylor replied to Edwardkenway's topic in Non-ship/categorised builds
Wonderful work on her, Edward. Pity it has to go into storage. -
I finally took the plunge.
mtaylor replied to florida_troll (James)'s topic in New member Introductions
Welcome to MSW, James. Doing a build log is one of the best tools. Have a look here at the first four topics. It should give you an idea of the essentials and the ones not to buy. http://modelshipworldforum.com/ship-model-materials-and-tools.php -
I wish you a full recovery. Don't overdo on the ship as rest will help your body heal.
- 2,696 replies
- heller
- soleil royal
(and 9 more)
That you and your family are not infected is good new, Jack. I hope it remains that way.
- 190 replies
- ragusian
- marisstella
I looked at the picture before reading the text and the only thing I could think was... "Ow.. that's gotta' hurt". The shields and crew are coming along nicely.
Vladimir, I hope these links will help... There might be more as just searched using "cutty sark" and "photos". https://modelshipworld.com/topic/23303-cutty-sark-photos-of-the-real-ship-taken-while-visiting/ https://modelshipworld.com/topic/21326-on-board-of-the-cutty-sark https://modelshipworld.com/topic/6858-revealing-cutty-sark-pictures-you-may-not-have-seen-yet You might also check the various build logs on the Cutty Sark.
- 200 replies
- cutty sark
- clipper
Eric, If you know how long you the boats, then you'll know for the kit. MS makes some and so does MasterKorbel. I think the MS would work just due to the design where the MK would be best for frigate unless heavily modified. As for MS, if they don't have the size you need, if you have a scanner you can scan the parts and then scale them to the size you need.
- 599 replies
- sidewheeler
- arabia
(and 4 more)
Hi Paul, Welcome to MSW. Nice work on the boat.
Check here: https://www.syrenshipmodelcompany.com/ You might consider a ropewalk if you'd like to make your ownl.
Don't know if this will help....
The more things change, the less they really do.
Al, Here's a link where there's several articles on tools needed, tools to ignore, etc.: http://modelshipworldforum.com/ship-model-materials-and-tools.php
North American P-51D Mustang by Asat - Airfix - 1/48
mtaylor replied to ASAT's topic in Non-ship/categorised builds
I have no idea. When I built my CH-53, I looked for after market parts. I ended up overseas in eastern Europe. There's a caveat to this... the CH-53 is NOT a popular model so after market would be hard to find. Edit: I see you started a separate topic for this question. I was going to suggest it but you beat me to it. -
Setbacks do seem to be part of the learning process, don't they? I wish the virus would go away and we can get back to "normal"... whatever "normal" is. If they're coming from overseas it can take some time even when things are normal. There's a couple of places where if you order from them, they have to order from someone else which adds more time. -
Is there a trick to making deadeyes?
mtaylor replied to Schooners's topic in Masting, rigging and sails
Jaager has a good point and it jogged my mind. Somewhere here, I remember seeing a build that used a drill to cut out the deadeyes. Ah.. found a couple: https://modelshipworld.com/topic/1005-la-belle-1624-by-cabrapente/?do=findComment&comment=18693 and here: https://modelshipworld.com/topic/410-hms-sphynx-by-alex-m-scale-148-english-20-gun-frigate-as-build-1775/?do=findComment&comment=10133 There's more, I used keywords "deadeye making" not as a phrase. But the others I looked at pretty much do the same. There's others that use the same technique of basically making a cutting tool that cuts out a length from a block of wood then they put it on lathe and shape and then cut free. -
Are you notching the keel or the bottom of the frame? If not, will be putting a wooden peg through the frame to the keel? I'm wondering about strength if relying only on glue.
- 58 replies
