Everything posted by mtaylor
One of the problems with scanners is that they do not produce exact copies even at 100% to prevent the counterfeiting of money. You can do what Tony suggests but also if you first scan a ruler at the size needed, you can then check and see what needs to be tweeked as far as size using photoshop or similar. The other way is to find an architectural copy shop that does copies for architects. They will automatically produce an exact copy scaled down. I use both methods depending on the size of the original. Nope.. not legal to share plans.
Eyebolts are pretty easy to make if you don't want to buy them. Some thin copper or brass wire (appropriate to the existing ones) and small drill bit the size of the hole on the existing ones. Pull a length of wire over the bit and twist. It'll take a bit of practice to sort out how much tension to use when twisting but it isn't all that hard. A lot of scratch builders make their own. Do you have a photo of the pawls?
Welcome to MSW, Redline. If you go here, you'll find 3 logs: https://modelshipworld.com/topic/17023-quick-find-indexes-to-build-logs-for-kits/ Which are: https://modelshipworld.com/topic/15685-viking-by-dave-cormier-artesania-latina-scale-175-the-easiest-wooden-model-boat-i-could-find-first-build-ref-19001-n/ https://modelshipworld.com/topic/20480-viking-longboat-by-dvlp47-artesania-latina/ https://modelshipworld.com/topic/10066-viking-by-hojofan-artesania-latina-10th-century-replica-gokstad/
Happy Father's Day, Lou..... for that I gave you like. Everything else is "meh".... Plumbing is not fun.
- 446 replies
- zebulon b vance
- deans marine
(and 3 more)
What is the purpose of these holes in this block?
mtaylor replied to Louie da fly's topic in Masting, rigging and sails
Pat, the archaeological report says "This block was found concreted to the downslope arm of the ship's forward port bower anchor." That's it, I'm afraid. Doesn't tell all that much, does it? Interesting. Possibly then it was for working the anchor? -
Have a extra $100.00 to spend......
mtaylor replied to CPDDET's topic in Modeling tools and Workshop Equipment
I agree with what Jaager says. Buy it when you need or if you "know" you'll be needing it. As far as bending planks, one can go a garage sale and pick old curling irons (in various sizes) for very little money. -
Chris, You might as Maristella's owner here as he could probably give you more than enough info:
- 190 replies
- ragusian
- marisstella
Somethings missing here. I can't quite put my finger on it (mentally speaking). Is it possible that the lower block is missing and that they were used similar to dead eyes where you'd need two? Then a set of the holes could for knots.... Or maybe this block is upside down? Anyway, that's my guess.... -
Steady hands and sharp eyes. Beautifully done.
- 306 replies
- schooner
- la jacinthe
Thanks for the feedback. I'm starting to use it and it really is wonderful.
- 1,784 replies
- winchelsea
- Syren Ship Model Company
Why? Probably profit. AL moved from (I think it was) Italy to Vietnam due to costs. The some of the designers didn't move and founded OcCre. Their kit came out long before the monograph. They have a long history of not upgrading kits. Their Constellation is a good example of this. BTW. I have the monograph for L'Hermione and there's some errors in the plans (the framing). I'm not sure if they have corrected them yet. At this point, it's probably a ship I'll never get around to building.
The Japanese had a guided bomb towards the end of WWII and was used in several of the suicide attacks. Dropped by a Betty as I recall. The thing was actually radio controlled. Since this is a "fantasy" build, why not have actual drones using both technologies. Ok..... I'll get my coat and leave quietly now.
- 345 replies
- graf zeppelin
- trumpeter
Downer, It doesn't bleach out in light then some other woods?
- 1,784 replies
- winchelsea
Ah... so it will have jets and guided buzzbombs then. Good thing the Germans weren't working on lasers back then. I guess I should specify that the V1 could be considered an unguided drone?
- 345 replies
- graf zeppelin
- trumpeter
