mtaylor
Moderators
Everything posted by mtaylor
  1. Marvelous work, Gaetan. Maybe it's the bigger size and the excellent photos but she looks to be the real thing.
  2. Thumbs up for helping dogs. Now I need to figure out a thumbs down on the ankle. I'm just happy to hear the rock didn't land on you.
  3. Beautiful work. I'm just following along quietly and enjoying this build.
  4. I would use them as the figure 349 has them. They appear to have been used to protect the wood. I also see that the washers were held in place with what appears to be bolts to keep them from moving (figure d).
  5. Amazing work, my friend. Very impressive.
  6. Can you show us a photo that has elements of the butt, washers, etc.? It's possible we don't (I know I don't) understand the question.
  7. As I recall, his job started taking much of his time and then family. I'm hoping he's ok and that maybe we'll hear from him one of these days.
  8. Mike, Get the "best" paper ones (if that's all that's available) you can find. Most don't filter out the really fine stuff but a bit of wandering around the local home improvement shop should turn of some disposables that work on the fine stuff at a reasonable price.
  9. Mike, Google search on the type, size, and tooth count and try setting your location in the search even if it's -USA (not USA). The Thurston specs could be used as a guide.
  10. Sorry Derek.... no idea on the gauge off the top of my head. Thought there was a set of plans for the guns and carriages. It might be on the plan? Here's a thought... go to the very end of this section and find the logs for UWEK and Scottacus. As I recall, they were pretty compete and detailed and for a long time UWEK's was the reference.
  11. Count me in. I'm finding these steel navy models fascinating to watch even if my eyes won't let me build one.
  12. Sure, it's a ship. We have quite a few kit ships (plastic and resin) and many hybrids (mixed... wood, resin, etc.).
  13. Right Kurt. I think we're both saying the same thing... I don't think anything acidic would be a good idea.
  14. Varnish won't hurt. But give some thought to a good waxing, perhaps car wax or a paste wax for wood.
  15. Ed, Either of those two methods should have worked although the thickness is probably an issue. They may need more soaking time as you didn't specify soaking time or the wood type.
  16. I'm not sure anything acidic is good to use unless the wood is washed or the acid neutralized. I've heard of sails colored in tea/coffee being eaten in a few years so I'd think the same would apply to wood but over a longer time frame. This would apply to vinegar also. I might be wrong and if I someone knows different, let me know and I'll delete this post.
  17. I don't know if the Brits changed the ship name on the ship or only for "paperwork" purposes. But.. both sides were known to carry "extra" flags of other nation's navies. Sort of an early stealth attempt that was often quite successful. All sides many times did not have a flag flying at sea and then raised one as appropriate.
  18. Thanks for the comments and the "likes"... I'm using 400 grit at the lowest speed (2000 rpm) plus, if I put too much pressure on the tool, it stops spinning. Speed wasn't my issue, it's getting to the darn things and this seems to be working. Thanks Dan. I'll look into them although I've never used them. Might be useful for the next project as a bit late for this one. Hmmm just looked.. .9" wide. A bit too wide for the space I have to work in.
  19. Derek, I think it looks pretty good from here. If you have some scrap wood, mock up a deck section with a gunport and put into position. BTW, if you do the mock up, it makes a great jig for working on the gun rigging.
  20. Thanks for the likes and comments... It's been too long since this was updated... so this is a short update about a pesky, self-induced problem. Between doing things around the house and yard, numerous medical visits for both Janet and myself and trying to sort my brain out and what's what, I've been pounding my head over a problem. If we go way back to cutting out the frames, I put some "tits" on the frames to allow for positive placement of the deck clamps (I think that's right... brain fart). But.. I've forgot how I was going to deal with them when I did the inner hull planking. My bad... and my notes are no help. Here's one frame.. those "tits" are highlighted by the red arrows. After much angst, occasionally thinking of just burning her in the stocks, I started to hand sand them with a thin piece of scrap sanding stick, I punted. The sanding stick was taking forever and I wasn't pleased with the lack of control and also damage from my fat fingers. Here's the area I was dealing with... you can see a couple of the offending pieces highlighted in red. What I finally came up with is the below tool.. a felt buffing piece with some sticky-back sandpaper attached. I'm using my mini engraving tool as it's small, lightweight, and the lowest speed is a good 3000 RPM less than a Dremel. It seems to be doing the job. Once I've got the sanding done, I'll finish the planking. Anyway, I'm still at this and hope to have another update as soon as time permits.
  21. I'm looking at my build of the Scottish Maid from about 15 years ago which was the first ship model I did. It's possible the kit has been changed but I'm not sure. Based upon what I see, there's ample room for the spanker boom tackle as it's secured to the top of the aft bulwark.
