Everything posted by mtaylor
I recall there was a post and I can't find it referencing a Youtube video A quick Google and here's the one's of models being historically correct: https://www.google.com/search?biw=1329&bih=759&q=youtube+titanic+model+sinking&oq=youtube+titanic+model+sinking&gs_l=psy-ab.3..0i30k1l2.22391.23284.0.23636.6.6.0.0.0.0.165.743.0j5.5.0....0...1.1.64.psy-ab..1.5.741...0i7i30k1j0i13k1j0i8i7i30k1j0i13i30k1.0.1Ve-MDSMzE8 Expect to spend several hours if you watch all of them...
Metal work resourcnes
mtaylor replied to Kurt Johnson's topic in Metal Work, Soldering and Metal Fittings
Mike, What I found useful was basically the beginning of the book and little bits and pieces elsewhere. True, it's not a shipbuilders guide but the principles apply. I believe he said he's revising it to add techniques for shipbuilding. BTW, is log on the Constitution is an education unto itself Hope this helps. -
Count me in. I find these boats and their history fascinating.
- 599 replies
- sidewheeler
- arabia
(and 4 more)
Given the habit of kit makers, you probably have the wood in the right places then.. light colored decks and darker hulls. We all get gaps in planking at some time so just sand away the deck to get it smooth. Do NOT vacuum or dispose of the sawdust. Mix that with a 50/50 mixture of glue and water and apply as filler between the planks. Let dry and sand again. Repeat as needed.
- 9 replies
- first build
- swift
Try trimming the clear off closer to the "ink" first. Also many spray the matte finish after the decal is in place and dry. I'm sure others may have a better technique.
- 8 replies
- decal
- weatherring
So far, so good. As for the veneer, is it darker than what you planked the deck with? The pictures of the whole deck look pretty good from here.
- 9 replies
- first build
- swift
An excellent lesson in perseverance, Dan. It looks great and I was happy to read you got the solution you needed. Hopefully things get a bit easier from here on out.
- 287 replies
- michelangelo
- ocean liner
Excellent work on the paintings. Not just the subject matter but the atmosphere really gives a sense of being there.
That's the one and yes, that's the hull shape from the stern. The French frigates had some beautiful lines.
- 290 replies
- confederacy
- frigate
Nice choice Chris. She's a sweet looking frigate.
- 290 replies
- confederacy
- frigate
Pete, I don't know if you're only covering English ships, and I can't speak with 100% certainty, but the French didn't use "stoves" as such. The used "fireplaces" that were open on the front and top with large pots for boiling the food. Under the overhead beams were plates that directed the smoke to the chimney. The fireplace used for the officers could also roast meat. They also had ovens for fresh bread and "pastries". I'm not sure what is meant by "pastries" back than, however.
Congratulations on a beautiful build, Chris. I hope you'll post some pictures in the case.
- 290 replies
- confederacy
- frigate
Swan class 3D model in progress
mtaylor replied to dvm27's topic in CAD and 3D Modelling/Drafting Plans with Software
Your artist is doing some magical work, Greg. I hope you'll show us more. The detail is incredible.- 141 replies
- pof swan series
- swan
Recommendations For A Good Milling Machine
mtaylor replied to Thistle17's topic in Modeling tools and Workshop Equipment
Joe, I was going to comment the same thing as Wefalck. It does look like the column is in the front and not the rear. That is a nice machine however. -
Atlantis by Thistle17 - FINISHED - Robbe
mtaylor replied to Thistle17's topic in RC Kits & Scratch building
Just curious Joe, would rubbing compound fix it? Is it in the same spot? I wonder if there's a defect in the hull right there if is as I used to run into that way back when I did model cars. -
Best Model Company with great Kit Instructions and Plans
mtaylor replied to Sapot's topic in Wood ship model kits
Simon, Search MSW for the ships you're interested in. It's probable that the model has been built at least once and often the builder will put info in the log about deficiencies, instructions, etc. Basically the good, the bad, and ugly. -
ancre Chebece 1750 by Jeronimo - FINISHED
mtaylor replied to Jeronimo's topic in - Build logs for subjects built 1501 - 1750
Maybe it's me but the pictures didn't come through. -
Cutty Sark by NenadM
mtaylor replied to NenadM's topic in - Build logs for subjects built 1851 - 1900
Extended days? I too wish for those, my friend. Your little boats look great and it's good that you found some time. Cherish the children while you can for all too soon they will fly away to new adventures and new lives. Taking care of you and being happy is more important than anything else.- 4,152 replies
- cutty sark
- tehnodidakta
The super long strakes are usually kits. The bulkheads are usually too far apart for doing scale lengths on the decks and usually also the hulls. The 25 or so (varied by country and available wood) would be scale. Thus, it's your choice.
