mtaylor
Moderators
Everything posted by mtaylor
  1. I'm using Google Chrome for MSW and much of my other browsing. Too many issues with Firefox (which is about to come off my PC due to those "issues") and IE has it's share also. I'll not upgrade to Win10 in this lifetime but probably switch to Linux in the near future. Only thing holding me back is one small issue with an important application (to me anyway).
  2. Peter, If you don't have it, get a copy of "The Billy Ruffian" by David Cordingly. I think the photos of paintings alone will help you. Plus there's a "reconstructed" set of plans by Norman Swales on page 12. Unfortunately, I've not been able to find a hard copy of just plans alone.
  3. My jaw drops everytime I look in, Keith. Wonderful work and wonderful methods for problem solving.
  4. Hmm.... expansion slots? From what I've seen, those only show up on the low tooth count blades. Then again, I'm usually running the high tooth count "slitting" blades as I'm normally cutting thinner wood. One of the key things is to make the cut, shut down and check the blade temperature. I do very limited runs unless it's mass cutting for say, frame blanks. Even then, I didn't have heat build up.
  5. Hello Martin, Welcome to MSW. The best way to get help and improve skills is to open a build log. You'll get help and encouragement.
  6. Well, I hope they had proper beverages and food at the party, Dave. Nice work on the bowsprit.
  7. Short answer "yes" but you MUST use the Micromark adapter. Note that Hobbymill used these (Thurston) on their Byrne's saw: http://www.thurstonmfg.com/cut-off-saws.html with the 1/2" hole. Have look here to link to Jeff's article on using the Thurston blades with the Byrne's saw (or any comparable saw):
  8. She's coming together, Sam... Now if we just figure out a way for you to have a few days off....
  9. The "likes" themselves (like who liked it) mysteriously disappeared during the upgrade, or so it seems. The like (reputation) count didn't drop... so maybe it was a feature and not a bug.
  10. Excellent fix to the bit problem... I think the old saying about "necessity being the mother" applies here.
  11. Thanks Dave. I was just curious and thought I'd ask.
  12. What I'm led to believe is that you didn't loose the "like" count, just the indication that someone liked it. It appears to be working as it should but the "likes" on posts before this last update disappeared. In other works, the icon and names went but the number of likes didn't disappear. You can check this by looking at your "reputation".
  13. Just a question... when did the Constitution get anchor chains? I thought, and could be wrong, that she had cable for the anchors for much of her life.
  14. Maury, Look around second hand shops or even yard sales for a pressure cooker. The water boils at a higher temperature and being under pressure the steam would get forced into the wood a bit deeper than boiling. Sadly, I dropped my old pressure cooker and it was dinged to the point the lid wouldn't seal.
  15. Have a look at Patrick's latest. Now that's tiny. Also the ones that Nenad referenced..... Sweet work on the boat, Nenad. I couldn't do that if I tried.
  16. Bill in Idaho, I've heard of india ink being used (diluted) but I'm not sure if the alcohol is needed for diluting. If you try it, let us know.
  17. Hard work in the attic but well worth the effort to keep the weather out. The jolly boat is looking great.
  18. You can also make your own black glue and have the shade the color you want from pitch black to light gray... get some pigment form the art store and mix that in with the glue.
  19. Well.. I'm hoping to get things moving faster this week as it'll be too darn hot to even go outside (100-115 F) for the highs and in the low to mid 70's F at night.
  20. Dave, I think most of us go through that maze of emotions. So.. you're right, you're not alone.
