Everything posted by mtaylor
Sweet... Congratulations, it's time to splice the main brace.
- 83 replies
- sloop of war
- sloop
Amazing stuff, Magnus. I looked over your Youtube posts and saw some stuff I've missed. You're modeling work is incredible.
No problem, Geoff. I didn't address your other question about their behavior. Best answer is "money is the root of all evil", so follow the money. And I believe this site is in the banned kit list with some other sites. We can't catch them all nor can we really post them as unless someone admits to having the plans from the pirates, our hands are tied as far as banning the build. We can only hope that our members are honest and want to support those who put in the hours to make a plan and that they would never knowingly buy a pirated plan, but I suspect that's not always the case.
Panart San Felipe 1:75 Updated Version Review
mtaylor replied to Salty Dog's topic in Wood ship model kits
Max, Part of the problem with castings is the same as with plastic models. The age of the molds and how many parts have been cast. Companies just don't like making new molds because of the cost. -
Mike, A couple more thoughts.... 1) Squirt some glue on a piece of waxed paper or aluminum (aluminium) foil. Use finger to apply. Spread all the way to the edges trying to make an even coating. Not too thick though which requires some trial and error. Scrap cut-off's are good for this testing. 2) I have two pieces of glass (not plexi as it bends) 12" X 12" X 1/4" (30.5mm X 30.5mm X 6mm) that I put the blanks between after applying the glue. I toss a couple of large books on top of the glass as weight and then go fiddle somewhere for about an hour or so.
- 943 replies
- hahn
- oliver cromwell
Nice work. For flags... there's also silkspan and good old printer paper. I'm partial to silkspan myself. Have you searched online? There's several companies that do miniature flags.
Mayflower by SawdustDave - Finished
mtaylor replied to SawdustDave's topic in - Build logs for subjects built 1751 - 1800
Joe, I don't know it the "new" Microlux has them, but the earlier model had dado washers which, if needed certain pre-set grooves, worked very well. -
7-1/4" diameter on the Microlux? I thought they were limited 3"? Just curious... put it on slow speed with the blade reversed and some very careful filing? Or maybe a lathe? I can't imagine doing it one tooth at a time. I salute you for your determination. -
Mike, A couple of things I've found... you really don't want a mirror finish for making the blanks. The 240 is about as fine a paper as I would go using wood glue. With the warping I had, I ended up having to redo 2 frames out of 60 because of it once I figured out what was happening. In my case, fresh bottle of glue.. a bit too damp. Left it open for about a day, mixed it up well, and it was ok. The wood blank strip wood... I had to resize the width on my original order using the table saw. One side was just too raw to use and it was too wide. It will need thicknessing before you cut and make the blanks. As I recall, my wood was 1/32" too thick so I ended up (after thicknessing) with 1/4" wide frames instead of 3/16". (I ordered a timbering kit knowing that the wood needed adjustment since there wasn't a timbering kiit for my plans.) However, the thickness varied over the length of the strip.... Perhaps sanding after glue up might not be a bad idea afterall. Same for the sheet wood... thickeness varied, etc. Hmm.. Consistent color is an issue. But on framing that's visible, I'm not sure how much of an issue it is as some of us like variable colors to show the join lines. I almost wish I was leaving my in frame.. I guess it depends on the builder. I will agree though that Hobbymill will spoil you.
- 943 replies
- hahn
- oliver cromwell
Thanks Gaetan for the instructions and also for the insight on O.Bello. I'll use him very carefully from here on. Interesting method.. much like what Ofencer and Jud said. I learn something new everyday here.
Ofencer, I knew they were different and have different purposes but was trying to show others who might not know. Yes his website is a great one and he a great modeler which is why I'm use him for some references. Would you happen to know how the ovens were heated? I really am curious about this.
Pennsylvania by threebs - 1/72 scale
mtaylor replied to threebs's topic in - Build logs for subjects built 1801 - 1850
There's a ton of ship's boats being built.... have a look at Blue Ensign's Pegasus and Grant's (gjdale) Victory in the kit area (they scratched the ship's boats. There's others, but that's the two I'm remembering at this moment. -
Batavia by *Hans* - FINISHED
mtaylor replied to *Hans*'s topic in - Build logs for subjects built 1501 - 1750
Beautiful work, Hans. What "limitations"..?? I see great craftsmanship.
