Everything posted by mtaylor
Good question.. I think it's functionality. With split ports, the guns were left run out and the lids sealed around them. With single lids, the gun had to be pulled back in, the barrel raised and the whole thing lashed against the side of the ship. It took more space. Plus, if there was a need, it took some doing to unship it and make it ready, whereas with the split lid, pop open the lids, remove the tampion and you're in business. In 1798, the one piece lids were very common and it was also a "country" type of thing. The French frigates of middle to late 1700's didn't (for the most part though some did) have any lids permanently installed. The only time a lid was used was in heavy seas.
- 116 replies
- constellation
- artesania latina
yep.... had the wrong glasses on. That's my excuse and I'm sticking with it.
- 1,319 replies
- caldercraft
- Victory
Nice buckets, Kevin, although I think the ER crest is a tad large.
- 1,319 replies
- caldercraft
- Victory
Excellent plating, Sjors. Looks really super nice.
- 1,616 replies
- caldercraft
- agamemnon
HMS Victory by JPett - Corel - 1:98
mtaylor replied to JPett's topic in - Kit build logs for subjects built from 1751 - 1800
Good to have you back, JP. And it's great to see that you're back in the shipyard. -
The kit uses the one piece lids as that was what was fitted to the real thing back when the kit was designed. The ship in Baltimore is now fitted with the correct lids (two piece). Foxy, if you're not aware, the kit doesn't reflect the 1798 Constellation as no plans exist (or have been found, at least). The kit is based on the ship sitting in Baltimore which at the time the kit was designed was a fiction. Long story, much about it on the web.
- 116 replies
- constellation
- artesania latina
General Scroll Saw use
mtaylor replied to jdbradford's topic in Modeling tools and Workshop Equipment
Here's what I do to make a zero clearance insert... it's a piece of scrap plywood close to the thickness of the lip inside the hole. I level it and bring it up to the table level using tape on the bottom of the insert. I really need to make a new one for these particular blades but it works for the parts I'm cutting. The hole was originally drilled to take a larger pin-type blade. -
Mayflower by SawdustDave - Finished
mtaylor replied to SawdustDave's topic in - Build logs for subjects built 1751 - 1800
Nicely done on the windows and I like your fill in the slot method for the wires. -
Good to hear. I guess I fit into that category of "even a blind squirrel gets an acorn every once in awhile.".. I am happy that this worked out for you.
Sam, Buy two sets... you'll discover the pain and angst in the machining.
Sam, Go look at your local hobby shop. Find a pair and rework the tips.
Ah.. masterful work from the master... I bow to your excellence in planking. Ok.. seriously, that is one fine planking job you're doing. Great choice on wood color. You got me smiling.
- 2,191 replies
- confederacy
- Model Shipways
Hmm... interesting.. I searched and found two pages of references. Here's some links: http://modelshipworld.com/index.php/topic/2503-uss-constitution-model-shipways-vs-mamoli/ http://modelshipworld.com/index.php/topic/3694-uss-constitution-which-one-moved-by-moderator/ http://modelshipworld.com/index.php/topic/7344-uss-constitution-vs-uss-constitution-model-shipways-vs-bluejacket/
I'm moving this to the Wooden Model Kit Questions and Answers area. I would suggest a quick search through that forum might give you a starting place.
Denis, Superb work and that rigging is wonderful. I recall what I thought was a lot of rigging on Wasa, but nothing like what your SoS has.
- 555 replies
- sovereign of the seas
- mantua
Amati New Revenge kit- What scale will it be?
mtaylor replied to bear's topic in Wood ship model kits
Bear, Have a look here: http://modelshipworld.com/index.php/topic/985-amati-and-chris-watton/ The Revenge is discussed on and off throughout the topic but particularly the last several pages. Chris is the designer, BTW.
