mtaylor
Moderators
Everything posted by mtaylor
  1. I've seen it. Try "compatibility mode" on your browser if using IE. There might also be some other issues going on as well.
  2. Matti, Looking better than ever. What Nigel said about a cover up is a good idea. I've done a similar thing and recommend it.
  3. Time to start giving hints, Kevin.
  4. Short answer... no. 1/4 scale is equal to 1:48 in that 1inch = 4 feet = 48 inches of the real thing.
  5. Jason, If you read through the logs, all kits have issues. Some with quality, some with amounts. Hang in there.
  6. Crow's feet before were good. They are now great. Well done, my friend.
  7. The red looks great. I guess you got the hang of the airbrush alright. Great going.
  8. Mile, Beautiful work. I'm looking forward to seeing more. Drazen, Thanks for posting these.
  9. You might try softening the brass as it work hardens when you work on it. Heat it red hot and let it cool.
  10. I've not seen that method. There was a builder on MSW 1.0 and I think did a bit here on 2.0 who was building a destroyer or cruiser using printing plates, which are thin metal. I'm not finding it... so I'm not sure he did carry it over.
  11. I'll join the chorus. That is beautiful work. Very well done, sir. Pop a few buttons and be proud of it.
  12. I've used spray mount (3M product) but it doesn't give you a whole lot of time to fix it. If it's that brittle, rubber cement might work. Put it on the mounting surface and then put the plan down on it. The problem is, any adhesive will probably grab pretty quickly. Have you tried contacting Model Expo and see if they have the old ones available?
  13. Bob, If you're using IE 11, roll back to IE 10. For some bizarre reason, IE 11 and the forum software are incompatible at this point.
  14. Hi Jason, I used basswood for the galleries (from local hobby/craft shop). My references were pictures of the actual ship and then kind of winged it from there. I cut out the top and bottoms as mirror images (port to starboard) and then fashioned them together. A bit fiddly but it was fun and very satisfying when they were done. Don't use balsa as it's too flimsy and easily damaged. The only time I use it is for prototyping. I used it on the galleries to get the shapes right before cutting the basswood.
  15. Sjors the master... planking, ratlines, and now crow's feet!!!!
  16. Guys, There was a glitch in the system that has since been addressed: http://modelshipworld.com/index.php?/topic/6021-server-maintenance-scheduled/ Unfortunately, the lost photos will need to be re-uploaded.
  17. Yep, the quarter galleries are crap. As I see it you can clean up the brass (I don't recall them being solid brass but white metal and bronze plating) and paint them. Or scratch build new ones. The ones in the kit are about half as long as what's on the real thing. I scratched the ones for my Constellation and they weren't all that difficult to make.
  18. Al, Have look here at Jeff's Hobbymill page on how he uses the Byrne's Saw: http://www.hobbymillusa.com/byrnes-saw-operation.php Lots of good info on blades, etc.
