Posts posted by Kevin
good evening everyone
thank you for comments and like, and the ongoing conversation about loss of life and survivors
having built up the 2nd set of racks i then had to work out how they are fitted, they appear to sit on top of two small cabins, of which i presently dont know their purpose, but they have doors, so yet again when i find out, i will let you know
7 hours ago, Roger Pellett said:
Kevin,
First of all, your model is beautiful and your doing a great job turning Titanic into Britannic.
I have one quibble! Like Titanic, I assume that Britannic’s fourth stack was a dummy. If so, would the dummy stack still have the relief valve piping running up its forward side?
Roger
it appears that all four stacks are fairly identical with the exception of number 3 which has a lot extra pipework
5 hours ago, Roger Pellett said:
Kevin,
Roger
good question, i will check, however Trumpetr and KAMK1 add detail to that stack
- mtaylor, Old Collingwood and Canute
3
- Ian_Grant, Canute, Old Collingwood and 1 other
4
good evening, everyone
Thank you for comments and likes
been a busy couple of weeks, and i have not been doing as much on the forums as normal, like many others, we have been making life easier for ourselves and finding ways to keep ourselves warm but at the same time not restrict what we do
we made the decision that during the day if possible, we would both work from my mancave, keeping that warm and comfortable would mean not having to keep the temperature up in other rooms, that has worked very well so far, however the mild weather here in the SW has helped a lot
2nd set of boat racks has been made up today, i ran out of 1mm straight brass rod and substituted it for .8 wire, which is ok but seams a lot flimsier, getting it straight was harder than thought, but once painted and in its place, it should be ok
- Prowler901, DelF, yvesvidal and 12 others
15
2 hours ago, Ian_Grant said:
Impressive work with the i-beams and brass! But tell me (maybe I missed this earlier in your log?) why did they pile the lifeboats up like this? And how would they sway them out if needed? Thanks.
On my tablet at present, britannic was a much modded Titanic and to allow for the right amount of lifeboats 8 sets of massive davits were to be fitted, the war got in the way, and she became a hospital ship, 5 sets were still only fitted at the time she was sunk by a mine, will post a photo later
As a post war liner it was intended for more of the racks to be fitted, and none down the sides
- Old Collingwood, Ian_Grant, Canute and 1 other
4
Good evening everyone
thank you so much for comments and likes
as @realworkingsailor suggested i went and ordered some more suitable I frame (3 different sizes) and today made another attempt at the after Boat rack (Evergreen 272 and 1mm brass wire, i am real pleasd with the result
whilst waiting for the strips i also did other bits like detailing the after stack
11 minutes ago, realworkingsailor said:
Hi Kev! Looks great. I had to look online, but yeah, that looks basically like how they were stowed. Have you thought of sourcing some Evergreen “I” beam or “C” channel?
If you can find a small enough size, it might give you that fine profile of the racks. Going by this photo here:
Otherwise, looks great!
Andy
i may have to Andy as it dont look right
- king derelict, mtaylor, Canute and 2 others
5
thank you for comments and likes
After lifeboat rack
well i am having to use the grey matter now, and possibly failing miserably
without any plans, only a walkthrough i am having to interpret what i see, (not necessarily what there is to see, i have taken as few shots of the programme, and the 7 boats on each rack seem to be on at least 4 levels, mine are on three (please dont tell anyone)
the racks are still slightly oversized, but too fragile to make them in scale, this has taken me two days and about 7 different versions, but for now they will do, if however the next set is better then i will come back to this for the redo
shots from the walkthrough
first failed version
version 8 i think
23 hours ago, popeye the sailor said:
she's coming along splendidly Kevin..........some very nice work!
Thank you
are you ready for another update?
- Canute, mtaylor and Old Collingwood
3
On 10/22/2022 at 7:30 PM, Knocklouder said:
Didn't take me long to find one. Asked the first Mate 👎 ahem NO no no. Finish what you have lol 😆 😂. So I can get one as soon as I finish what I have . Bet they will be sold out by then, but it is on the list. Back to planking lol
if i listened to the Admiral, i would have by now far more finished, and less uncompleted kits
coming on very nicely, what wood glue are you using, as it could be wiped away before it dries
- mtaylor, Dave_E and Keith Black
3
3 hours ago, Old Collingwood said:
Looving your updates Kevin - really nice work, so much fine detail my friend.
OC.
Thank you OC
- mtaylor, Old Collingwood, Canute and 1 other
4
its nice to get back into the swing of things, and so I have another update
pretty well everything on the after deck is scratched, but i did take the two lifeboats of the kit as i need to purchase or obtain more
the supports for the after steering positions is 2mm evergreen rod, other plastic mouldings are available, the white box on the stern is the morgue still very much wip
its been a strange couple of weeks, with real life getting in the way, only doing a bit here and there, but it all kind of fell into place today, here she is as off tonight
after welldeck made stronger
upper structures glued to the hull and wiring extended to light then
quite a lot of work is required aft, extra cabins scratched for use by the medical staff
after plank sheet on, primer used to stop light bleeding
waterways, metal work and railings
after raised deck with also raises the after steering position
Brilliant, Christmas gets closer every day
- mtaylor, thibaultron, hollowneck and 2 others
5
after a couple of days in the forward well deck i have gone up to the funnel deck, this is the section i added the play room to several weeks ago, windows and doors added.it looks ok
the KA MK1 upgrade set adds many pumps and vents to the model, but the Britannic is very different to where they are situated, creating a lot of head scratching, so i am putting everything in the right place as if it was Titanic and then sort it out from there
the kit
play room added
with windows and doors
good morning, everyone
thank you so very much for comments and likes
day ? forward well deck
i made the decision to leave the forecastle for now as there was the risk of something being damaged, the railings are quite fragile
this is how the forward well deck looks as off last night
i still have to place vents, bollards, ladders, and possibly change the steam winches on top of the raised hatchway from black to white
HMHS Britannic by Kevin - Trumpeter - 1/200 - PLASTIC - from Titanic kit - Started September 2022
Had they been in the North Atlantic, they might not have hit a mine
