Posts posted by Kevin
hope you are feeling better this evening
the diorama is looking fantastic
- yvesvidal, thibaultron, mtaylor and 6 others
9
36 minutes ago, amateur said:
Dutch quality engine
Don’t think SD14 ever had one of these (the info on the engine-model suggests it is early 1960-ies, the ship is eraly 70-ies.)
However, it is rather basic card-model, so it should scale down nicely, and it sure looks like a ships Diesel.
Jan
if i was able to find a correct engine i would try to obtain one,
3 minutes ago, amateur said:
Is the engine part of the kit, or is the kit "only" the steel hull and superstructures?
Jan
Good evening Jan
just the hull, framework and superstructure
no prop, anchors or internal detail
i do have some links for a few compressors, but US supplied and costly
i have a engine but needs to be rescaled down to 1/70
- GrandpaPhil, mtaylor, yvesvidal and 4 others
7
good evening everyone
thank you for comments and likes
day 41 engine room levels
as the port side will be fully enclosed i started putting in the engine room levels for that side
everything seams to be lining up so far
put some paint down as well today green and white for machinery spaces, grey and grey with white box girders and deck heads for the holds
i had some decent outside photos of the engine room until i realised i had put the i had put the flat level in the wrong position,
oh and the boi wanted a mention
lol couple of the better photos from today with the engine room level in the wrong position
just love what you are doing on this subject
- mtaylor, Edwardkenway, Canute and 3 others
6
Good evening everyone
day 37 stern build up continues, and a wheelie bin
3 days since my last post, and not much to show for it, life got in the way
the stern build up is now mainly complete, i just want to add some paint to the hard to get to places before the frames go in, i will do that next to prevent any damage occuring
the white painted section is the steering gear flat, it will get a green deck before the longitudinals go back in
11 hours ago, Old Collingwood said:
Amazing work Kevin kind of on the edge of my seat watching your amazing stages.
OC.
1 hour ago, hof00 said:Ditto!!
Cheers....HOF.
day 35 and not fell over it yet
21 hours ago, Jim Lad said:
With both ends done the middle should be quite simple, Kevin!
John
i hope so
- mtaylor, Canute, thibaultron and 1 other
4
day 34 box girders and crocodile clips
the after peak has been fitted and stands up quite well on its own, however the more support i can give it the safer it is
the box girders are now starting to line it all up, no glue has been used since the last post
i have no intention of passing the forward engine room bulkhead for a while with intentions of staying with the after part of the build
5 hours ago, GrandpaPhil said:
If you have a photocopier, you should be able to resize that engine kit relatively easily.
Just figure out the scaling difference and do a manual scaling.
That’s how I rescaled everything for my Prince de Neufchatel and Hannah builds.
For such a small scale, I’d use really thin card or regular paper when rescaling though.
yes
i found a rescaling chart the other day, i hope to try it out within the next few days
that turned out very nice
lovely work, she is coming along very nice
- AJohnson, Egilman, Keith Black and 7 others
10
this build seams to have attracted some attention, so i had better make a decent job of it, and finish it this year
Day 32 engine room tween deck module and after peak
been doing some garden work the last couple of days but yesterday i varnished 12 sheets of card on both sides to allow more cutting out
personally i have found it easier to work away from the kit rather than on the build itself
37 minutes ago, Model Boat Mayhem said:
Gutted for you! 😖 ..... but Phoenix does sound a great option!
Have you started the new stern section as yet, Kevin?
Martin ~ Model Boat Mayhem
i have a new full build log started, the link is in my post signature
- Canute, mtaylor and Old Collingwood
3
7 hours ago, hof00 said:
Hi Chap,
for your model, over 2.13m in length, I trust that you have somewhere available to display when complete!!
Cheers.... HOF.
i may be extending this
Displaying large scale static boats - Shore Leave - Model Ship World™
- thibaultron, Old Collingwood, hof00 and 2 others
5
overall the kit is about 7 feet
the engine room is at tank tops approx 20 cm long reducing to 21 as it goes aft 1st levle of the engine room is 7cm then 11cm with top deck at 16cm
3 hours ago, realworkingsailor said:
Haha! Easy big guy!
Found this intriguing offering:
http://www.dhsdiecast.com/mobile/Marine-Engine-Load/productinfo/IMC33-0182/
It’s in 1:50 scale.
Otherwise, Norscot offers a bunch of CAT engine models at larger scales (1:35, 1:12) that may also work as a main engine, with a little tweaking and a repaint. Not the cheapest, I’m afraid, but maybe workable.
Andy
Andy i have an engine, rong scale though, those bits you linked to me i will see if i can find a supplier this side of the pond
16 hours ago, realworkingsailor said:
Looking nice! Will you be detailing the engine room? I had a couple of thoughts thought to help you get started:
https://www.walthers.com/emd-567-prime-mover-kit
https://www.walthers.com/refinery-piping-kit-509d60
https://www.walthers.com/piping-kit
The first is a 1:87 styrene kit for an engine and generator (you’d need three), and the other two are a collection of pipe works and other fittings (valves, unions etc) that you can assemble as needed.
If you feel like diving down that particular rabbit hole 😁
Andy
Edit:
Found this too:
https://www.walthers.com/tanker-truck-loading-rack-kit-7-x-3-1-2-x-3-3-16-quot-17-8-x-8-9-x-8-1cm
It has a bunch of pumps and other useful bits.
ooooooooooooooooooooooo I LOVE YOU @realworkingsailor strictly in a MSW sort of way
very nice
i was watching this the other day for a future project
USS ENGLAND (DE-635) by ccoyle - FINISHED - HMV - 1/250 - CARD
just say kev told me to buy it
