Posts posted by Kevin
good evening everyone
thank you everyone for comments and likes
Main mast shrouds upper and lower
been a great couple days, and just fell back into the build routine, having left a list of what I was doing and what was planned to do next save a lot of messing around
most of the back stays are also in just another 3 to do both side, then i will have to think about making up the mizzen
well the scratch for a non ship build has been scratched
a lot of members (well one) was hoping i would just continue with the SD14 but i do miss the wood and string, and as i will be purchasing the Vanguard Models HMS Indefatigable, i thought i would pick up where i left of last October/November time on the AV
so the shrouds for the main mast lower are now complete,, i then put in the main back stays before realising i need to do the upper shrouds on the main mast, what a great way to waste a couple of hours
good morning
i have this and the KA MK1 set, im not sure if i will ever build it though
there is so much after market stuff available now, to update and upgrade another of Trumpeters failings
i have a couple of links and will delete them if you wish me to do so
Model products | Trumpeter Titanic upgrades 1:200 - Woodys Model Works
yes i know its facebook but a whole wealth of info here
Titanic model China 3D prints 1/200 - 1/350 sales and show ONLY | Facebook
Trumpeter & Academy R.M.S Titanic model builders group | Facebook
- Tom E, Canute and Old Collingwood
3
thanks guys, was going to purchase a clock, but decided to leave that to modellers
- Old Collingwood, Egilman, Canute and 1 other
4
- ccoyle, Baker, popeye the sailor and 11 others
14
Thank you for comments and likes
will be glad to get this out of the way, the trailer still needs another sand down re-prime and top coat, at least my itch for wanting to do something different has been scratched
do i go back to the SD14 or back to wood and get the Amerigo Vespucci further along
- Canute, GrandpaPhil, yvesvidal and 7 others
10
thank you for comments and likes
still working on this project, But just wish i had taken a week off and done something away from the mancave, it would have saved me enough to pay the postage for @chris watton HMS Indefatigable, nothing wrong with the kit at all, i loved putting it together, and it is so well engineered, it is just the painting
anyway, lets at least finish something so here are a few outside shots taken tonight, dont look so bad in the distance, Oh and the wife loves it
as for yesterday please do not mention mum visits and her blocking the Macerator
@yvesvidal that is looking brilliant
4 hours ago, Canute said:
That trailer hitch is called a fifth wheel, over on this side of the pond, Kevin. It allows the tractor or cab you're building to haul a semi trailer. The semis have a pin on the bottom as the other part of the hitch.
Thank you Ken
ugears truck day 6
fantastic build, let down yet again by me painting, hairy stick with cheapo acrylic tube paints
wheels being made up prior to painting
Bonnet being built up approx 50 bits, a great interlocking system
same for the cab roof
Chassis
trailer hitch (or what ever its called
rebuilt the engine now free with out snagging
steering rack in and works
test fir of cab sides
varnish , spirit based gloss
pose for photo, nothing fitted
8 minutes ago, yvesvidal said:
If you manage to have this engine spin, you are a champion.
Yves
it is spinning with my fingers on the ends of the crank, but thats not the same as spinning from the transmission train lol
Truck day 3 cab, front chassis and engine
engine was a fun little project, everything has to be left a loose fit
even temp clamps are to allow the pistons to be fitted into the head with out falling out, they are then removed
front chassis build up, with moving steering rack
spare wheel on cab roof fitted and connected to the rubber bans tension unit
- hof00, Old Collingwood, Canute and 7 others
10
UGEARS’ journey began back in 2014 as a startup, in Kyiv, Ukraine. In 2015, UGEARS launched a hugely successful Kickstarter campaign, which yielded twenty times more than the original goal. UGEARS’ patented plywood joint design has proved to be popular among our models, as it makes them straightforward and simple to assemble, with no special tools required.
UGEARS is a Ukrainian company with its own manufacturing facilities found on the outskirts of Kyiv. All of the UGEARS range has had a considerable amount of time being designed, developed, and brought to life through the hard work of all us who work at UGEARS. Today, the UGEARS range is represented by 25 unique models, which are forever growing.
The UGEARS model kits have everything you need to assemble them. Our models are made from high quality, sustainably sourced wood – which are laser cut from plywood boards. All components are already cut, making them simple to detach from the boards. The instructions describe the construction of the model in a very detailed step-by-step process. They also come in full colour and in 10 different languages.UGEARS Models in United Kingdom
Good evening everyone
heavy truck day 2
something different from me as a break from the SD14
i know nothing about truck, and possibly less about ships, but this kit looked a nice kit to put together
its not hard to assemble but bits to get right are, it takes quite a time to get the gears to mesh properly, but so satisfying when it does work
each kit they produce get give a build time to put together (10 hours on this one) 3 difficulty level this being a 3 and number of parts (541) on this one
below the cab is all the running gear which gets its energy from the rubber bands which are tensioned via the spare wheel on the cab roof
lol i have already put in more than 10 hours but rather than leaving the plain wood my will be painted
lm going to enjoy building mine. counting down the days
17 minutes ago, hollowneck said:
True.
Finding ships plans in the "updated" site has become a struggle and there are a number of sad MSW members who've expressed frustration about this new reality- including myself.
However, I was searching "ships paintings" just today and had surprisingly good results - albeit a slog as their host server(s) are obviously over-burdened and it was very slow; worst case, the RMG site breaks as is the case this evening, at this very moment as I enter this post. The site currently is not functioning. I suspect the part of this problem is the massive amount of high-resolution content that the servers struggle to deliver to one's browser.
Perhaps there's a dreadful Summer heat wave in the U.K.? Or, perhaps they were hacked by an angry FSB? Hot, in' it?
Yeah im sure it is the British Summer heatwave we are suffering, 18 degs here yesterday LOL
- thibaultron, davyboy, hollowneck and 4 others
3
4
After reading naff comments about the release of the Yamato i just found this
1:200 WWII Japanese Navy Mogami Heavy Cruiser Model Kit – 3D-WILD
Phoenix by Kevin - Panart - 1/84 - Ex Amerigo Vespucci - restarted June 2020
i just wish i could decide if to go with sails or not
