Posts posted by Kevin
On 6/24/2022 at 12:46 AM, Roger Pellett said:
What do people find so fascinating about these ships? Compared to the Iowa’s they are rather ugly with their humpbacked sheer. Both were sunk by aircraft and neither distinguished itself in battle. And, they didn’t represent what many would consider to be a good cause.
My last comment would apply to Bismarck and Tripitz too.
Roger
at least we are getting choice of new retooled kits
On 6/24/2022 at 2:54 AM, Kelp said:Same with the Titanic. The Trumpeter model is beautiful, but I’m not sure if I’d like to look at a ship that had such a historic tragedy in my house every day. Maybe Trumpeter can come up with a large scale Queen Mary?
Don
now thats a great idea
- thibaultron, yvesvidal, mtaylor and 1 other
4
Good evening everyone
Day 96 hull plating forward Port side
the kit is wrong and it messed me up quite a bit
some of the hull plates are marked up incorrectly and the hull plates that overlap the bilge plates are also incorrectly identified, and the wrong size, so i had to remove some and make others to fit, I think it is right now
The dotted line on the F plates should be on E, and as a result i forgot to over lap the bilge plates, so ripped them out
and did them again
all the G plates have to be made taller as they then forgot about the overlap
tonight's experiment hiding the seam lines, paper tape and then varnished
the milky look is wet varnish
On 6/23/2022 at 4:16 AM, Old Collingwood said:
Kevin - my word my friend you are doing an Amazing job - of probably the most delicate medium you could work in, to me its looking genuine and realistic just like a ship would be.
OC.
thank you OC
3 hours ago, uncarina said:
Or a Japanese restaurant! 😄
Cheers, Tom
you mean the on that just sank lol
Hong Kong: Iconic floating Jumbo restaurant sinks - BBC News
oh no,
no i must not, buy this
I dont build 1/200, (turned round to take a photo of my stash to prove it , and fell over the 1/200 Titanic) lol
- JeffT, chris watton, scrubbyj427 and 6 others
3
6
8 hours ago, amateur said:
Impressive!
I know it is part of the fun, but it is a shame that alll thise frames and deck structures are disappearing behind the outer skin
Jan
morning Jan only on the port side, a lot of stbd will be left opened up, i, just finding a way around of doing it, without the upper deck collapsing under the weight
it wont be this much as the bow/stern will be skinned
good evening everyone
thank you for comments and likes, the wife is much better now
day 91 stbd side hull and bilge plates
even though the wife was ill, i still made sure a did a bit on the the build every day, maybe an hour tops, but back on it today
the kit is quite clever considering, its my modelling that lets it down, but even that seams to have been taken into account, and so far the plates have gone on ok
the sticky tape under the plates is my idea, and im happy i went down that road, i have ensured a better contact with the frames, and yes the tape has been glued as well so that the whole lot does not fall off
the bottom of the hull plates shows the position for the top of the relevant bilge plate
once i was happy the bilge plate was in the correct position i secured the hull plate over it
as we get to the pointy end smaller plates are laid under the sheerstrake, these take a bit of adjusting to sit properly i will tape over these butt joints later on
i just laid another coat of varnish over, hence looking a bit wrinkly
hi guys
been quiet in the boatyard the last week or so, the wife has been ill with a bad viral infection, although she is well on the road to sarcasm (a sign of being back to normal)
Very Nice indeed, he will look great looking over my shoulder whilst i build mine
- mtaylor, thibaultron, AJohnson and 3 others
6
Day 83 deck and hull plates
continuing with the stbd side i have put a few deck plates on
i am using tacky glue which is just a thick PVA and i am finding it was dropping between the transverse beams, so i changed the way i am doing it by putting a brown tape over the beams with ca glue and then pva on top of them to put the plates on, it seams to be going down ok
update
the plates that were dropping slightly between the beams has now sorted itself out now its dry
the hull plates are just tacked on, as the bilge plates are still to be found, cut out and put on
loving this build
- GrandpaPhil, AJohnson, mikegr and 11 others
14
- GrandpaPhil, yvesvidal, mikegr and 7 others
10
3 minutes ago, Veszett Roka said:
Kev,
how rigid is the structure now? I guess it is incredibly stiff, i mean much more than we think. And the ship's side yet to install, which give the full structural strength in reality... I think your model has to avoid of bend but nothing else, although i'm a computer engineer and not a structural one so it is my rough estimation.
the port side is quite secure now, i was going to leave a lot of the stbd side open (cutaway) but i may Have to put the frames in, to get the hull plates lined up, just to remove a lot of it, its just another of my idea's / intention, but not fully thought it through lol
8 minutes ago, chris watton said:
Your patience must be boundless!
lol it gets tested occasionally,
- chris watton, mtaylor, thibaultron and 2 others
5
day 81 forepeak upper start of stbd side frames
lots done in last couple of days,
forepeak upper module made up quite a nice little project, putting into position might be a different story
all the top deck transverse frames are now in place, and with a slight adjustment they will sit flush
she was tired and needed to have a sleep on her side
spent 3 hours this morning removing 170 plus frames, did that before taking the boi out for walkies at 0700
so the top of that ist lime strip is flush with the top of the lower gunport sill, thats clever
great update thank you
1 minute ago, Dion Dunn said:
That SD 14 would probably be the end of me too. That is ambitious!
about 1/2 way through now, hopefully before @chris watton can release the 1/64 Indy
great start, I will follow your progress
1 hour ago, Old Collingwood said:not for me @Old Collingwood, i will have satisfied my card urge after my present SD14 build, back to wood after this
- thibaultron, Dion Dunn, Canute and 2 others
5
SD 14 by Kevin - Marcle Models - 1/70 - CARD - Full build March 2022
Posted · Edited by Kevin
day 97 pointy end 99% complete
well that wasnt to bad in the end, after all its just card and easy enough to make bits that fit, even the Hawse holes lined up
