AON
Posts posted by AON
  1. The planking of the orlop deck was flush also. The short planks were set into a rabbit or notch and they were lifted out to gain access to the hold.
    The only areas where the long deck planks were above the beams and fastened normally like other decks were those areas with permenant cabins or walled storage areas.
    The grating was to allow air circulation and minimal light into the hold.
  2. I had completed making all the Orlop deck gratings (image below). From what I could find they ran along both sides of the hull , full length, and this was called the carpenter's walk. There was also a run along the bow from port to larboard (starboard) and three central gratings.  The topside of all were flush with the top of the beams.
    The first task was to lightly sand the top of the grating battens to be flush with the grating ledges as mine stood a bit proud. I set my sandpaper down onto the small repurposed pastry marble slab with some double sided tape to keep it secure and had at it (image below).
    Installing the gratings was, at first, an overwhelming challenge. The grating ledges were to be set into notches cut into the deck beams and carlings. Aligning these notches properly was impossible, and occasionally splitting the beam corners off unavoidable. To alleviate this, I simply cut (chiselled and scraped) the corner edges off of the beams and carlings that the grating ledges were to rest on, and then I sanded the underside corners of the grating ledges that were to rest on those beams and carlings (image above). Applied a little dab of white PVA glue and plopped them into place. When looking down at it you cannot tell the complete beam corner is gone, plus it will be deep enough below other decks that seeing anything will draw attention away from such a small detail.
    In the image above I only have the three central gratings installed.
    I did not install the floor, lower futtock or second futtock riders. The second futtock riders pass through the Orlop deck and up to the underside of the Gundeck clamps. In doing so, these run alongside the deck beams and pass through the gratings in those areas. That is why some beams haven't knees in between bracing them. When installing those gratings I notched them out to allow the passage of the riders. I have no intention of adding the riders... they won't be seen or missed.
    Once all the gratings are in I will install the Orlop standard knees above the floor beams. Then I move up to the Gundeck.
    I am further along than these photos suggest but still will need a couple of nice days to finish them off. Yes, I am back outside working on the ship, so nice weather is a must. Yesterday was rainy, today is a bit cruddy, and the next few are forecasted to be wet!
  3. On 4/29/2024 at 12:32 PM, Glenn-UK said:
    Next I added the thread between the thimbles, not sure what this rigging is called.
    We would secure with a half hitch or two between tackle (two blocks or even thimbles) and may complete by wrapping the standing end around further and finish with another half hitch to hold it there, or alternatively simply coil the remainder of the standing end of the line and place it out of the way.
  4. It's been a month of many things. Spring has sprung, grass cutting, readying the patio, preparing the flower and vegetable gardens for later next month.
    All the orlop deck stairways are installed.
    Made some of the standard knees but they are not installed as yet.
    I've got 12 of 23 gratings sets made.
    I won't be posting anything until I've got them all assembled and installed.
  5. First let me say I haven't done a miniature eye splice (yet) and I am impressed with anyone that manages it so well.
    With full size rope, I find that gripping it either side of where the eye splice will be, twisting to unravel the strands and pushing both hands together will open the strands to get a spike or fid into and hold it. I imagine with small scale rope (1:64) the same will likely be true, the needle being your fid or spike, though a third hand might be useful. This might make it easier to make sure you don't pass a strand through a strand.
    When the splice is done I would put it on the floor, step on it with my shoe, and roll it back an forth under my body weight to tighten it up.  I imagine rolling the scaled down version between a pinched thumb and finger would do the same thing.
    One day I will have to try this all for myself.
