Nils -- I have that Proxxon sander and love it.  It works like a random orbital sander, and with those triangular sanding sheets, it can reach into tight areas.  It does put out a lot of dust, but that's an indication of how much wood it's taking off.
Your work is exemplary.
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
Martin
Many thanks Martin,
for the Proxon Hand-Band-sander I had this one in mind (maybe something for christmas ?)
That triangular sander was once a special offer by one of our crafter markets
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Many thanks Peter,
appreciate your good advice, I´ll see if my local Obi-market has the product on stock.
I used to apply two-component polyester filler before, but that has too short working time and cures out very hard, so that the sanding afterwards is creating finest "powder" all over the room.
Today I completed the stand-plate (for three brass pedestals not finished yet), and stained it cherry wood color, same fashion as for the other ships and their glass cases baseplates. Still need to put some dull silk surface varnish on it
Nils
Current builds
-Lightship Elbe 1
Completed
Hello Nils,
I have not been on the forum for a while and now I discover You have started a beautifull build of a beautifull ship. I am looking forward to see more updates.
Regards, Kees
Thank you for dropping in and your words Kees,
It still will take me some time to get the hull-planking completed and the fairing of the rather thin outer Skin afterwards...
Nils
Current builds
-Lightship Elbe 1
Completed
Little update....
the last plank for the hull  was put on today, and the outside skin first faired with a viratory sander because due to the accumulated overload of the postworkers strike I still did`nt get that ordered spokeshave...
Nils
next, is to put on the bow post, straight stem and around the bend to the keel in bow area. I think I`ll take it off the "slip-way" then and plank the upper stern bulwark area vertically
Current builds
-Lightship Elbe 1
Completed
hull is looking nice Nils..........looks really smooth ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks Denis,
yes, I did the fairing outside under the car port, was a strong wind, that blew away the dust.
Am quite pleased with my triangle vibratory sander, in appr 2 hours the sanding was done. Some of the few pits and scars in the Planks will be treated with filler
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you for dropping in Christian,
and for your comment, you`re always welcome...
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 10
bow post and vertical stern planking put on...
Nils
the upper portion of the stern rounding will be horizontal planking
The upper propshaft housings still need to be planked, and the whole stern area requires fairing and blending for smooth transitions afterwards
the bow post (beech wood) where the plates are riveted to later on, gives the nostalgic touch to the rather sharp bow
its time to take the hull off the board now....
Current builds
-Lightship Elbe 1
Completed
hi nils
looking good! very sharp lines looks like atrue thoroughbred.waiting with bated breath for the start of the metal plating.
will you be using aluminium litho plates ? i know its quite a common building material for some a our "grey" warship modelling colleagues.
following with great anticipation.
cheers....mick
Many thanks Patrick and Mick,
and all the "like this" button activators...
Patrick,
Thanks for your appreciation, I took her off the board this afternoon and was delighted of the work so far, a straight symetric and light hull like it should be. All the overstanding frame hights will be removed (cut off) and the upper deck stringers put on. The slot places are integrated alrteady when I cut the frames
I am including some pics of this milestone moment....
Mick,
Thanks for your words ,..
For plating I shall use self-adhesive aluminium foil stripes which will be ponced from the rear side to resemble the riveting
Before the plating comes on, there is still some filler application work to be done, and several semi-round rails must be attached to the ouside hull skin.
removed from the board and put on the upper end-cap plank 180° around the stern.
Stb aft view...
stb front view
view into the aft ship hull. The outcuts for the deck stringers can be seen here
the "deck-beam" upper lnes are pre cut, so only the outer sides of the frames need to be cut. In this way the decks will have a positive curvature in width direction
one of the three lock-nut devices for the stand`s pedestal-spindles (through the keel and anchored in the "backbone" )
removing some old hardened glue drops out of the hull
Current builds
-Lightship Elbe 1
Completed
Very Nice Nils, Beautiful Hull, She is coming together and looking good
Best Regards,
Pete
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
Thank you so much for your Kind words
Pete - Bob - John - Lee-
and all the "likes"....
Pete,
It all requires the time it takes, and many ideas for the continuing sequences come as I do the progress
Bob,
thanks for your appreciation, I`m glad you like it. I Need quite some space in hight for fitting on those "golden" ornaments to the round Stern transom, and for putting adequate portholes just under the aft deck-Counter, so I might need to increase the deckbeam hight on the aft-ship a bit
John,
trust the hull will be the less difficult part of this build. For all the superstructure I have`nt made any scetches or plans yet, will probably do them to suit the build sequences as they come
Lee,
Thanks for your words Lee, I think it may be wise to connect the upper decklines to the sides first, in order to get a better looking transition for the plating Job and when integrating the rails.....
Nils
Current builds
-Lightship Elbe 1
Completed
Great job on the hull Nils, and congratulations on reaching the milestone of removing her from the board.
Thank you very much Martin and Grant,
Martin,
tho òl deckhand is enjoying every day of his pensioneer`s life
Grant,
thanks Grant, that`s a good Feeling to hold the hull free in Hand turn it around, and observe it from all sides....
it`s so great knowing that fellow modelers from all corners of the world find interest in what I am doing. it gives me very much motivation. Thanks so much for your appreciations....
Nils
Current builds
-Lightship Elbe 1
Completed
congrats for the milestone of getting her off the board!   the hull looks very nice...will enjoy seeing the progress you make on this fine vessel  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks very much Denis,
I`m just searching the web  / Ebay in order to find  suitable hollow rivets from which I intend to make the appr. 400 brass hull portholes from. Think I`ve just found something this afternoon, We`ll see....
Nils
Current builds
-Lightship Elbe 1
Completed
Hey Crackers !,
I`m very much flattered :) with such fine comment of yours,
stay tuned and enjoy....
Nils
Current builds
-Lightship Elbe 1
Completed
Many thanks Mark,
appreciate your tip for portholes Simulation, that is actualy the solution I`m going after by using hollow rivets DIN 7340 Form "B"
I also found an in diameter suitable solid Nylon cable (like used for a rotating grass cutter) to slice / cut the glassing inlays from. Hope ist works well....
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 11
some progress on building the hull....
Nils
this is no convertion to a viking longboat, but temporary protection to the prolonged bowpost until the upper bow bulwark is ready for attaching
my wife asks me this morning, if I`m sure the ship is not much too narrow...
All the overstanding frame hights have been cut off
between the second and the third rail (stern) I need enough place for attaching the decoration and the name, and homeport.
For providing adequate space for the portholes around the poop and perhaps some "eyebrows" over the portholes, I had to increase the hight of this (round the stern) plank accordingly as well as a good transition of the sheer in foreward direction
these are preliminary deck-stringers, for dry fit. There will be a pit right down to the lower deck, just behind the later forecastle bulwark
Current builds
-Lightship Elbe 1
Completed
too bad you didn't ask around concerning those hole rivets
I found this box of 'em in the cellar a while ago.........there's a bunch of sizes - mixed.
I separated what I could stand.......it's the equivalent to the Chinese water torture :D  :D
I have plans for a Danmark down the road....I got more than enough,  if you need any  ;)  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
