Naval Cutter Cheerful by SawdustDave - 1806 - 1:48th scale
I will be building Chuck Passaro's "Cheerful" as a very special gift to my ENT surgeon (Dr. Harold Pillsbury) in appreciation for his outstanding efforts in my ongoing fight with a serious life threatening infection of my left ear.
I hope to be able to finish this and present it to him at the conclusion of my continued daily IV treatments as a complete surprise.
"Dr. P" is a very special man, going far beyond normal efforts in my case.... Calls me at home after hours during the week to check on me and encourage my wife.
At my last weekly appointment in his office, the man gave me a $250.00 pair of tiny alligator pliers because I had made a comment.... "What a neat rigging tool" they would be.
His staff knows about this plan but they have all been sworn to secrecy.
Edited by SawdustDave
Link to comment
Share on other sites
Opened up the plans only three days ago. I do recommend, for anyone who is thinking about building this beautiful "Scratch Build" project, the low cost of having Chuck laser cut the bulkheads for you is money well spent.
The photo here is with the bulkheads inserted as a dry fit....and I will tell you every single one of them slid in place like butter and the top surfaces aligned absolutely perfectly.
The keel pieces have been added and sealed with a single coat of wipe on poly...
Chuck recommends using boxwood for all of the exposed parts, but due to the expense and difficulty for me to get boxwood lumber, I am using basswood. There will be a slight difference in color and grain, but I will accept that under the circumstances.
Link to comment
Looking great Dave..... :)   You might also want to consider hard maple.  If you can mill it on your own it is readily available and very reasonably priced.  It will be much easier to obtain a better finish that closely matched the boxwood using it.  Even at Lowes or Home Depot.
Link to comment
You are so right about hard maple Chuck. Have used it quite a bit for small turnings and some deck fixtures. In fact, I'm quite sure I still have some in my lumber boneyard.
Thanks Frank.... Any time I'm working with the guidance of Chuck's well illustrated instructions, I feel very comfortable. I will always consider him my mentor. (Don't let that go to your head Mr. P)
Link to comment
After several hours of careful sanding, I managed to complete the fairing of the bulkheads and move on to installing the gun port sills.
First, seen here, using a temporary batten to mark the smooth alignment of the sills on both sides....
Then carefully cutting and fitting the sills and uprights according to the plan sheets with exactly 17/32nd openings.
Also note that all gun port sills have been faired perfectly flush with the fairing of the bulkheads.
Link to comment
Gotcha Master P..... Figured the final touch-up's could best be done once I begin planking. Although the thin batten was laying very nicely across the bulkheads, I fully expect to have to make a few tweeks, once I begin fitting the stiffer planking strips.
Those last three stern bulkheads are the most obvious.
Link to comment
The transom frames ready for the band saw. Using maple, they will be a little tough for the fairing process, but very strong. This appears to be a fun part....
And here's the result....
She's all faired and ready for planking....
I should add, what a pleasure it is to be, once again, working with a great set of plan sheets that can be trusted. A big relief from the SOS project where I have had to fight the plans every step of the way.
Link to comment
Sawdust, let me answer you question regarding alligator forceps.  I am an ENT surgeon and use them daily in my work in the office, the OR and the shipyard.  There is a tremendous quality difference between the $15 hobby quality alligators and the real McCoy.  However, a good, not great, pair of forceps will run you $150.  The difference is in the set of the jaws, the strength of the grip, the weight and the quality of the metal finish.  Is it worth it for our hobby?  No.  Alligators also come in scissors (Bellucci scissors).  These are wonderful for cutting the ends of rigging in those hard-to-reach spots.  Hope that helps.
Link to comment
You're right about the difference between the hobby alligator's and the much longer and stronger ones you ENT surgeon's use.
I am laying here right now, awaiting the good Dr. Pillsbury to come by and release me to go home after his second deep cleaning of the left mastoidal area. Guessing you have been there and done that as well Toni.
Link to comment
Alligators come in different lengths, depending on their intended uses.  I use the long ones in your photo more for nasal work and shorter ones for the ear.  There are even longer ones intended for neurosurgery.  Many surgical instruments can be adapted to our uses.  My OR team knows that if something isn't good enough for surgery, it might work fine for the ships and they give me first dibs before throwing them out.  Bits used in ear surgery typically are not allowed to be re-sterilized but work great for carving wood.
Link to comment
Very close to finishing the port side planking above the wale.... not too bad so far.
Before posting any further progress, I feel compelled to drop a few advanced explanation's.
As noted from the beginning, this project is being built in appreciation for a very special physician who has become a big part of my life.
Something you must understand about this man, along with about any other graduate from the University of North Carolina at Chapel Hill.... when you cut them open, they all bleed "Tarheel Blue". To the point of being very offensive to everyone else in the world....especially those from any other ACC school.
First.... he found my blog site with all my ship projects and has already asked me to do a commission build for him. Which I said I would certainly consider doing something for him once I finished the SOS.
Obviously, I do not intend to ever charge him for building him a ship. But, the main point here being, he loves the bamboo skin on my more recent ships.
Second.... This is primarily to prepare Chuck, I will be painting the hull below the wales that hideous Tarheel Blue! I know this will make you want to heave chunks Mr. P, but this is a request from his beloved staff members who are in on the project.
Also, I am using bamboo planks above the wales because he says he loves the bamboo.
So let the shock kinda settle in for a while before I force you to see any of this in future postings.
Finally the name.... The UNCENT Cutter - Pillsbury
He doesn't have a clue as to why I've now taken to calling him "Captain Cutter"
Link to comment
Having issued fair warning.... here is your first view of your beautiful Cheerful wearing bamboo clad.
One coat of wipe on poly....and a little more sanding to do.
I'll try to save you the pain of seeing the blue hull until the bamboo has time to wear off. hahahaha
Link to comment
Now, allow me to brag on Chuck's plan sheets and PDF instructions.
My fairing techniques have been pretty much "self developed" over the years. Not bad, but....
This time, I followed his method of fairing and marking the planking to a tee....and must say, this has to be the nearest to perfection I have ever achieved in having the run of each strake lay absolutely perfect to each bulkhead. No waves....no highs/lows....no fighting with alignment.
This is one kit I am absolutely enjoying.
Chuck.... Send check made out directly to Dave Bullock... You have my address.
Link to comment
George....I can't say enough about Chuck's influence on my love for building model ships. Go's back to the Syren project and then the Confederacy, which I have taken to four shows around the state and been honored with "Best in Show" each time. Last show in Fayetteville, there were two other really fine Confederacy's entered, but I think my fully rigged version must have a little more "WOW" going for it in the public eye.
The man is a master teacher in the way he writes his instructions.... As if he is sitting beside you with every cut.
BTW.... I hope to eventually manage to take the SOS to a level of "HOLY SH##!" hahahaha
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
