USCG Pequot (WARC-58) by Cap'n'Bob - 1:96 - Finished
Thanks Lawrence, I'll need all the luck I can get.  But if Patrick can do it on Majellan, . . .  Well I hope I can.
Bob
Hi Bob
Thanks for the vote of confidence! But trust me, you're gonna do a mighty fine job, without a doubt!
Cheers
Patrick
Link to comment
Share on other sites
Well here I am again.  I’ve been working on the railings for the upper deck.  I made them from .020” (.05mm) brass wire, 2” (50mm) scale.   You can see in the pictures the sheet of balsa I used to solder on.  Using a straight edge I scribed two grooves in the balsa to hold the long pieces parallel.  I cut the stanchions to .5” (12mm) and put them in a container with liquid flux.  I then wiped the long pieces with flux.  The solder was placed on the board and arranged so that the free end was in the air.  I would touch the soldering iron to the solder to pick up a small amount.  Then touch the joint until the solder flowed to both parts.  I found early on that I needed something to hold the stanchion while soldering, I cut a .020” slot in the end of an old tool for the job.  Now all I have to do is paint and mount them.  Oh, yes.  The new railings look so much better than those on the pilot house. I’ll have to redo those.
Bob
Current build:  SS_ Mariefred
Link to comment
Bob,
you`re doing a good job on the railings-soldering...
Are you going to stick the stanchion foot-ends through the deck, or into those white borderline surroundings ?
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Thanks Nils, Frank and Patrick.   The stanchion ends will be inside but touching the white curbing.
Bob
Link to comment
looking good bob.........you must have been reading my mind.........I did some railings this morning  ;)    nice shaping!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
There’s a ladder that goes from the pilot house down to the main deck.  I know that there are companies that make photo etched ladders but I don’t know which ones make good parts or how to order the one that I want.  Then I would have to wait for it and hope it is the right size when it gets here.  I’m just not up to that kind of stress.  So I made my own.  The photo I am following shows the ladder with ten treads.  Measuring the model makes the treads .090 inch.  So I sanded a 3/32 square strip down to .085 inch on one side.  To make the fixture I used a .005” brass sheet as a spacer and  glued the square strips between two supports.  The treads were cut from the .005” sheet and squeezed into the fixture.  The sides are 1/16” brass angle.  Sorry I didn’t get a picture of the ladder mounted in the fixture.  But here is a picture of the fixture and the a couple of the finished ladder.
Bob
Link to comment
Bob, the ladder looks perefect,
a fine positioning fixture and a super soldering job !!   :)
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Link to comment
Thanks Nils and Patrick,  I've always enjoyed problem solving and as you both know model building has a lot of, "Now how do I do that?"  When we come up with an Idea and it works . . . ah that's the joy fulfilled, and MSW lets us show it.
Thanks again
Bob
Link to comment
Bob, I agree with Carl.  You are too modest.  Your work is brilliant.
Link to comment
Thanks Carl and Mark.  If I were modest I wouldn't even show what I build.  The pictures are my way of bragging.
Bob
Edited by Cap'n'Bob
Link to comment
Bob,
Beautiful ladder! And interesting technique to get it all uniform. But I've got a couple of questions: I understand that the treads are slipped into the slots of the fixture, but how do you put the angled side pieces on where you can do the soldering? Also, is that a picture of your soldering gun, or is it a pen? Finally, the clean-up of excess solder in the angle of the side pieces must have taken some time?
Tom
Link to comment
What Carl said, Bob.   Just keep bragging away.
Link to comment
It seems that a lot of people have trouble with soldering.  Most people who are good at soldering have their own methods that they have used for a long time.  This is my method.  My main soldering iron is an old 50 watt Unger that I’ve had for 40 or 50 years.  The liquid flux is also so old the label is gone and I don’t remember what the brand is.  The solder is the smallest diameter that I can find and I don’t care if it is rosin core or not.  The problem most people have is using too much solder.  The solder I used for this ladder is .020” (.5mm) diameter.
This is the same ladder I did above but with more pictures.  First I painted the angles with flux and tinned the inside.  After placing the treads in the fixture I tinned the edges of the treads.  Then the angles were mounted on the fixture with one leg of the angle under the treads.  All the parts are then pushed tightly together.  Next I liberally painted everything again with flux.  Now all I had to do is heat the angle enough to melt the tinning solder that is already on the parts.  Using solder on the outside of the angle transfers the heat to the inside better.  In the final pictures you can see there is no buildup of solder that needs to be cleaned up.  The solder on the outside is easily filed or sanded off.
Well that’s the way I do it.  The main things to remember is the parts must be clean, use plenty of flux, the parts must touch, don’t use too much solder and practice until soldering becomes comfortable.
Bob
The next three pictures show the part with no cleanup.
Link to comment
I learned from my dad........I had forgotten all about tinning  ;)    very neat method and jig you have there.    pretty darn good copy of the one in the picture......supeer job  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Thanks Tom, my admiral says I should have been a teacher but I went into engineering instead.
Popeye, I forgot most of what my dad told me also.  Tinning isn't always necessary but there are times you can't do a nice job without it.
Bob
Link to comment
Well there you are! You understand about the left brain and the right brain? One side is artistic and verbal; the other side is math and science. According to your wife, you've got an abundance of one side and according to your accomplishments, you've got an abundance of the other side as well. Yah, I'm corny, but I love to look at talent!
Tom
Link to comment
I see it’s been a while since I’ve shown you the Pequot.  So here is where she is at present.  I’ve been mounting parts on the upper deck which is now complete except for 13 fire buckets which mount in a ring surrounding the stack.  The first picture is an attempt at a water level shot, looking up at the wheel house.  The gray thing on top is the 50mm gun which was always covered with a tarp.  She was only armed during the war and I am portraying her as she was in 1943.
Bob
Link to comment
Pequot is looking top at this stage Bob,
very nice progress and beautiful work, the boats look great !, now comes the remaining fitting out....
Are those the the vents you recently introduced by copper electoforming ?
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
awesome progress Bob!   very nicely done ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Link to comment
Thank you all for looking in and telling me that you like how the Pequot is coming along.
Nils, yes these are the electroformed vents I made.  Glad there weren't hundreds like you just made.
I'm glad you all like the details.  I always feel it is the detailing that makes the viewer say, "Wow".
Bob
Link to comment
Bob,
great ship....
I`m very pleased that those electroformed vents worked out so well. The technique. is very incouraging, and now its time to see the results, well done !
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
