Disclaimer This is all Pete's fault.
Because I already have too many builds on the go I thought why not another one. I know there are a few others here who merrily go about building a few boats/ships at the same time one of them shall remain nameless but we all know who it is.
Pete has already done enough waxing eloquently about the merits of the Herreshoff lineage of boat designs so there is no need for me to go into any great details here except to say that I completely agree with him on the elegance of the Herreshoff lines no matter what size he designed.
Build Part 1
Pete sent me a printed copy of the drawing he is using for his new boat it was already printed at 1 1/2 inch to the foot. (thanks Pete) I scanned it in order to trace it for developing some detailed model plans the lines plan is 50% and the body plans are 100%
I spent a lot of time studying the various images of the 14 on the net and was particularly drawn to the Port Hadlock WA Boat school photo stream
There are a lot of pictures of the 14 under construction and it is this version of the hull that I intend to model as far as the main structure of the hull. I have chosen this one because of the clarity of the construction methodology visible in the pictures.
Unfortunately there are no pictures that I have yet found of the beginning of the Port Hadlock boat which would have confirmed a few things about how they prepared the frames and if they used a set of mold forms with ribands to prepare the bent frames, but I suspect that is the method that was used.
I used corel draw this time instead of Autocad because I am more familiar with all the curve functions in corel. I used the line width function to shape the frames instead of drawing the outlines of them and this seems to be working well.
This hull will be a test of my skill at doing a proper planking job, I have learned so much since the first post on the Pilot Cutter (still planning on sailing her next summer) where I basically did not have a clue about what I was getting into and built that hull as if it were a strip built canoe. I have chosen 3/4 inch thick planks for the hull (3/32 inch) and wondered a while about what wood to use. I want to have the planks varnished and not painted (visions of Chucks planking job on his cutter  for the clarity and elegant execution)  as a goal but with a more reddish colour.
I remembered the redwood panels from the salvaged garage door and did a little re-sawing to get enough planks for the task.
stripped up to 3/32 x 9/16 (3/4 x 4 1/2)
Next I tried to bend some 5/32 square stock by all the different methods that I have read about on this forum and snapped most of them (what am I doing wrong?)
I remembered that I had a 5 foot by 5 foot sheet of 1mm birch aircraft ply so I cut some 3/16 strips up on the paper cutter, it worked very well surprisingly. I also printed and traced out one of the more challenging mould forms to add the frames to.
Next I used the wide throat jewelers saw to fret out the mould to use as a form for laminating the rib/frame the material is 1/4 inch Baltic birch ply.
The mold form was pinned to some cork covered homasote (at least that is what I think it is) and the 4 layers were laminated together.
In order to cancel out any discrepancy from side to side I laminated two of the same side, I will cut out the middle of the mold to help with the clamping of the planks.
This will now continue for the rest of the frames that will fit over the molds
Michael
I'm in also...
very interesting technique Michael,
laminated Frames (= high strength), ;)   I`m curious and tuned in for further Progress.. :rolleyes:..
Nils
Current builds
-Lightship Elbe 1
Completed
I checked in
It seems to be a school "how to make it perfect"
Nenad
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
Michael, I do accept full responsibility, You Know that I am in, I am glad that you chose to build one at this scale. It should be an amazing build
Best Regards,
Pete
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
I like the idea of laminated frames.  Fine start.
Bob
Current build:  SS_ Mariefred
Thanks for all the views and comments and likes.
Build Part 2
The laminating of the frames continues, if you ever get the chance to pick up one of these for cheap or even free which is how I got mine grab it, they are amazing paper cutters.
And as you can see they do a great job on thin aircraft ply as well.
alongside other seasonal tasks I am waiting about 3 -4 hours before pulling the frames off the form then leaving a full 24 hours before doing any sanding. I have two more stations to go the one at 9' and the one at 6'. Once all the frames are laminated I will set up and fret out the centre sections, I will need to do this out in the shop where it will be a little easier than at the desk.
The stations will then be set up on a board to receive the stern post keel, and stem elements.I will also carve a block once all the planking is done and fair it so as to make a mold for the lead keel.
If I don't get a chance to wish everyone a great Christmas holiday and any other forms that are celebrated at this time of the year.
Judy and Me wish you all Merry Christmas
Michael
Looks Great, Michael, Merry Christmas and Happy New Year to you as well
Best Regards,
Perte
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Thanks Pete, I have been thinking about the sail plan and thought that this rig  from DanO on the wooden boat forum is the one I would like to adopt, I read Dan's reason for the gaff rig and liked what he had to say. scroll to the bottom of the page to read the reason.
Michael
This is a great series of pictures on the construction of a full size hull and of pouring the lead keel which had an all to familiar ring to it. this relates to the boat in the previous post.
Michael
Based on the comments in the wooden boat article by Dan O I have drawn the new sail plan thus. the jpg is 50% PDF full size for model
sail plan.pdf
Michael
Hi Patrick, The other thing that I particularly like about the gaff rig is the lower Centre of effort of the rig.
I have tweaked it just a little, by lowering the gaff jaws and raising the peak this moves the CE just a little forward as well without changing the sail area by any significant amount.
sail plan 2.pdf
Michael
Druxey, the reason i raised it a little was because in reviewing the photo once more that Dan had posted on his blog I noticed that the gaff was pretty much the same angle as the forestay, I could split the difference and see how that looks because I tend to agree with you.
This is a better configuration I think
Michael
Edited by michael mott
Hi Michael, the Gaff rig looks good ( wooden boat forum, and your drawings ), It gives the Boat that 12 1/2 flair, I am partial to the Marconi rig, Are you planning on Sailing the Boat?
Besat Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Michael, I like the last drawing (#18).  Since the peak of the gaff is farther back than on the Marconi, you may have to move the mast forward to keep the centers aligned.
Bob
Hi Bob, Yes you are absolutely correct I did an overlay of the 12 1/2 original sail plan and you can see that it is forward and scaled up is not quite as large as the one I had put on.
sail plan 3.pdf
michael
Build part 3
I completed the first major task this morning all the frames are now laminated for the molds. the other frames will come after the planks are fixed.
I will do the final sanding after the molds are fretted out.
Michael
You're moving right along.  At this rate you'll have it finished by new years.
Bob
Thanks Bob and All the members who added likes
build part 4
I finished fretting out the molds this morning. I now have to sand the frames and fix the molds to a building board and add the transom, it will be mahogany.
Michael
Hi Michael, the Frames look great, you sure are moving at a fast pace
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Hi Michael
I agree with Bob and Pete. Boy, you're moving fast! Nonetheless, there's no mistaking the shapely lines of the hull coming through. Very nice.
I also love the way that your Bristol cutter makes a cameo appearance in the background. She must be itching to get into the water once finished
Cheers
Patrick
Thanks for the nice comments Pete and Patrick,
Build part 5
The building bard is a piece of 1x10 clear pine, I wanted to keep this simple The support pieces are 3/4 x 3/4 and just glued with a couple of small spots of glue to hold them in place without a lot of fuss. I did position them so that the stations aft of midships are set to the aft side of the line and the forward ones forward of the line. this will help when fairing the frames.
The transom is glued from three pieces of 3/16 x 1 5/16 mahogany I glued them the same way that I would a board for a cabinet. I planed the edge with a hand plane then rubbed the joints together with the glue and propped it up to dry. this method does not impart any stresses into the glued material.
The plywood molds were not perfectly flat and are glued to the support blocks with a couple of spots and clamped.
I will attach the transom to the stern-post once it is cut and shaped.
Michael
Looks fantastic Michael, Beautiful work, will you be making the Keel out of Lead?
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Nice setup of the frames and transom.  the planking should run easy.
Bob
looks great Michael,
ca`nt wait to see when you take the planked hull with the laminated frames off the build board...
presume that in the moment only those blue tapes are holding the frames to the "molding frames"...
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Bob thanks, Nils yes the blue tape is very temporary the frames still need to be finally sanded and cut to their finished lengths. Also the keel needs to be fitted before any planking goes on.
Thanks to all who pressed the like button.
Michael
