Hi All,
Well the Winnie is in dry dock, I've finished the Cazador for my grandson, things have
calmed down and now I'll start my build log for Chucks Syren Ship Model Company's
HM Cutter Cheerful 1806 in 1:48 scale. The model will also be fully rigged.
I plan on using a lot of Chucks available laser cut parts. Most of the wood used in the
model will be boxwood except for the deck which will be holly and the bulkheads which
are plywood.
I know there are plenty of great Cheerful’s being built here and anything I do won't be
different from those build. I've listed the build here as a scratch build but quite honestly
with Chuck's laser cut parts it's a lot like a kit.The plans and practicum are Chuck’s usual
splendid work. Easy to understand and very precise.
Here are the laser cut bulkheads.
The two halves of the bulkhead former weighted waiting for the glue to dry.
The keel attached.
All of the bulkheads added and drying.
Lots a sanding to do next to fair the bulkheads.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
I always enjoy watching your builds Rusty, so I'll pull up a chair for this one too. :)
Pulling up a chair also.
Jack
Current buildUS Constellation
Thanks all for stopping by and the likes.
Hi Bob, Grant, Ken and Jack. Always a pleasure to have you around.
Chuck working in the shop is always a great thing. I get carried away and forget to take pictures and post though.
Rusty
Thanks Eric. Oh I'll apologize to you right now then!
Ok next up I started fairing the hull. Lots of elbow grease needed here.
I mainly used 80 grit sand paper and course perma grit files. I then switched
to 100 grit sandpaper. Once I frame the port sills and fair them I’ll switch to
150 grit paper.
Edited by Rustyj
Rusty
You are always welcome Bob. :)
Rusty
Hi Ben,
I'm gonna know how you feel in a bit. I'll be packing in as much work/fun as I can over the next two months.
Then it's pack up the house, move, unpack and then build a new work shop just like you're doing.
So much fun, so little time. :blink:
Rusty
Oh it's a real long distance move Ben.
All of three miles away from my current house. At least I’ll save on fuel! :D
Same area just a different house. Oh and it has space for a 10'x20' workshop
in the basement. Gonna have to build it though. B)
Edited by Rustyj
Rusty
Ben, I'm glad to hear you're getting closer to having your shop completed. I'm lucky there's
no demo for me to contend with. The entire basement is unfinished. Half will be a rec room
and bathroom, 1/4 for my shop and the last 1/4 has the utilites and storage.
Rusty
Great to see you building again Rusty. I've had a great time building Cheerful and I'm sure that you will too. Please keep those photos coming.
Mike
Current build - Sloop Speedwell 1752 (POF)
Completed builds - 18 Century Longboat (POB) , HM Cutter Cheerful  1806 (POB), HMS Winchelsea 1764 (POB)
Thanks Mike, Your work, as Rafines and others, has been an inspiration. :)
Rusty
After the preliminary fairing of the hull I used batten strips to mark the gun port sills.
I pinned it to several bulkheads and used rubber cement on the bulkheads that were not
pinned. I was able to make some subtle adjustments to get what looked like a smooth run.
After marking the sill’s location I cut them out of boxwood. I choose to install them between
every bulk head for added stability for the final fairing.
Now it’s time for more for more sanding. Oh such fun. ;)
Rusty
Hi all,
Well all of the uprights have been added and the first round of sanding completed.
Adding the extra bracing worked well for me as I didn’t snap anything off……yet! :huh:
Though this is listed as a scratch build I will from time to time (read every chance I get)
use Chuck’s laser cut products. Purely for research purposes mind you.
Next I'll start framing the stern. One of many ah....cheats I will be doing. I ordered the
boxwood frames from Chuck and they are perfect.
Rusty
To start assembling the laser cut stern frames I first had to glue the two outer
frames for each side together. They were then placed in the corresponding slots
on the stern. Then three more frames were glued to these. In all 5 layers were
assembled on each side.
Here they are all glued and clamped to dry.
Once dry the laser char was removed. A reference line needed to be marked on
the frames. To do this I glued a piece of pencil lead to the end. Holding the strip
wood against the hull I traced the reference line. The wood will be removed so it
is close to the hull fairing.
Rusty
Thanks Mike, Deon and Bob and all the "likes". Much appreciated.
Bob I'm sure that's just one of many fun things awaiting me!
Rusty
Hi Rusty,
Just found you mate, mind if I jump aboard and follow, it's what I do best, ( follow that is ).
This I think will be a perfect build for me to follow for when I build my Armed Longboat, given a few variances.
Good luck with this one mate.
Be Good
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Hi Mobbsie,
You know that you are always welcome aboard!
This a really great build and I think you would love it! :)
Rusty
The remaining stern frames were glued into position and the sills and lintels
added for the stern ports. Then the start of the square was made with the
placement of a piece cut from some 1/32" sheet.
You also can see the preliminary fairing of the outboard edge of the stern frames.
Next up will be the start of the hull planking. I'm off to start cutting the strips of boxwood. :)
Rusty
