I have also added the central plansheer and am working forward with the forecastle plansheer and timberheads at the same time20190102_184344.thumb.jpg.321894a8c933286e5c8eaa9f2a588e62.jpg
Regards
Paul
The clerk of the cheque's yacht of sheerness
Current build HMS Sirius (1797) 1:48 scratch POF from NMM plans
HMS Winchelsea by chuck 1:48
Cutter cheerful by chuck 1:48
Previous builds-
Elidir - Thames steam barge
Cutty Sark-Billings boats
Wasa - billings boats
Among others 😁
Head timbers coming together, sorry about the crappy photos
Previous builds-
Among others 😁
And deconstruction of starboard side begins
Previous builds-
Among others 😁
Its three degrees in the garage and Diana Ross is nowhere to be seen
Could be the last photos/work for a while until it warms up a bit
Regards
Paul
Previous builds-
Among others 😁
Ah a cosy temp for a January day in Canada, time to get the shorts out.😀
I can sympathize when I used to heat my old shop with wood it was brutal in the winter. I am happy now that I have proper heat.
Tell me why the deconstruction on the starboard side? apologies if I missed an earlier explanation.
Michael
Hi Michael, no problem thanks for looking in, I had major problems on the  starboard with the windows and fitting the gallery, After some help from Druxey, Ed and others at the time I managed to fix it, I had made the top and bottom shelves the same size but not taken into account the taffrell
I have had to trim down the top piece to match the bottom to ensure the windows are the same size and slope.
Regards
Paul
Edited by paulsutcliffe
Previous builds-
Among others 😁
I have just started catching up Paul. Nice progress and some interesting build techniques. I think it will take a while to digest it all.
Where do you get your exhotic wood please?
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Hi Keith
Welcome back, I get all my wood from two suppliers in the UK, original marquetry (originalmarquetry.co.uk)  and exotic hardwoods uk ltd (exotichardwoodsukltd.com) for all the big stuff ie pear and boxwood blanks
Regards
Paul
Previous builds-
Among others 😁
The temperature warmed up slightly Friday is managed to get some ship time in, head main rails are now attached and some more work done on the gallery top
20190109_162456.thumb.jpg.82436d64ed948c9c4de81ceb7c46e23b.jpg20190109_162506.thumb.jpg.60909a3d337a917a46080f1c227d517d.jpg20190109_162528.thumb.jpg.1f4110c7d5e40d092296cab1aa9f8cb9.jpgnow working on the head timber carlings etc which curve upwards bevel towards the front and the sides, I had never noticed previously that they curve similar to the main rail as well
Regards
Paul
Previous builds-
Among others 😁
stern head timber fitted, ebony trial board and bolster can just be seen under the upper cheek20190129_124307.thumb.jpg.fe7133770b258edfc0009333504125ea.jpg
forgot to move the coffee cup
bulwarks on the forecastle also going in, mortices for the carlings added to the head timbers and a test of the carronade to check fitment
regards
paul
Previous builds-
Among others 😁
as I mentioned earlier the carlings for the head curve upwards similar to the main rail, I curved a piece of 6" box with dry heat ready for these pieces
even though it is nicely bent because the pices are so short when ou have cut them they actually still look straight, so I will have to shape them by sanding in  more of a curve
regards
Paul
Previous builds-
Among others 😁
current state of play, there are some really interesting and awkward angles and curves in this area
the piece of tinfoil is representing the lead covering for the lancing piece, not sure if I will be adding this piece or I might try and make it out of copper foil, chase port has been cut out on this side with gents saw and I now need to file sand the sill level
regards
Paul
Previous builds-
Among others 😁
Carlings and ledges all completed, the curve upwards was made more complicated by the slight camber similar to the deck
20190130_172354.thumb.jpg.f4563c5efa9f43a724142b56e20eaf09.jpg20190130_172346.thumb.jpg.6f3d9be0a7b32c8e84610f8a7fceb430.jpg
Previous builds-
Among others 😁
I need to bevel the bottoms of the false rail before fitting, a coat of sanding sealer and final sanding of the head timbers first though, oh ! and the seats of ease
Regards
Paul
Previous builds-
Among others 😁
Impressive detail Paul.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Sometimes, one Keith isn't enough. 😊 Very nice Paul.......Keith
Edited by Keith Black
Additionally statement
And here's two Mark's.....   Very nice, Paul.
🤣🤣thankyou Mark's and to everyone for the likes
Two costs of sanding sealer, false rails fitted, seats of ease to do
Question- normally there are two more seats at the back corners, however these aren't shown in the aots Diana and when I measured up they would be directly under the chase ports above which are an addition on my profile plan, would they have been omitted from this position because of the guns above?? Any suggestions?
Regards
Paul
Previous builds-
Among others 😁
Paul one thing I forgot to ask about the temp in your garage, that is not where you keep the model is it? I would be a bit concerned about the temp changes with all the glues and joints.
Michael
Hi Michael
Unfortunately yes it is, lives there all year round, I haven't noticed any problems yet but did seem to have a bit of hogging in the long dry summer but that's disappeared now, anything I glue at the moment though has to be hit with a heat gun for a few minutes or the joint have failed when it has been really cold -3 last night and a couple if the ledges on the head were still loose this afternoon and I had to reglue.
I hate to think about what might happen when I do finally bring it indoors
Thanks
Regards
Paul
Previous builds-
Among others 😁
Added the front seats of ease and test fitted the rear seat
Regards
Paul
Previous builds-
Among others 😁
Paul, you would sure want to know if anyone was planning on running out the cannon, before choosing that seat of ease! But then I guess no one would be allowed forward if the ship was coming into action...
I've spent a long time staring at the picture of the Bellona headworks on the front of Brian laverys ship of the line book admiring the scroll on the end of the hair bracket, also looking at mine which can be seen above
I decided major surgery was needed and cut it off
Spent a few hours last night watching you tube on carving scrolls and replaced with this
Which doesn't look very good in that picture but get the light right and it ,looks like this
With a bit more sanding smoothing and sealing I think it will be much more how it should be, not like Bellona yet but a bit more practise
Regards
Paul
Previous builds-
Among others 😁
