7 hours ago, SJSoane said:
if the ship was coming into action
Mark, seats may not have been required!
Edited by Keith Black
spelling
Hi Mark, you are right im not sure I would want to be perched there when the gun above was run out😀
The clerk of the cheque's yacht of sheerness
Current build HMS Sirius (1797) 1:48 scratch POF from NMM plans
HMS Winchelsea by chuck 1:48
Cutter cheerful by chuck 1:48
Previous builds-
Elidir - Thames steam barge
Cutty Sark-Billings boats
Wasa - billings boats
Among others 😁
I wouldn't want to be up there when the gunfire is "incoming".
Just found your log  - fantastic work paul.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
A couple of days off work and reasonable temperatures have got me back in the garage, I started with finishing off some parts for the carronade, breeching rings etc out of brass, and then made up some rope of the right size to check how it all looked
Previous builds-
Among others 😁
Whilst trying out the fitting I was thinking about the rest of the rigging for the sled so came to msw and searched carronade rigging, lots of options to read and then I noticed a picture of someone's Diana and noticed there was no bulwarks on the forecastle, checking my plans and the Diana book I realised I had a problem and my 12 pound cannons wouldn't fit
As can be seen above more deconstruction has started, always one move forward and two back, in my wisdom I have built up the bulwarks to High and will have to remove all the caprails and timber heads and lower it all down
In fairness to myself the frames were cut nearly seventeen years ago and I made them to the full height including the berthing up, I have then gone ahead and added the timberheads on top, so am now standing at approximately two feet too high
Previous builds-
Among others 😁
Caprails and timberheads removed
The middle piece has been sanded down to the correct height of two and a half feet, timberheads on top of eighteen inches will bring it all up to four feet high as it should be
Edited by paulsutcliffe
Previous builds-
Among others 😁
Hi Paul.
The advantage of this approach is that you eventually end up with twice as much material as you started with. You will be able to sell on the spare and plough the surplus into a workshop central heating system.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Great idea Keith thanks, that really made me chuckle
Regards
Paul
Previous builds-
Among others 😁
Probably an even better idea the way im feeling right now, or the whole ship😁
Previous builds-
Among others 😁
All port side sanded down and levelled ready for  remaking the caprail
Carronade and 9lb chase gun test fitting
Regards
Paul
Previous builds-
Among others 😁
So four years on since I had the stroke and restarted the build from pieces in the garage, and this is where i'm at
Previous builds-
Among others 😁
Wow, really looking great Paul.  Such a beautiful ship.
Able bodied seaman, subject to the requirements of the service.
"I may very well sink, but I'm damned if I'll Strike!" JPJ
My Pacific Northwest Discovery Series:
On the slipways in the lumberyard
Union, 1792 - 1:48 scale - POF Scratch build
18th Century Longboat - circa 1790 as used in the PNW fur trade - FINISHED
Future Builds (Wish List)
Columbia Redidiva, 1787
HM Armed Tender Chatham, 1788
HMS Discovery, 1789 Captain Vancouver
Santiago, 1775 - Spanish Frigate of Explorer Bruno de Hezeta
Lady Washington, 1787 - Original Sloop Rig
 Thankfully Paul, having had a stroke you're now in relative good health and have the manual dexterity to continue with the hobby. Both you and I are very fortunate compared to a whole lot of stroke victims.
 It's a fine looking ship and you should be proud!
I'll jump in as a third stroke victim... Paul, you're doing very well and if you hadn't mentioned it, no one would have known.  You're doing that good.
Thankyou Downer, Keith and Mark for the comments, Keith you are not wrong and feel extremely lucky after seeing some of the other stroke victims in the ward during my stay there
Mark get that licorne finished, don't let it beat you
Regards
Paul
Previous builds-
Among others 😁
The picture I showed the other day wasn't very good with all the clutter on the deck, as it was supposed to be a four year anniversary picture I decided to show a better effort
Cleared away and all shipshape, with the original deck nail from the real ship
Previous builds-
Among others 😁
Remembered I had to fit the elm tree pumps before I couldn't get access anymore, I remade the piece to hold the forked stanchion and added a piece of hardened sterling silver for the end of the shaft, rest made out of brass
And after painting
Regards
Paul
Previous builds-
Among others 😁
Paul.
She is looking good for a 4 year old. I once took 20 years to complete a model so you have a way to go until you can claim she is a veteran build. 12 deg C in my workshop for the last week, I assume you are benefiting from the same mild conditions?
P.S - we must have all bought those nice cheap tweezers.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Thanks Keith, four years since the restart, First frames were cut 17 years ago now, yes the tweezers were recommended by someone in this site if I remember correctly and I think the seller did very well out of all of us that fell for it ha!!!
I have had the last two days in the garage with the warmer weather, unfortunately work gets in the way at other times, but yes much more bearable than the last couple of months, I have even started doing some sanding on the cheerful Hull to try and get it back into some sort of shape
Regards
Paul
Previous builds-
Among others 😁
Ah I see, only 3 years to go.
Tweezers - I bought a set, my son bought a set - the manufacturer probably never knew why his sales took off.
Edited by KeithAug
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Small update on things, working on quarterdeck furniture while messing about with the cheerful Hull and painting, mizzen and capstan partner with wheel and rear gratings all with ebony
Previous builds-
Among others 😁
