Hi Frank just a query.Just above the cross jack on the foremast are 2 k's 5mm double blocks,they are the ones rigged to  the 2 j's or 5mm single blocks on the cross jack.plan sheet 6.Did you tie these to the mast after doing your bottom shrouds and how far up the mast did you attach them to.Thanks Frank.
Current builds: HMS Victory - Caldercraft 1:72
Completed builds: HMB Endeavour - OcCre 1:54   HMS Supply - Caldercraft 1:64. Fishing boats, Bremen,  Palamos.
Hi Ron ..... if you are referring to the ones that hoist the yard, yes I attached them after the shrouds were in place, the 2 k's went around the mast and came down thru the opening in the mast top( on top of the shrouds) Hope that was what you ment :)
Frank
completed build: Delta River Co. Riverboat     HMAT SUPPLY
                         USRC "ALERT"
in progress: Red Dragon  (Chinese junk)
Ron I'm sure 15mm will be the right distance for your deadeyes on the lower shrouds and 12 on the upper. I made s spacer out of a small pc of wood with nails thru it at the right width and distance between top and bottom deadeyes. I wish I had my camera , I'd send you a picture.
But its pretty simple , I'm sure you'll come up with the right way.
                         USRC "ALERT"
looking forward in seeing you get back in the saddle....so to speak ;)     the admiral would like to get another camera.......I'm going to try and put in my two cents......for a few more bells and whistles.  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Frank,
Any more movies or pictures? :P :P :P
:cheers:
Jim
Completed      Robert E Lee, Misisssippi riverboat
Completed,  HMS Victory Bow Section
Completed,  Wells Fargo Stagecoach...Picasa album....
Completed,  Lackawanna tugboat converted to private yacht...
Completed:  Sopwith Camel, 1:16 Scale, Model Airways...at another location...
Completed:  1961 Ferrari F-1 Sharknose
Completed: (sorta)  OcCre BR-18 Locomotive
Completed: 1/35 Pz.KPfw.III
Completed: Allerton Steam Pumper circa 1869
Hi Frank just saw you vid i used  firefox no probs  picture sound all ok,oh yeh the oscar is in the post.You just might have started some thing her my friend ihave not used my canon dvd camera in ages,might do one for meself now,lol  i wont be going on here though.  DEREK :cheers:
  • 2 months later...
Well time for a little update, it's been awhile since I've posted here, due partly to my procrastination and partly because I can't see to well B)  B) , ........ anyhow I could get thru the anchors with out too much of a problem....... so here they are....... does anyone out there know if the anchor rings are supposed to have rope raped around them??... if so what's the best way to do them. Thanks
Frank
                         USRC "ALERT"
gee Frank........they look great!   they look weathered........the wood part came out especially well.  I'm not an expert Frank,  but I think they do....I believe it called wooling.   I'm going to do it on the Goth........dampen the thread with diluted white glue and wrap it aroung the ring evenly.......should be tacky enough to hold the thread in place as you do it.   that is the method I thought of,  perhaps someone else has something better.   glad to see your making some progress.......look forward in seeing more.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hey Mike....... the anchor wood was walnut, and I'm not a big fan of walnut, so I put some "Weather It" on them , then I put some white weathering powder on them, used some Q tips and rubbed most of it off,  then I just did the same with  a medium rust where rust would normally accumulate.  I was pleased that they came out as well as they did, especially the wood. Thanks for the pdf. it will be helpful. How are the twins doing ? Keep'n you up at nite?? :D  :D
Frank
                         USRC "ALERT"
Thanks for the techniques - I like how they turned out.
Twins are doing very well, thanks for asking.  They are four months now, and not waking up too many times during the middle of the night.  Hopefully things get easier soon so that I can finish my Badger and move on to other builds.
Frank!!!!!!!!!!  Great to see you got some shipyard time in.    The anchors look superb all weathered and used looking.
dooough!  thanks Mike for the correct terminology of the anchor ring treatment.......what I described....goes around the mast!  so many new words....I can't keep them straight!  LOL!   you got twins......and your still building!?   gee.....I have two boys {6yrs apart}...and I had to stop for a while.  build while you can.......when they get mobile.......game over man! ;)
Frank........I made an error on the term for it..........listen to Mike.......puddening........I'm writing that down....... :blush:
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
are you using something like this?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Don't listen to him Frank, just do what you can when you can, cant be easy mate especially when you have to borrow your own camera. :D  :D
Lovely work on the anchors my friend, the anchor ring should be roped, it's quite easy when you get started.
Take care buddy
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Hello Frank,
It's good to see back at your Supply again.
I must agree with the others. The anchors are looking great.
And just take tour time, we will (try to) wait patiently.
Skype is on next saturday with Mobbsie at 19:00 our time.
That will be around 10:00 am your time.
You are more then welcome to join.
Anja
Those we loved but lost are no longer where they were, but are always where we are.
In the gallery: Albatros 1840 - Constructo
Mark ...... yeah, finally getting back to doing something ,it's about time I get her finished up, you know you're
                taking to long when your grand kids are saying " aren't you finished yet " :D
B.E.  .....     thanks for taking the time to look in, I'm glad you like the effect  I'm striving for.
Popeye .... No sweat on the terminology, I had no idea what they called it either, we both learned something :D ....... I didn't use the Lifecolor  weathering set, but I do use their paints, and I love them . They are great to work with. I have a couple other weathering sets of theirs and they're real good too. I used a product called "Weather It " and some white and rust weathering powders on the anchors. I'd like to get their wood weathering set, it looks like it might be pretty good.
Sjors  ......  Finally getting back into it Sjors, not much , but alittle..... at least you got a picture!!   :D  :D :D
Tony ......   No more excuses for the camera, it's back!!..... now all I have to do is use it :D ... Thanks for the heads up on the anchors.
                   I'll try and catch you guys on Sat. (Skype).
Anja .....     thank you for your kind comments, ( psssst... don't tell Sjors this but, they are only exceeded by your gracious charm and good looks !! ;)  ;)  ;)  ;) )
Frank
Edited by riverboat
                         USRC "ALERT"
just another little update on the puddening of the anchor rings......... the rope I used started out a nice tan , but when I put a drop of cyno on it to keep it in place, it turned the color of the rope real dark, so I had to do a little coloring on them. hope they look passable !! I decided to redo the catheads, so before I add the rope to the anchors I want to work on those first.
Edited by riverboat
                         USRC "ALERT"
Hi Frank,
Even when it is changing colour it doesn't matter .
The anchors are looking old, so when the rope is darker, that's also looks old then…..
Keep on going my friend !
Looking very good, Frank.  You accomplish some amazing weathering on your builds - I am quite envious of your skill!!!
Wayne
Neither should a ship rely on one small anchor, nor should life rest on a single hope.
Epictetus
Sjors:..........  you're right, they should be darker...... must be my eyes B)
Arthur:......... thanks for look'n in, glad you like the look!!
Wayne: ......  the hardest part about weathering is doing it :D  :D .... thanks for your comments...is diner still on???
                         USRC "ALERT"
Howdy Frank!
Just getting caught up a bit - good to see you back at it , and a great comeback at that! Those anchors look incredibly well done!  The weathering is outstanding.   You are a brave brave (and talented) individual!!
KUDOS!!
-Adam
-Adam
Current Builds
Santa Maria - Artesania Latina (1:65) POB
MayFlower - Model Shipways (5/32"=1') POB
Blue Shadow - Mamoli Revolutionary War Brigantine. (Fict) (1:64) POB (Recommissioned as the Kara June)
On The Shelf Waiting so Patiently
USRC Ranger - Corel (1:50) POB
18th Century Longboat - Model Shipways (1:4) POF
La Nina - Artesania Latina (1:65) POB
U.S Brig Syren - Model Shipways (1:64) POB
Completed Builds
Phantom NY Pilot Boat - Model Shipways (1:96) Solid Hull
Decommissioned Builds
(Time and conditions were not good to these. They have been cancelled =( )
Willie L Bennett - Model Shipways (1:32) POF
USRC Harriet Lane - Model Shipways (1:128) Solid Hull
