Thank you, Ron. How have you been - not seen you for a while? Might have a go at HMS Bounty (Amati) but not just yet, will have a break but still be keeping an eye on yours and everyone's builds...Again thanks for all your help - as you say the instruction aren't that brilliant but I guess that is the fun bit....
Completed:
HM Brig Supply - JoKita / Caldercraft 1:64
HMS Fly - Caldercraft 1:64
HMS Sherborne - Caldercraft 1:64
HM Brig Flirt - Vanguard 1:64
Saucy Jack - Vanguard 1:64
Fantastic work. Crisp, clean and precise. CONGRATULATIONS!!! Bloody well done.
Alistair
Cheers
Alistair
Current Build -
what a beautiful model Doug. I am about to start the "Supply", kit arriving tomorrow. Will be visiting your build site on a (very) regular basis! All the best Geoff
Thank you everyone for your comments - and Geoff will be looking out for your build - good luck.
Been busy sorting out a glass case - very expensive but I guess it is needed
Regards
Doug
Completed:
Thank you for looking in and your comments,  Amfibius.
I think I have finally finished !!!
Have made up a deck pump from a combination of one from Caldercraft and an Amati one. Although I still have another one to do I may not fit them on the ship as there is really no space - gets a bit tight. The handle had a bit of walnut strip added both sides and sanded round otherwise it would have been flat brass.
Anchors fitted.
Rounded lump added for the sling to sit on - plus having been very impressed by Beef Wellington's (Jason) serving thought I'd have an attempt on the slings.
Final photo
Thank you for looking and and all the comments and those on the old site whose build of the Supply helped me get started. Hopefully I may have helped someone in return.
Again thank you
Regards
Doug
Beautiful build Doug,
a wonderfull sight your Brigg Supply
Nils
Current builds
-Lightship Elbe 1
Completed
  • 2 months later...
A very, very impressive build!! The detail is remarkable. I am particularly impressed with your paintwork. I assume you used Admiralty Paints?? If so, did you use acrylic or enamel? Was an airbrush involved or did you paint everything with a brush?
Hornet
             Current build HMS Granado - Caldercraft
             Completed Ship Builds. - USRC Harriet Lane - Model Expo.
             Vanguard - HMS Adder, OcCre - Shackleton’s Endurance
             Caldercraft - HM Bark EndeavourHMAV Bounty HM Brig Supply
             Aeropiccola - Golden Hind, Constitution
              Scientific -  Clipper Seawitch.     Corel - Victory
              Modeller's Shipyard - A Schooner of Port JacksonBrig `Perseverance'    Cutter `Mermaid'
               Sirius Longboat (bashed Sloop Norfolk
Beautiful work Doug! Love this ship and would love to build her one day - you've done an excellent job
hamilton
Love the pump. Wish mine looked that good!
 Current build: Syren : Kit- Model Shipways
Side project: HMS Bounty - Revel -(plastic)
On hold: Pre-owned, unfinished Mayflower (wood)
Past builds: Scottish Maid - AL- 1:50, USS North Carolina Battleship -1/350  (plastic),   Andromede - Dikar (wood),   Yatch Atlantic - 14" (wood),   Pirate Ship - 1:72 (plastic),   Custom built wood Brig from scratch - ?(3/4" =1'),   4 small scratch builds (wood),   Vietnamese fishing boat (wood)   & a Ship in a bottle
hornet - hamilton - and JesseLee
Thanks for looking at my build and your lovely comments.
hornet - I used Admiralty paints, diluted with some water - hand brushed several coats with sanding in between.
Been building a balsa wood WW1 plane kit - but will get back to ship building.
Also have another distraction - have just had a 1963 Lambretta TV175 series 3 scooter restored to play with....
Had a case built as well for HM Brig Supply - so a bit poor at the moment  :(
Regards
Doug
Completed:
Hey Up Doug, Your "Supply" looks good in it's case. Could I ask where you got it from as mine is nearly ready? Like the aircraft model, as an ex "Rocker" not sure about the Lambretta though!!  Geoff
geoff - hello.
Have sent you a pm but not sure if it worked.
So if you did not get the pm the answer to your question as where I got the case - sshardwoodworking.co.uk - and the guy's name is Simon.
Doug
Edited by Dfell
Completed:
thanks for the info. Doug, I looked up the address you gave me, he certainly knows his stuff! I now have to summon up the courage to ask for a quote & leave the info for the Admiral to see(accidentally on purpose)!  Geoff
  • 6 months later...
Hello Doug,
I just bought theCaldercraft  Supply also, but in my box I see no resign sloops, and the drawings mention nothing about windows in the stern.
 Did you "super" detailed them, or can it be that you have a different version?
RonaldB - Hi - yes the windows were a scratch built but not sure what 'resign sloops' are but if they are not in the box then I either bought them or made them
Wish you well with your Supply build and will look forward to it with interest and can certainly help you if you require any as I am sure the others on here who also have built Supply will like to help.
Regards
Doug
Edited by Dfell
Completed:
Hello Doug,
Thanks for your reaction.
About the windows at the stern, i will see what I do
The sloops i was referring too, i wrote it wrong, must be resin (the material), i have seen these somewhere on the net, they are very good detailed and accurate mini models.
For now, i go along making a carefull start whit my Supply.
When i need help, i sure will not hesitate to ask.
Regards,
Ron
  • 1 year later...
Just read through this whole build and what a stunning piece of work you have created, infact I have now given up wanting to do the Pickle, this model is going to be my next step on the ladder. There is something pretty special showing a ship with no sails, I think they look tons better in the rigging scenario only. Great job my friend and thanks indeed for posting something so interesting it was impossible not to just keep reading.
Current build: Caldercraft 1:64 HM Brig Supply
Finished builds: HMS Endeavours longboat
Hi Doug, can I just ask please.... The lifeboat on your supply, was this part of the kit? I got mine today and am doing the inventory check and there is not one with the kit, so I thought I'd better ask just in case this is a self build by yourself or an addition as such. Thanks for any feedback.
Terry
Edited by Telp
Hello Telp - bought the ship's boat from Cornwall Model Boats.
Link to web site and item:
http://www.cornwallmodelboats.co.uk/acatalog/caldercraft-ships-boats.html
Hope this helps and hope you got my message awhile back thanking you for your previous nice comments. Thanks again
Regards
Doug
Completed:
Many thanks Doug, I have duly ordered one, I am going to go for the windows option at the stern as well, that really does set it off. I think I saw them on the cornwall site, little 4 pane metal ones. Must admit, I am not sure about the kit ladder, I think I will be hunting other bits down, this happened when I use to build aircraft, I think 50 per cent ended up being bought or self made. regards
Hello Doug, indeed a magnificent build. Very impressive build log and beautiful work(too bad so many pictures got lost). I would sure like to see you build the Amati Bounty as I myself have that one and would be happy to follow you as the "Master" ;)
  • 6 months later...
Hi Doug, was wondering if I could ask please where you got the brass stand fittings from for the build, I was having a think on how to mount and remembered seeing these. Many thanks.
Terry
Terry - Hello. Been following your build - nice build!
The brass column mounts came from Cornwall Model Boats (made by Amati)
Regards
Completed:
Thank you - Blue Ensign - for your comments.
Not sure if anyone noticed I had the design on the bow replicated onto the case stand.
Again thank you very much to everyone who looked in, commented and the likes.
Regards
Doug
Completed:
I just see your build log for the first time . . . what a beautiful model! It is a fantastic sight in its case. Congratulations!
Thomas
Current Built:   Model Shipways  Syren  (US Brig 1803)
Last Built:        Anfora (kit bashed)  Ictineo II  (1st steam powered submarine 1864)
