excellent build Mike !
Nils
Current builds
-Lightship Elbe 1
Completed
With the addition of the rest of the main deck ledges the deck framing is complete. The forward, main hatch openings and the bowsprit step will be finished before the deck is planked. This set of photos shows the progress to date.
Beautiful work, Mike.   I like your choice of woods which are setting off the framing and planking.
The main hatch openings and the bowsprit step are installed. It looks like I need to add a few more things before planking the deck like the windlass, main jeer bits, azimuth compass, capstan and steering wheel. Installing the bowsprit step involved a little more work than I expected. This is a few photos showing how it was installed.
This set of photos shows the progress on the windlass and the lining on the main deck. The lining needs to be installed so the crank handles can be added. I don’t have an organized approach to building but she seems to be moving along well.
For me this week was not a good week for model building. I had cataract surgery on my right eye last Tuesday so I didn’t get to spend much time in the shop.
I did get the forecastle deck planked and have started the exterior planking. There will be a 6-pdr Carronade on the deck that will take up most of the space so I didn’t leave openings to view the main deck under the gun.
This is a few photos of the forecastle deck as it currently sits.
This is a few photos of the compass and binnacle. I used bloodwood for both items it turns very well.
I guess adding the rails will clean up the overall appearance of the ship, these are progress photos so far. I am using walnut for the rails.
This is a small update I added the wales and taffrail and am looking at the false quarter gallery. I guess it will be a solid block of wood without access to the interior of the ship.
Is this the way most false quarter galleries are modeled? Any help would be appreciated.
Looking good Mike. I like your use of rubber bands (or elastics as we say up here in New England) and clamps to hold the wales. All of the false quarter galleries I have seen are badges that fit over the planking, but I am not sure if there would be an opening into the hull under them in the real ships.
Thanks Tom,
I found that elastics and clamps are easier to use than little nails with my big hands. You are right a false quarter gallery would be a badge I just didn’t think of it that way.
I looked at the beautiful work you did on your Beagle. The layout of the main deck is different than the drawings in Heinz Marquardt’s book but all the models I have seen on line look different from each other.
I found that a lot of drawing views do not match up in his book and the size of stuff varies a lot but that is not uncommon in the AOL series of books. This book is a lot better than the one I used for my Pandora. http://modelshipbuilder.com/e107_plugins/forum/forum_viewtopic.php?3031
Mike
The Horn davits and false quarter galleries have been added to the model.
I started to make the quarter galleries out of solid blocks of wood but wasn’t having much luck squaring up the windows and went to using 14 individual pieces for each gallery. I used boxwood and walnut and like the way they turned out.
The skylight for the chart room was easy to make since it has square windows. After cutting the sides to length I drilled holes at the four corners of each window, removed the center waste with a Dremel tool and cleaned up the corners with a square file. This is a few photos showing the construction and installation of the skylight.
I have been working on the main deck items and added several hatches, pumps and the main jeer bits with attached winch. The main mast, mizzen mast and ensign staff are set in place. I will be working on the gun port covers and pin rails next.
Nice work, Mike.   I do have an observation...  check here on MSW for other English ships of the period as quarter galleries aren't "square" when viewed from the top but rounded.
The hammock cranes looked like a good place to start after returning from the family vacation. This a few progress photos of the work so far. I cutout the blanks from Beachwood and drilled .8mm holes for the netting support rope (brass wire). I use a band saw to cut out the rough shape and finished with a square file. An ebony black stain was applied and they were installed on the model. The next step will be adding the netting and hammocks.
The hammock netting is made from some plastic fabric I found at Hobby Lobby it was very stiff and difficult to install inside the cranes. To solve the problem I made a mold from basswood the same thickness as the inside of the cranes and twice the height. I marked lines at the distance to the top of the cranes on both sides of the mold and secured the slightly oversized netting with clamps then applied a diluted glue solution (4:1 water to glue). After the glue dried I used a straightedge and knife to cut the netting to size. The first photo shows the netting on the mold and the glue solution the rest show the netting installed on the model. I still have to attach the netting to the support rope with some of my infamous needle work and add some hammocks.
