Le Soleil Royal by EJ_L - FINISHED - Sergal - Scale 1:77 - 1669 Version
Well I'm back from a very relaxing vacation and am back in the shipyard continuing planking. No picture tonight as I have not done much yet but I thought I would stop in to say that progress is again being made! Hopefully in the next couple of days I will have made some substantial progress and will update then. If I get really fortunate in my build time I may even finish the lower hull planking this weekend. That may be asking a lot though... :o
Thank you to both Vic and Sjors for the kind words and encouragement on the planking. How I lay them down takes a long time but I think the end result is worth the effort. Plus it is fun to see people's faces when I tell them that I laid each plank individually and show the pictures proving it. That look of disbelief combined with the thoughts going through their heads thinking, "This guy is crazy" always makes me laugh. :D  I am looking forward to moving upward again with the planking and also working on the final shape of the upper works. Then of course there is the stern galleys and decorations......
"A Smooth Sea NEVER made a Skilled Sailor"
- John George Hermanson
-E.J.
Current Builds - Royal Louis - Mamoli
                    Royal Caroline - Panart
Member : Nautical Research Guild
Link to comment
Share on other sites
convinced :rolleyes:
WIP: No ships atm...sorry!🙄
Completed: Greek bireme - Dusek - scale 1:72
 Louie da fly: "I think it requires a special kind of insanity to choose a galley to build a model of."
Link to comment
Finished planking the lower hull a few minutes ago! Some sanding to do but overall I'm happy with it. Now I will set her back right side up and continue the upward planking. Plus side is this is the easier planking as it is mostly straight runs with very little if any to bend. More to follow soon!
-E.J.
Link to comment
Hi EJ,
I've been following along pretty religiously (though quietly) but I have to tell you how beautiful she's turning out.  Planking that monster was a monumental job and you pulled it off fantastically.  After the first planking I was a bit apprehensive and now she's beautiful.
Best,
John
Edited by Landlocked123
Member:
Connecticut Marine Model Society
Model Ship World
"So we beat on, boats against the current, bourne back ceaselessly into the past" F. Scott Fitzgerald - The Great Gatsby
"If at first you don’t succeed.......skydiving is probably not for you”
Link to comment
Thanks John. With P.O.B. kits I really need to stop trying to piece in the planking board by board for the first layer like I do on the second. The supports and frame structure are not very helpful for that style of planking. Instead, that first layer should be full length pieces which would give a much better appearance and smoother surface. Then I can plank piece by piece.
I remain stubborn on doing it the harder way mainly because it is practice for me. My ultimate goal is to only have to do one layer of planking so I keep practicing and with each build I get a little better. I'm making my way through those 99 ways to do something wrong in order to find that one way of doing it right! :default_wallbash::P
I'm looking forward to being able to give her a good sanding and apply the finish coat. I did a small test sample and really liked the way t came out. Now I want to see it across the entire surface. Ready to see that wood coloring at it's best! Still a little way off but with the completion of the lower hull, it is a lot closer.
-E.J.
Link to comment
gads, i hope you haven't already revealed this, but what glue did you use to install the planks?....ca?...if so.....no allergies? ha, my wife's sinuses clog up when she's exposed to ca fumes...i'm starting to react too....but, coming to the end of my build, i't not a problem...
Edited by yancovitch
Link to comment
I use a combination of CA and yellow wood glue. On flat runs or decks, basically anywhere I do not need to hold the piece in place I will use wood glue. On curves, vertical sections or anywhere that needs some pressure applied to hold the wood, I will use a thin layer of wood glue but will also add in some CA glue to help it bond and stay in place faster. That eliminates the need the need for clamps, nails or anything that may damage the finished surface.
The reason I use both glues is that I have read a lot of people saying that the CA glue fails faster over time than the wood glue. While I have not personally experienced this with either glue if applied properly, I admit that there are a lot of people with far more experience than I and so I figured it was in my best interest to take precautions. Plus glue is relatively cheap so other than an extra minute of build time, I'm not really out anything.
As for allergies, I've been fortunate in my life that so far I have only found that I have allergic reactions to Bubinga wood. Nothing in glue yet has bothered me. Wish I could say the same about the rest of my health but, be grateful for the good. :)
-E.J.
Link to comment
Well done with the planking EJ.
She looks beautiful.
Always a pleasure to follow
Regards, Patrick
Finished :  Soleil Royal Heller 1/100   Wasa Billing Boats   Bounty Revell 1/110 plastic (semi scratch)   Pelican / Golden Hind  1/45 scratch
Current build :  Mary Rose 1/50 scratch
Gallery Revell Bounty  Pelican/Golden hind 1/45 scratch
To do Prins Willem Corel, Le Tonnant Corel, Yacht d'Oro Corel, Thermopylae Sergal
Shore leave,  non ship models build logs :
ADGZ M35 funkwagen 1/72    Einhets Pkw. Kfz.2 and 4 1/72   Autoblinda AB40 1/72   122mm A-19 & 152mm ML-20 & 12.8cm Pak.44 {K8 1/2} 1/72   10.5cm Howitzer 16 on Mark. VI(e)  Centurion Mk.1 conversion   M29 Weasel 1/72     SAM6 1/72    T26 Finland  T26 TN 1/72  Autoprotetto S37 1/72     Opel Blitz buses 1/72  Boxer and MAN trucks 1/72   Hetzer38(t) Starr 1/72
Si vis pacem, para bellum
Link to comment
You have to be careful with those CA glues.  In my twenties and thirties, none of that stuff bothered me.  We were using massive amounts of West System epoxy, and washing it off our skin with lacquer thinner.  Stupid.  Now I find I am sensitive to funes from curing epoxy.  Same with CA glue.  I used to use it a lot, but now I find that I can't tolerate the fumes.  Make sure you ventilate.  And if you are using a lot of that stuff, go get yourself an organic vapor respirator.
All that being said - the ship really looks beautiful EJ.  Great work!  Sorry about the soapbox.  I just wish I had taken that stuff more seriously when I was younger.
Link to comment
I do have good ventilation in the shipyard and for heavy amounts of it I go out to the garage. To me the fumes from Testors liquid cement are more potent than the CA that I am using. Maybe brands or I'm just used to them and don't notice anymore. My warning that the fumes are bad is when the Admiral starts complaining. She is the best hazard alert I have! :D
Maybe need to pay a bit more attention to that though. Hate to cut modeling years short....
On happier note, thanks to all for the compliments and likes! My head is clear once again after vacation and I'm ready and motivated to keep on building! Should have another update in a few days.
-E.J.
Link to comment
Congratulations on a major milestone--looking good and putting my progress to shame!
To weigh in on the CA debate, I've stopped using it altogether after developing an allergy to the fumes.  I've found that anaerobic glues, also called threadlockers are best for attaching metal to wood.  They are virtually odourless an much easier to work with than epoxy.
Edited by testazyk
Tom
Current: Sergal Sovereign of the Seas
Previous builds:  AL Swift, AL King of the Mississippi, Mamoli Roter Lowe, Amati Chinese Junk, Caesar, Mamoli USS Constitution, Mantua HMS Victory, Panart San Felipe, Mantua Sergal Soleil Royal
Link to comment
I'm not sure, Hubac--I haven't tried that.  My guess is that it wouldn't work as well as model cement because it doesn't bond that way and it has a drying time, too.  But it works best on nonporous surfaces, so it may well bond plastic.  To test it out, I've stuck two scrap pieces of plastic together in my high tech materials lab (aka basement) and I'll let you know how it goes.
Tom
Link to comment
I too am interested in the results. Always on the lookout for new things to try out. Would love to find a glue that doesn't bond to skin as each of these ships has literally taken pieces of me with them! :P
-E.J.
Link to comment
she's look'in good E.J.   planking looks top notch!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
I let the test sit overnight and the results are 100% success!  It was two flat pieces of smooth plastic and they've bonded nicely.  Hope this helps.
Tom
Link to comment
Do you guys have a recommended brand and strength?
Ken
Washington 1776 Galley
Pilot Boat Mary of Norfolk
Completed Builds:
Link to comment
I use a brand called BSI only because it's available here.  It is pricey which is why I only use it for attaching decorative metal pieces.  They come in three kinds, green, blue and red and those colours mean increasing strength.  Blue seems best because it's a little thicker in consistency. These adhesives are designed to be but on bolt assemblies to prevent them from vibrating loose.  Blue and red are thin and runny to help them flow into the screws.   Also check because some of them specify that they aren't for use on plastics.  Hope that helps.
Tom
Link to comment
So here are the main glues that I use for the wood works. The wood glue is just readily available Elmer’s wood glue. I actually buy it in gallon size jugs and refill the smaller bottles as needed. The CA glue I use I buy at the Hobby Store and I get both the super thin and extra thick. The extra thick is the one I use one the majority of the CA needs. It is easily controlled so I can apply very small amounts easily. The super thin glue I like to use if the wood I’m using has tendencies to split easily when drilling or cutting. Since it comes out very runny and thin, it works great to cover a piece of wood in a thin layer of glue that holds the wood together to prevent splitting. Once he holes or final shape is cut, it sands off easily. I have some others I. The collection but most of my builds are done with just these.
Edited by EJ_L
-E.J.
Link to comment
So I know I was planning on getting back to work on S.R. now that vacation is over but the past few days I have been distracted as my inner child got to play with his favorite toy. While on vacation I picked up the Lego Disney Cinderella's Castle. It is built with 4,080 pieces, stands 29 inches tall and 19 inches wide. Comes with 5 characters; Mickey, Minnie, Donald, Daisy and Tinkerbell and has an amazing collection of details from several Disney movies. As both the Admiral and myself are huge Disney fans this was a great addition to our collection. It took me 14 hours to build so that is what happened to my ship yard time since Saturday.
Now I can get back to work on ship modeling as I shouldn't have any more distractions!! :D
-E.J.
Link to comment
hey EJ that's pretty cool, looks like it is pretty big
Edited by donrobinson
Link to comment
used to do legos with my oldest son.......during a blackout one time {storm related}  we built a street front {just some buildings using city street tiles for the base,  it was lots of fun.   looks like a really cool project  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
My dad and I did a similar thing when I was a kid. Then we both got into model railroading and those street scenes began to look a lot more real! I still have a huge box of Lego's at my dad's from childhood. Wish I would have taken better care of them growing up. I was rough on them and many found their way into air ducts, lost in the yard, swallowed a few, dog swallowed a few, left who knows how many at friends' houses and some I think just vanished like socks in a dryer. :P I can still recreate the majority of the structures, vehicles etc. that I once had but some will be missing a few pieces here and there.
They are actually what got me started into model building. I was constantly trying to build more realistic cars and buildings out of Lego. Dad saw this and so when I was 8, he began buying me model car kits and buildings for our train. He would work with me on them, teaching me painting techniques and how not to get glue on everything. Of course those early models looked bad but, I learned a lot and with endless possibilities of things to model and ways to modify them, I quickly fell in love with model building. Still played with Lego (obviously :D) but now I could really let my creativity come to life with the realism I wanted.
Ok! I promise, ship building updates soon!
-E.J.
Link to comment
As promised I am back in the shipyard and working hard. I raised the planking up to the 6th wale. From here up the planking will be painted blue with the wales still in walnut. I plan on pre-painting the planks before I install them to help ensure clean lines where the paint breaks against the wales. I will also give the lower hull a good sanding and apply the first coat of finish.
The break from the build was nice and refreshing but now I'm ready to get back to building. Now just hoping that whatever bug has the Admiral sick and in bed stays away from me!
-E.J.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
