2 seats of ease for a hundred... requiring release from the stresses of their day....seams a bit short sighted.  On the designers part....
Your model is looking superb...
Rob
Current build:
Finished build:
Current build(On hold):
I have to agree with Rob on his observation.
Michael
O.K. my friends, I will add others.😉 You are right. Thank you for your opinion and advice.
BTW, there are also seats of ease on main channels - just here:
0.jpg.1a36b41476b60bb523aa0991a803e81a.jpg1393278293_SOEonRK.thumb.jpg.c1b4ecf3c1fc9224ee1f862ca002ad99.jpg
Kind regards,
Doris
Doris
Current build:
HMS Royal Katherine 1664 from card
The doors are magnificent...I assume they are made from the vinyl  as well?
One question: I noticed the offset of the bowsprit exit hole and the bowsprit foot are not aligned...is there some reason for this?  Sometimes the bowsprit is laid port or starboard of the foremast because of proximity....but I would still think the exit and foot would be parallel to one another.
Just noticing.
Your work is so wonderful its hardly fathomable that it is made from card stock and some self adhesive vinyl laminate and modeling compound.
The folks who build exclusively with wood, would have a rough time keeping up with your standard......
Just wonderful work Doris.
Rob
Current build:
Finished build:
I suspected that...but I thought I'd ask.  The angle appears to be significant in relations to the distance of the hole(Bowsprit exit) from the foot.
Rob
Current build:
Finished build:
Thank you for your comments, dear friends.
Druxey is right, on some ships from that period you can see the bowsprit located outside the ship's axis but its forward end is at the centerline.
For example HMS Prince:
medium_1895_0056__0008_.jpg.729f5420518e4147a7e7448efff1bc51.jpgmedium_1895_0056__0009_.jpg.1d40cdb6eba65273fe9bcd1c7d7100d5.jpg
I admire wooden models and their builders a lot, wood is very beautiful material. I also tried to make some wooden models but finally stayed at card/paper ones  - it is much easier and enjoyable work for me, and I have found various ways how to improve techniques to achieve better results and get closer to the appearance and solidity of real wooden models.
Best regards,
Doris
Edited by DORIS
Doris
Current build:
Ship builders always have a reason for everything. But could the reason for the eccentric bowsprit simply be to allow access to a central beakhead bulkhead door? In Doris's model the doors are offset so a central bowsprit heel would be possible if the bulkhead were framed differently. Curious!
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
Hello Greg,
it was a difficult task for me, cause I do not have exact plans of the Royal Katherine, so I have to improvise from time to time. My solution is based on Vale painting, Van de Velde drawings and museum models from that period.
Royal Katherine on Vale painting:
Here was my main inspiration  - the model of Saint Michael, there is also the bowsprit out of centerline and in the beakhead bulkhead there are two doors:
SM1.thumb.jpg.e9bb47683bc0004ae67fab5b1b2c9ac2.jpgSM1a.thumb.jpg.2b7ebfdda6ec3886a3c1ef61ff86c90c.jpg
http://collections.rmg.co.uk/collections/objects/65963.html
Of course, I am not always sure with the solution, so please do not regard my opinion as relevant. I am only an amateur, but I learn and want to improve my knowledge.😉
Best regards
Edited by DORIS
Doris
Current build:
7 minutes ago, KORTES said:
Dear Doris
Your work inspires admiration. The technology that you are using is really unique and gives an outstanding result.
Respectfully yours.
Thank you, I am honoured you like my work.
Kind regards
Doris
Current build:
In most instances the offset for the bowsprit was established because of the internal proximity of the foremast and the bowsprit.  Because the forecastle was short and tall, the bowsprit and foremast found no room to be on axis with one another...so they did indeed offset the bowsprit by fashioning it beside the foremast.  I know this,....however, in one of the images Doris took of her additional seats of relief addition...the angle of the exit for the bowsprit and the bowsprit foot is too acute...resulting in the bowsprit being exaggerated to port by almost 20degrees....from what I can tell.
My original question was centered around that angle....NOT that,  was that angle(Or offset) correct.
I can only assume the bowsprit will be fashioned NEXT to the seat and not ON the seat...
Question:
Doris...will you be rigging this model with masts, yards(sails) and rigging?
Rob(inquisitive minds want to know)
Edited by rwiederrich
Current build:
Finished build:
Hello Rob and thank you for interesting information and attention to detail for more realistic implementation. I would like to learn more although my English is not very good for understanding and I don´t know appropriate technical terms. If possible, please post some pics, it will be very helpful (not only) for me.
Question:
Of course, I will. Hope I will manage it well.🙂
Kind regards
Edited by DORIS
Doris
Current build:
I just caught up with your project Doris........I'm in awe!   it's always a pleasure to look at your amazing work  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Question:
Kind regards
Doris I drew up quickly, an example of the 3 possibilities the bowsprit might find itself.  Key elements are noted on the drawing.
My question is, from your model, the exit hole for the bowsprit would place the bowsprit off axis if you were to seat it on the foot as noted by the example on the right.  if you were to keep your bowsprits termination on axis, you would follow the drawing example on the left.  the middle drawing is a representation of an average.
Key notes: The bowsprit is abutted to the foremast(for reasons previously noted). The real question is, will you be actually resting the bowsprit on the foot(where it usually is found) or will you be placing it along side it and allowing for it to be centered and then fixing it there?
That was my entire line of questioning.
Rob
Current build:
Finished build:
I am fascinated by the Science Museum Model of the Prince.  I can appreciate the practical considerations for off-setting the bowsprit to the side of the mast and stem, however, I had always thought the stem was an essential support for the bowsprit.  Or, is it the case that between the gammoning and the fore stay(?) weights and tensions are balanced?
Edited by Hubac's Historian
I would think that there would need to be some type of support other than the gammoning and the fore stay mostly due to the fact that if the fore stay broke the entire spritsail mast would collapse. I ran into this issue with La Couronne as well. I chose to simply keep it inline with the center line of the ship though, many models I looked at had it offset. What I have wondered since is could there have been a supporting ledge to the side of the stem to carry the offset mast? This seems like a logical option as it would give the mast a place to rest that would allow the stem to still support the weight of the mast but allow for the offset. The gammoning and fore stays would still do their job of holding the mast steady but in the event that the fore stays are broken, the mast would not collapse.
"It was a stormy sea that made a Captain out of me."
- Derina Harvey, "Captain" Derina Harvey Band
-E.J.
Current Builds - Vasa - Scratch
                               Royal Louis - Mamoli
                    Royal Caroline - Panart
Rob
Hello Rob,
thank you for the pictures and description, the term "foot" is not known to me, so I was confused what do you really ask. I know only the term  "stem" from literature a hull description in English. 😉Well  as I have already written above, I will follow the model of HMS Prince or Saint Michael -  their bowsprit is located beside the stem and its end is in the centerline. It is not possible to place bowsprit on the stem in this case, on some pictures of various ships from that period you can see sculptures on the top of stem.  Here are some pics of HMS Prince 1670:
medium_1895_0056__0015_.jpg.65751e0b5849df98c2c494aa248de65e.jpgmedium_1895_0056__0016_.jpg.9d71a7e11e2ec7b1bcbb5bcc379186f2.jpgmedium_1895_0056__0017_.jpg.9f65278d403ddb6ffb88a64d2d519e8d.jpgmedium_1895_0056__0008_.jpg.f9b3b5884a4aedecb9f2115f4f5f9d51.jpgmedium_1895_0056__0009_.jpg.63f49717916d4639de83331b825af02a.jpgmedium_1895_0056__0006_.jpg.b4f0dda8cd3fccae8b84c8c63b372126.jpg
Other ships with this similar design and position of bowsprit:
Sovereign of the seas:
Sheldon´s model:
Naseby:
N2.thumb.jpg.908b2c5dc044cc041d604b30524528dd.jpgn14.thumb.jpg.7756a49b1d81c496195ecadf70f2ce13.jpg
Best regards
Edited by DORIS
Doris
Current build:
Thank you Doris for the fine examples of the direction you are going.
I suspect my own lack of the exact time frame for the shift from offset bowsprits to the more traditional forward and on axis designs drove me to this line of questioning.
I'm looking at the counter action created by the gammon lashing, which do their work by pulling the bowsprite in toward the midline and down toward the stem.
Your picture examples show that lateral forces are applied to the starboard side of the Stem not on top of the stem(which I referred to as the *Foot*)....which in later designs became more prevalent.
If the bowsprit does not find support from contact with the *Foot* or Stem...then all the Gammon lashing energy is being countered by the fore stays.
Regardless....my questions have been answered, and your attention is most appreciated.
Love your work.
Rob
Current build:
Finished build:
Hello Rob,
No problem, I would like to explain anything, only my English is not very good and sometimes is a bit difficult to understand. Plenty of various modifications and structural elements I try to do accroding to museum models and paintings/drawings from that period. I am also very grateful for help and professional advice to the top expert and experienced naval captain from our country - Kpt.KL. I have already written about him in some of my previous posts. For example you can read through his professional research about Sovereign of the Seas (1637).
https://www.modelforum.cz/viewtopic.php?f=183&t=46754
Several years ago I built a model of this ship (also a scratch build out of card) according to his advice and research, and achieve one of the most realistic results. Here are some pics of my model:
11.thumb.jpg.d3bd773fd773fff2962ad98b010da4f4.jpg12.thumb.jpg.b2ea70b8f72b212b92adc9b4cf1d4a91.jpg14.thumb.jpg.e8cde4098e7a34a915b0a3c45c813145.jpg16.thumb.jpg.d51607b7d65d1fa099111ec756fdedec.jpg18.thumb.jpg.c33f796086dc84213de6f378d1774e0b.jpg22.thumb.jpg.d07701d1b80bad0d838d2c525d5c561e.jpg19.thumb.jpg.6829eae00e0f6980b93798848e10910f.jpg20.thumb.jpg.18db68f38107fdfcb76dd7447f2942c9.jpg
Edited by DORIS
Doris
Current build:
Hello dear friends,
I have just started with interior of a great cabin, at this moment it looks rather untidy but during next weeks it will be fully equipped and nice. Here are some actual pics, how the "change" begins.... The last gunports on main deck (before quarter galleries) will be closed and the space between them will serve for electrical wiring.
1.thumb.jpg.0db751ba81b4e0ee9bc31c227078644d.jpg2.thumb.jpg.02d68add94dd4112aa12f07b3282fc60.jpg3.thumb.jpg.1c9efe1e535d92cd68e0bd9376ad67ca.jpg4.thumb.jpg.50fb9eb8e0999212689e405bc80800bc.jpg5.thumb.jpg.d8bf5ab65e129a21c4209ea2422e639d.jpg6.thumb.jpg.4921c710471c742e3e3d75552c6481d1.jpg7.thumb.jpg.ce0205b7283f88d7e9264a36c28fb632.jpg8.thumb.jpg.9497fcb177483ab6b6c138790fd470dd.jpg9.thumb.jpg.b2aae06e1d48ebca0e7dc11ebcc972df.jpg10.thumb.jpg.0952cd5e03a62a2d8e10c96c1ae84124.jpg11.thumb.jpg.ca4783935d4bba663e61efee1fd310bb.jpg12.thumb.jpg.8026f58a9b25149c84a0f4052c404120.jpg13.thumb.jpg.aae635cc05575301838ad1b24500f1d3.jpg
Edited by DORIS
Doris
Current build:
Hi there!
It is almost unbelievable that your Sovereign is in a scale 1:96! The details on her are just stunning! 👏👏👏
As regards the wiring for the light in your Katherine: Who is making your schematics? Are you doing it yourself or do you have some help?
For my scratch build of "Neptune" from Roman Polanski's movie Pirates I plan to implement light as well. But all my components, i.e. resistors, potentiometers, capacitors, will be outside the ship, so in the ship itself there will be only the diodes in a parallel circuit connection. This will save a lot of space. A student at my workplace was friendly enough to help me with the schematics. I hope to post my progress soon on papermodelers "Spanish Galleon Neptune" 😊 and at some point I will start a progress report on her here, too.
Kind regards,
Radek
Edited by RdK
Hello Radek,
thank you very much for your praise, I am honoured. Sovereign of the Seas is my favourite ship and her model is the most precious for me. This was my first scratch build of sailing ship.
These schematics for Royal Katherine lighting I did by myself. It was quite easy. There will be five separate circuits - each with 3 or two pieces of LED.  Now it is connected only provisionally.
I am looking forward to your model and wish you a lot of success and enjoyment during the build.
Best regards,
Doris
Doris
Current build:
Wonderfully done.
Rob
Current build:
Finished build:
