Hi Nils. Interesting model and a good start. Some of the frames are quite thinly cut, what did you use to cut them?
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Hi Keith,
thanks for looking in and for your kind comment. The frames were all cut out manually with with a good old jig saw and fine thin blades...
Nils
Current builds
-Lightship Elbe 1
Completed
Nils, very neat jig saw work.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Thank you very much Keith and Carl,
Keith,
Thanks, I use the hand jig saw since I started building models and would`nt want to mis it...
Carl,
The agent of Algier Harbor Carpenter Services has just delivered a bunch of 1/2 dozen oars for the ships boat. He is still a bit pale and tired from working on them all week, but for sun protection he is wearing his new tricorn hat made from 0,3 mm brass sheet
Nils
Current builds
-Lightship Elbe 1
Completed
"his new tricorn hat made from 0,3 mm brass sheet "
looks more like a folded 20 euro cent piece ... he must have a heavy head ... ;)
Edited by cog
Carl
Nils, in the past I always used a hand held jig saw but I recently bought a scroll saw. I'm sort of hoping it makes cutting out frames easier.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Keith,
yes you`re right, agree,  the scroll saw makes life easier indeed, which would be worth the investment...;)
Nils
Current builds
-Lightship Elbe 1
Completed
update...
checking out the hights for stringers / rails, and stand hight for the crew beneath deck...
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you very much Kees,
on this model I`ll be doing things I dd`nt try before...., so for the planking I odered size 1,5 x 6 mm planks in "red cedar" wood, trust that will provide a nice warm mediteranian tone, hoping it will not be too brittle when shaping...
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Hi Nils.
Wow that a large model. Looking good with the frames in position.
Also good planning on the gunport.
Regards Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
Hi Antony,
by now non of the frames are glued to the keel yet. Its only stuck in place and positioned by the fixture. Will have to cut out all the notches for rails and stringers first (frame by frame) before glueing them down to the keel permanently, and make card templates for the decks, so these decks can be cut out of 0,8 mm thick ply. Those decks will then be planked with 3 mm wide pine strips, caulking, etc.... I`m wandering if it will be possible to slip the floor into the cargo hold in (in parts), without removing some of the deckbeams of the main deck. I did this on my Pegasus build, so it should work generally. Besides that the model will be 25% larger, this early framework is not dealed with in the original Amati plan. Thats why the preperation and planing will take a bit longer for the involved sequences...
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Patrick,
thanks for your words, the working on... is only a few hours per day, if no other things have priority...., so nice and steady modeling..
Nils
Current builds
-Lightship Elbe 1
Completed
Update...
today framework removed from positioning jig, started fastening some of the stringers, quite fragile construction in the moment no fractures so far...
Am thinking of leaving a part of the port side hull open for a look beneath the deck...., beneath the wales
Nils
The frames are straking very nice...
Current builds
-Lightship Elbe 1
Completed
looks awesome Nils!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you very much Denis,
for your appreciation...
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you very much Bob,
I`m quite pleased with the way the holding and positioning fixture worked out, and the meanwhile arrived red-cedar planks look great for color and grain.....
Im the moment I`m involved in repairing our wooden equipment shed in the garden. It needs new roof parts and all gutters and rain drainpipes. As always, the more old wood I remove for replacement, the more rotten surprizes become visable. But I think I have the right concept now. I`ve been at it 3 days now and guess it will take the weekend as well to get things managed and the repair done.
Nils
Current builds
-Lightship Elbe 1
Completed
Update...
put some more stringers on, mounted the fancy support brackets for the high poop-deck grating, and am shaping the card template halves for making the cargo hold floor. I think I need`nt remove the deck beams for doing so, the card templates and later the thin planked ply floor halves can easily be slipped in through the frames from above....
Nils
Current builds
-Lightship Elbe 1
Completed
thank you very much Patrick,
I also liked the shape and lines of these chebec hulls very much, and I find the enlarged Amati hull was a nice one to base and modify the design on...
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Nils.
WOW that so impressive and no breakages is outstanding. As some of them deck beams are so thin.
I do love the lines of this type of ship.
 Keep making my day by posting them wonderful pictures.
Regards Antony.
Completed Mayflower
Many thanks Antony,
the rather thin deckbeams will be supported (strength) from below with turned wooden pillars. This way I have the option to place 35 mm high figures standing upright, crates, barrels, etc., below the deck. Now I will have to deal with the positioning and anchoring of the two M4 stand spindles below the cargo hold floor, and cut the two half hold floor parts from 0,8 mm ply and plank them. The port side of the outer hull shall remain partially open, in order to give view into the ship...
Nils
Current builds
-Lightship Elbe 1
Completed
Nils,
Always enjoy tagging along watching the progression of your builds. You always seem to add side notes that tell a story with all your little visitors. As always excellent work.
John Allen
Current builds HMS Victory-Mamoli
On deck
USS Tecumseh, CSS Hunley scratch build, Double hull Polynesian canoe (Holakea) scratch build
Finished
Waka Taua Maori War Canoe, Armed Launch-Panart, Diligence English Revenue Cutter-Marine  Model Co.
Hi John,
I`m pleased you like the build so far, and thanks for your words, much appreciated...
NIls
Current builds
-Lightship Elbe 1
Completed
update...
cutting out the floor halves from 0,8 mm ply for the cargo hold bottom (still to be planked...), and attatching the brass M4 thread-plates under the floor for the stand`s two spindles..., also checking out the deck-supporting pillars midships...
Nils
card template halves... will do...
the threaded brass fastening plates are enbedded safely between supporting lugs...
dry fit of pillars, the floor halves can be slipped in through the frame deck-beams...
here one wooden floor half (with overlapping) braces in dry fit
Current builds
-Lightship Elbe 1
Completed
Nice progress Nils - I like the spindles.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Thanks very much Keith,
am pleased you like the spindle fastening points....
the stb. floor half is now permanently planked and mounted. The pine-planks are 3 x 100 mm long and 0,7 mm thick. The three square  outcuts take up the gratings to the bilge. The overstanding outside edges of the floor will be trimmed off when the hull gets faired for planking...
Nils
the three gratings, per side, for access to the bilge
the glue is applied from underneath, once the floor half is correctly positioned
Current builds
-Lightship Elbe 1
Completed
