On 26.11.2017 at 1:19 PM, KeithAug said:
Hi Nils
He looks like he ate too many pies, or is it a beer belly?
Keith,
next to the fresh-water barrel, this one is also one of the utmost important barrels on board....
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Hi Carl,
the surface coating is a Clou product, "Ballenmattierung" for silk appeal wooden surfaces, normaly it would be wiped on, but due to the brush coating I used, it comes out a bit more "shiny", no problem...
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Carl
Yep, thats right...
Nils
Current builds
-Lightship Elbe 1
Completed
Nils, cleaning all those small spaces between decks requires specialist skills. Can I suggest you buy one of these. https://www.google.co.uk/search?q=model+figures+cleaner&ie=UTF-8&oe=UTF-8&hl=en-gb&client=safari#imgrc=thgAXWf_HUfN_M:
Edited by KeithAug
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Not bad Keith,
that brought me a nice smile with those "specialists" out of the link
Nils
Current builds
-Lightship Elbe 1
Completed
it will likely flatten out as time goes on......I use semi gloss lacquer for that reason.  below deck is look'in busy........love the effect  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi Denis,
thanks for looking in and for your comment, am pleased you like it....
Nils
Current builds
-Lightship Elbe 1
Completed
Update :
on the deck outcut side i put the braces on that hold the 9 side gratings in place. The 7 port guns will be arranged between the gratings, with barrels tied up at the upper bulwark, and the carriages tightly rigged for non battle mode. The starboard guns will be pointing out through the gun-ports.
I am concidering if eventually I should show the sweeps in their oar-port positions, at least on one side....
Nils
Current builds
-Lightship Elbe 1
Completed
Update :  (status report)
made some additional supporting braces in the areas where the gunports will be cut into the bulwarks....
On the stb. side the template fror the gun plattform can be seen
Nils
the guns standing on rails, the barrels pointing upwards, where they will be strapped to the upper bulwarks
Current builds
-Lightship Elbe 1
Completed
Nils,
Just catching up - awesome as usual (;-)
Under the table:
Woody Joe Higakikaisen
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Hi Michael,
thanks for catching up, I`m glad you like it....
I`m moving on to the starboard gun platform ( also deck planking for the platform and the one step down middle deck )
Nils
Current builds
-Lightship Elbe 1
Completed
Good morning my friend,
Its a great idea you have there Nils ! The life inside the ship its a great and not ordinary project. It looks like you have catched the real atmosphere inside the hull!  Its a very atmospheric build. I enjoy always looking your profi work, but at this modell am very anxius to see the end result... I guess it would be something very extraordinary!
Wish lots of fan
Christos
Christos,
thank you very much for your appreciative words, As the Amati Chebec was too small (1:60) to suit my intentions of the model, I decided to make "something special" out of the basic plan without making things too complicated....
I must admit, that the plan is not going much into detail, but I`ve studied a lot of chebec models on the web, and will try to adopt quite a lot of details I liked during this search. Also there is my imagination and improvisation which provides me much fun...
In scale 1:48 the complete model will be 900 mm long between bow sprit and aft-sail boom. It certainly will require quite a large glass case when finished...
Nils
Current builds
-Lightship Elbe 1
Completed
update :
been stiffening out the inner bulwarks. Nearly all stb. braces put on....
Nils
Current builds
-Lightship Elbe 1
Completed
update :
did some structure fitting out to the stern platform....
Nils
Current builds
-Lightship Elbe 1
Completed
Nils m- was there a specific reason for the overhanging deck / gratings at the stern? By the way the grating looks very neat.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Thank you Keith,
I unfortunately do`nt know why the stern overhang worked out this way with the actual vessels, and why this is performed as a grating. I`m building it after the ships that are shown with this design. It is required any how for access to the sheets and handling of the aft latin sail. Its one of the typical chebec design features...
Nils
Current builds
-Lightship Elbe 1
Completed
Nils, its quite an attractive feature, its just a bit interesting that the original builders didn't just extend the hull length to give greater capacity and speed. I guess we may never know their thinking.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Keith,
Probably the lesson that the longer waterline gives more speed was not so known in 1753. Perhaps the aft grating was the place where the capt. took his late and undesturbed afternoon nap with the ships wake and the waters rippling down below, as she sails into sunset.... Maybe one of the fellow builders knows the real reason
of this overhang in this way...
Nils
Current builds
-Lightship Elbe 1
Completed
Update :
made a sequence I was a bit anxious for all the time, drilling the holes for the 14 gunports.....hoping that the hull planks would not fringe out...
Solution : I bought a 8 mm diam. hollow tube drill with diamond splitters around the cutting edge and used this with my electronic hand-drill at appr. 2000 rpm....
first I made a small jig to set the vertical centerline and to find the mid position between the bulwark supports. On the outside bulwark I fitted / clamped a bit of scrap ply, flush contact with the hull planks in that area. Sigh of relief , it went well, wonderfull sharpedged holes
On the battle side the guns have a few degrees over horizontal, with upward pionting barrel. On the non battle side there will be shield plugs inserted with lions head decore from the outside bulwark. Those guns will be retracted with barrels pointing upward and stropped, out of action, just below the upper bulwark rail.
Think that the smaller holes for sticking the sweeps through can also be made in this way for clean cuts....
Nils
just before cuttung the gunports into the bulwarks
the 8mm diamond splitter tipped hollow drill
the clamp holds the little jig on the inside as well as the ply counter-plate on the outside planks
battle side, the gunbarrel can be set to point ot horizontal and  sightly upwards
non battle side with closed gunports (here shown without the larger  decore rings). The plug shields are removeable
here gun retracted from action and barrel pionting upward
Current builds
-Lightship Elbe 1
Completed
Hello Nils,
Caught up with your build progress now that my computer is working again with a new hard drive.  Marvelous work, as usual.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Hi Piet,
I`m pleased to hear from you again, must have been a feeling like cut off from the family with a broken down computer, but now you`re all set again....
Thanks for your appreciative words, glad you liked the progress since your last look in.
Have a nice and relaxing Christmas time with your family...
Nils
Current builds
-Lightship Elbe 1
Completed
Nils,
What can I say the lines on this build are so smooth and clean they just flow one into another. I have watched this progress and am amazed at how simple you make a complicated build look easy. Kudos
John Allen
Current builds HMS Victory-Mamoli
On deck
USS Tecumseh, CSS Hunley scratch build, Double hull Polynesian canoe (Holakea) scratch build
Finished
Waka Taua Maori War Canoe, Armed Launch-Panart, Diligence English Revenue Cutter-Marine  Model Co.
Thank you very much John,
for your nice words, much appreciated.  Yes, it was because of the lines of a Chebec that I was adoring and just had to start building one......
Am now moving on to the next parts like deck supports / timbers for masts tackeling. The card template for the upper deck is in dry fit position...
Still need to fit the chimney tube for the stove exhaust over deck
Enjoy coming Christmas holiday and have a nice time..
Nils
Current builds
-Lightship Elbe 1
Completed
Just catching up Nils, she is looking very nice.
Michael
Hi Nils.
Like Michael above. Just catching up... wow amazing work on the stern and deck.
And I've gotta remember your excellent method of cuttng round holes in the hull or deck.
Have a nice christmass.
Regards Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
On 13/09/2017 at 3:26 PM, Mirabell61 said:
Hi Dan,
I think we`re in the same alley there, having interest also in ships of other nations and cultures.....
I have in mind also do tackle it doing a Chinese trade- junk around 1930 or so, when the Chebec is completed
Nils
Hi Nils.
Sorry it's Off topic .
Will you be doing a Junk ?.
Looking at doing one as my next scratch build.
Did you get any plans or are you going to use the Amati plans or the Artesania Latina red dragon plans.
Regards Antony.
Completed Mayflower
