HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 69 donations so far out of 49,000 members - Can we at least get 100? C'mon guys!) ×
On 6/21/2022 at 8:11 PM, Baker said:
As always.
Very nicely done Ondras 👍
Thank you very much Patrick!!:piratebo5:
I lined the back deck with lapped boards..
Deck with gratings ground..
Deck sanded..
View below the rear deck..
Ondras.
Done : President - https://www.modelforum.cz/viewtopic.php?f=177&t=90230
Under construction : Roter Lowe - https://www.modelforum.cz/viewtopic.php?f=177&t=114576
Member of the organizing clubhttps://wchs-c-2023.klom-admiral.cz/en
Thank you very much for the like!:imNotWorthy:
I provided the rear deck with all the pins..
Added Kevel blocks to the rear deck..
And the final spray, the inner railing..
Cleaned the holes in the gretings and waxed the rear deck..
Ondras.
On 7/22/2022 at 3:05 PM, rshousha said:
The work is done to perfection. One would want to spend hours just looking at the precision of the work.
Thank you so much Rick, I appreciate your words!:imNotWorthy:
The last part to be painted, the inside railing of the foredeck..
The wall of the back castle..
Added rear side bar for Belaying pins..
I cover the last plywood part, the roof of the rear castle..
Ondras.
Completed poop deck..
Created a bench above the mirror..
Also the flagpole and the inner railing..
Ondras.
Flagpole turned, flagpole halter placed on ship. I reached maximum torso height..:champagne-popping-smiley-emotic
I roughly created decorative ornaments for the top of the stern..
And then came the inner railing. Columns of the lower part..
Secured with three pins for strength..
Ondras.
Decorative S attached to the stern..
Work on the inner railing, the supporting centers of the posts made of steel pins..
Waxed..
Capstan already placed under the deck, using a previously created jig..
Railing done..
Ondras.
Made stairs..
Ramshead pulleys made for Halyard Knightheat posts..
Next work aft deck wall..
And a supply of Small staghorn harnesses..
Ondras.
On 9/9/2022 at 9:22 PM, FriedClams said:
Beautiful work Ondras!
Gary
Thank you very much Gary!:imNotWorthy:
I created the wheelhouse..
I started making ropes from thin Sajou threads. On the old ropewalk with a low-quality ride, the rope made mistakes for me. So I modified the entire ropewalk..
And now it's about something else!!
The hoists of the main mast have been completed with new ropes, they will now go below deck..
Now I can close the wall of the rear superstructure..
Ondras.
Hi Ondras -
Beautiful work.  The new ropes came out especially well, with a nice tight and regular lay to the lines.
One small point of wording - the curved deck fitting is not a wheelhouse.  The Roter Lowe would have had a whipstaff, not a wheel.  The fitting is actually a cover for the man who operated the whipstaff, sometimes called the helmsman.  The opening in front is so that he can see the set of the mainsail and hear commands from the navigator and captain.  To bring his head up above the height of the deck he just stood on a box.  Sometimes the simple solutions are the best.  Here is a drawing of the whipstaff from E. Keble Chatterton's book -
On 9/17/2022 at 5:42 PM, shipmodel said:
Hi Ondras -
Thank you shipmodel. Bad translation. This is just below deck. O.
Ondras.
Ondras -
Yes.  That is just what there should be.
It is good to see that the whipstaff is properly modeled, when it is not often seen.
Thanks for showing your work to us.
Dan
Back deck wall done..
After waxing, placed on the gun deck, secured with pegs in two wheels..
Restraint ropes created..
..and guns placed on deck..
Add hoists and place cannons below deck..👌
Ondras.
Thanks for the likes..:imNotWorthy:
The model is placed on a baroque stand...
Cannon goals set up. Created an imitation of cable entanglement..
The first cannon goals in place..
And arranged more..
Ondras.
Finally placed the main guns below deck. Blackening is alchemy, take your time, 1:25 an ideal solution that does not stain..😵
Tangled end of rudder belay rope..
Mounted guns on deck..
Current status..
Edited by Ondras71
Ondras.
I started making "belaying pins"..
I provided the model with mast stumps and some belaying pins to participate in the competition..
..but this affected me....
So I'm sitting at home...😭
Edited by Ondras71
Ondras.
I hope you have quick and good recovery so you can do what you love.
Hi guys and thank you.:imNotWorthy:
In the end, the boat went to the Czech Championship, it returned unharmed. In the ship components category "C3D", the points went to the gold medal.😲 Satisfaction. But I miss the atmosphere of the competition and meeting with similarly strange people..😭
Ondras.
Thank you all very much for the wishes and likes friends..:imNotWorthy:
Continuation with the production of "belaying pins". The form has been modified a little, the pins are now smaller..
Comparison with the old one, a total of 58 pcs..
Pins on the bow. I have to darken them to make them stand out..
Ondras.
I still work with breaks. Other Small Staghorn harnesses..
More work on the largest triangular Deadeyes. Homemade production is literally done by hand..
I found new options for the MF 70 cutter..👌
side groove..
rounding of edges..
Test with 0.52 mm cable..:36:
Edited by Ondras71
Ondras.
Finally forging deadeyes..
I used different lengths of fittings from the factory. I evened out the slope in the channels..
Belaying pins darkened and waxed..
Ondras.
On 11/19/2022 at 1:27 PM, Baker said:
The same comment as always 😉.
Great work Ondras 👍
Thank you very much Patrick!🙂
Again in big soldering..😵 I make "chains deadeyes" clamps. Brass 0.5 mm..
Drilled holes in the direction of the shrouds..
First placed eyes for "Masthead tackle"..
Ondras.
I gradually make deadeyes clamps called "chains deadeyes". Unfortunately, each piece is a different length..:default_wallbash:
The first foremast...
Placed guport lids are a big risk, I have already repaired..😭
Ondras.
