14 hours ago, Ondras71 said:
finally impaled and then drilled holes on the last pins ..
Congratulations, It is always a relief when all those holes are drilled and filled :champagne-popping-smiley-emotic
Beautiful work Ondras
Thank you very much Hubacs Historian a Backer..!!:rolleyes:B)
Last pins installed and ground ..
I really like the graceful shapes of the high torso galleons with lots of wales..:wub:
To compare the sides of the Vasa ..B) O.
Ondras.
Done : President - https://www.modelforum.cz/viewtopic.php?f=177&t=90230
Under construction : Roter Lowe - https://www.modelforum.cz/viewtopic.php?f=177&t=114576
Member of the organizing clubhttps://wchs-c-2023.klom-admiral.cz/en
Thank you for like ..:stunned:
I'm continuing to prepare holes for klinkbout on wales. I painted and pinned the studs clamped on each rib..🔨
Ondras.
Working on klinkbout. Here Dutch type, reconstruction Zeven Provincien ..
Modified nails 0,7 mm ..
wales test..
Ondras.
Drilled holes for the klinkbout..
The model rotated on its stand..
Broken off the rest of the construction ribs and modified the railings' shape..
Ondras.
Aligned height of the main deck ribs..
Finished base of the stern with the upmost deck..
Ondras.
Late to this party.
Just read your whole log.
Ondras you are an exceptional modeller.
Beautiful planking.
It has only just dawned on me why they cut a rabbett in the keel especially the bull nosed bow on galleons....to hook the plank into whilst bending it round!!! Why of course.
It was your pictures that made this clear to me.
Also that no plank should go to a point...because you cannot nail a point to the frames!...
Duh!!
I am only learning as I watch you guys teach me.
Thanks a lot.
Pete
Thank you Peter Cane, I am still learning as well ..:Whew:
I continue lining colored strips, Using discarded planks with poor grain of wood..
Still loose Wales ..
Putty..
Ondras.
Ondras..when I saw the beginning stages of this ship when you laid out the rough and ready bulkheads from corrugated card I thought " oh dear what are we in for here?"....
But mate!.....you have knocked me for six with the eye to detail, craftsmanship and now present this beautifully made miniature replica.
You are a master at this. A joy for me to witness your hands at work.
Pete
Pete
Thank you again Peter Cane.  Your words are encouraging!! :piratebo5:
For smoothing clean shapes I created shaped tools and used a belt sander..
Varnish for wooden pores..🎨 O.
Ondras.
Ondra, you are a gifted modeler.
The maker of the plans must have had a great imagination, but wether his design is truthful or not, you are doing a magnificent job. And you have one mighty excuse: The shape of the model may be wrong, but up to now we don’t have any written or archaelogical clue how it really must have looked, so who are we to reject?
No problem so far with your build. But just promise me to throw that horrible German book in the dustbin after you finished your model. It is no good as far as Dutch ships are concerned and there are four of them there, I believe. For all four we can say that any resemblance with existing Dutch shiptypes is entirely incidental.
Good luck.
Edited by Ab Hoving
Thank you for the compliment Ab Hoving!:imNotWorthy: We got into a fight, we have to fight..:default_wallbash:
Continuation.  Main deck base..
The sides of the hull inside..
Ondras.
Continuation..
Adjusted cannons according to historical background..
754921125_Mauritius1609.thumb.jpg.9589e59741499c6e5b4c969e78aa5dc3.jpgIn combination with the Dutch Lafette ..
Ondras.
Thank you for the likes..:imNotWorthy: O.
Hull on the stand reinforced ..
Installation of the internal boards continues..
Railing edges aligned..
Ondras.
On 10/17/2019 at 10:15 PM, rshousha said:
Do you think 500 years from now our current ship designs will look so awkward?
Hopefully, our current ship designs will remain accurate and there will be no room for debate.. :Whew:
On 10/18/2019 at 2:48 PM, Backer said:
Great work Ondras.
Thank you for your support Backer!!:imNotWorthy: Ondras
Ondras.
On 11/9/2019 at 5:25 PM, zappto said:
Amazing work you are doing! very nice ship!
Thank you very much zappto!!:imNotWorthy:
Construction of carriages, rather pedestals that will not be seen..:unsure: Shape and dimensions taken from the Dutch carriages Zeven provincien..
Test..
1214794089_zkoukalafet(2).JPG.59e642c7aa6be7c17f7bfac886187b79.JPG1530700426_lafetyvpodpalub(1).JPG.5c9f37905393078ff0d0b2dc81e263ed.JPG
My pattern, the deck of Batavia..:) O.
Ondras.
Excellent work. Thanks for the many helpful tips and inspiration
current build- Swan ,scratch
on shelf,Rattlesnake, Alert semi scratch,Le Coureur,, Fubbs scratch
completed: nostrum mare,victory(Corel), san felipe, sovereign of the seas, sicilian  cargo boat ,royal yacht caroline, armed pinnace, charles morgan whaler, galilee boat, wappen von hamburg, la reale (Dusek), amerigo vespucci, oneida (semi scratch) diane, great harry-elizabethan galleon (semi scratch), agammemnon, hanna (scratch).19th cent. shipyard diorama (Constructo), picket boat, victory bow section
Thank you very much stuglo!!:)
I was stopped by the warranty repair of the lathe proxxon, a little woodwork. Gun Port covers ..
Side test..
Ondras.
Love the insight of your modeling techniques!
Really nice craftsmanship.
Steve
"If they suspect me of intelligence, I am sure it will soon blow over, ha, ha, ha!"
-- Jack Aubrey
Builds:
Yankee Hero, Fannie Gorham, We’re Here, Dapper Tom (x3), New Bedford Whaler, US Brig Lawrence (Niagara), Wyoming (half hull), Fra Berlanga (half hull), Gokstad Viking Ship, Kate Cory, Charles Morgan, Gjoa
Thank you very much Srodbro!!:imNotWorthy: O.
Founded bases cannon main ..
Ondras.
