Thank you very much mtaylor, thanks everyone for like..:imNotWorthy:
On 4/4/2020 at 10:15 AM, Ondras71 said:
Thank you Tigersteve.:) I used a 1.1 mm Proxxon blade, but it is thick. Waiting for 1 mm. So far it has been a system test.⚒️ O.
Continuation of work on gretings with 1 mm thick saw blade ..💣💥
Ondras.
Done : President - https://www.modelforum.cz/viewtopic.php?f=177&t=90230
Under construction : Roter Lowe - https://www.modelforum.cz/viewtopic.php?f=177&t=114576
Member of the organizing clubhttps://wchs-c-2023.klom-admiral.cz/en
Looks like this blade worked for you as well. Was this another Proxxon blade? I am going to have to make gratings at some point soon. I do have the 1.1mm blade from Proxxon as well, but I have to make a jig for creating the gratings first.
Steve
Steve
I did not find a 1 mm saw blade at Proxxon. I got a saw blade from a friend, probably in the former DDR .. Its center is 16 mm, filled with ring 10/16.
The preparation is made of waste, the work took a very short time. Ondras
5 hours ago, Backer said:
As always,
Great work Ondras
Thank you, Patrick:rolleyes:
Ondras.
I created frames gratings for the main deck..
I'm starting to lay the deck. There are thicker "binding strake" boards around the gratings. I want to make these from wood contrasting with the deck.
I took the liberty of addressing Ab Hoving with the question: May I use the layout of strake boards on the main deck according to his reconstruction of the "WITSEN" pinase? The boards in question are the ones on the sides of the gratings and also the boards closer to the center of the deck around the masts and equipment?
509820251_studiumprkenbindingstrake(4).thumb.JPG.54df7843dbb057cbb72156f92cebbaa4.JPG
Laying the planks of the main deck I will do according to the replica Duyfken ..
Ondras.
I create "binding strake" boards from linden wood, the deck will be made of maple..
The boards are pinned and provided with paper before laying..
Binding strake laid ..
Other boards will be narrowed..
Ondras.
I slowly continue to lay the planks of the deck. So far, whole boards without hooking .. O.
Beautiful photos from the Duyfken deck exchange..💣
Edited by Ondras71
repair
Ondras.
Other boards with hooks..
Center of deck ..
The last boards at the waterway ..
463468686_napchankolkystedupaluby(3).JPG.dd3e5383eafaf496e58cf70dd35fe42e.JPG1276223021_napchankolkystedupaluby(2).JPG.8fc4ccff3ca20a421b97ff1c2bcc5977.JPG1483740427_napchankolkystedupaluby(1).thumb.JPG.99660ce546b5ef1a474d88731b83bbda.JPG
Ondras.
Hi Ondras,
Outstanding job on the deck. I understand you used maple strips. Do they allow a clean cut when you need to narrow them?
As I'm looking for alternatives for boxwood but nonetheless good quality.
Kind regards
Christian
"The original always beats the copy"
(supportive statement)
On 6/1/2020 at 3:27 PM, Barbossa said:
Hi Ondras,
Hello Barbossa. Maple wood has an ideal hardness, it is well cut and sanded, it holds the edge.💣
Ondras.
On 6/3/2020 at 7:50 AM, Barbossa said:
Hello Ondras,
Received loud and clear 🙂
So let's order some maple strips this evening.
Thank you Barbossa. Maple strips were overhead ..:default_wallbash:
I finished the deck planks. I'm just sorry half will be hidden, including hooking..:unsure:
Next will be grinding ..
Main deck..
Ondras.
Deck ground 240 grit..
An edge cutter made of waste..
Deck ready for wax ..
Ondras.
Fantastic work! Looks perfect, this build is great.
     Current:         Emma C. Berry Lobster Smack-Model Shipways-1:32-1866
        Back on the shelf:    USS Essex- MS- "Old Yellow Box" Solid Hull  Wall Hanger (Half Hull)
   Completed:    18th Century Armed Longboat-MS 1/24
                          USN Picket Boat-MS 1864 1/24
                          US Brig Syren by Sea Hoss- Model Shipways-1803
                          18th Century Carronade/Ship Section
                          Mayflower-Pilgrims Pride by Sea Hoss-Model Shipways-1620
                          18th Century Long Boat by Sea Hoss-Model Shipways
                          USS Constitution by Sea Hoss-Revel-Plastic
Thank you very much archjofo and Sea Hoss..:)
Front body wall ..
Medical needle 0.7 mm made pins 0.5 mm ..
Stairs worked glued temporarily with glue..
Ondras.
Thank you very much for like ..:imNotWorthy:
Door and window fittings ..
waxed ..
Ondras.
The whole hull waxed outside..
I'm making new gratings for the front deck. I tried a new style of production with a 1 mm cutter on one side, it works and it's more accurate than a saw..:36:
Comparison with old gratings..
Ondras.
Thank you very much Chuck, Patrick and Tom!!:imNotWorthy:
Continuation of gratings. Absolutely accurate system..
Preparation of deck beams for forecastle..
Ondras.
Ondras, absolutely stunning.
Current build: Model Shipways “Confederacy “
Completed builds:
Mamoli “Royal Louis“
Mantua “Royal Caroline”
Scratch 1/4 scale gondola “Philadelphia”
Scratch “Hannah” from Hahn plans.
Thank you very much Steven and Bossman!! I appreciate the favor of you all.:imNotWorthy:
Front gratings and front mast holder..
Deck boards will follow ..:stunned:
Ondras.
Thank you for supporting Mustafa.:) Thanks for the like!!:imNotWorthy:
Front deck pins..
Preparation of the aft deck..
Ondras.
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
