Hi folks
Hot on the heels of finishing my last model, Shadow, I’ve excitedly started on what I think is my biggest challenge yet - Genesis, a 49m Luxury Mega Yacht, based on an actual ship named Khalilah, built by an American builder, Palmer and Johnson.  The details of the ship, Khalilah, can be found here:  https://www.yachtcharterfleet.com/luxury-charter-yacht-46797/khalilah-photos.htm#yacht-tabs
As I don’t have any detailed plans, a lot of what I’m attempting is by sheer guess work, with a lot of help from a fellow MSW member (whose help and guidance I shall always appreciate).
Like all of my other models, Genesis will have a fully detailed interior, from her engine room through to her sky deck.
I hope you can follow me on my journey from here on.
The following photos show where I’m up to so far with the hull.  Lots and lots of work to go, folks!!!
Thanks.
Patrick
Hi Patrick,
thats a very ambitious super yacht (Khalilha) you have chosen. With all those curved surfaces I think I would never find through, let alone fitting out the interior, but you had a good test run with your fab. "Shadow"
Wish you a steady hand and good luck with the build...:rolleyes:
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
2 minutes ago, Mirabell61 said:
Hi Patrick,
Nils
Thanks Nils!
Yes, you’re right about Genisis’ complex curves.  She is definitely not a hull for the faint hearted, that’s for sure!
Have a great week.
Cheers.
Patrick
Hi everyone!
Okay...Seriously!!!!  Is this a Star Wars’ spaceship, or is it a mega yacht’s hull???  She sure looks weird at this stage, but trust me, Genisis will look really spiffy once it’s done....
Here’s the progress so far.
Cheers.
Patrick
Edited by Omega1234
Patrick,
I got dizzy following Shadow, this one is really going to test by depth perception. Kudos to be able to work at such a small scale with such precision. Question what wood are you using for the hull?
Will follow until the launch.
John Allen
Current builds HMS Victory-Mamoli
On deck
USS Tecumseh, CSS Hunley scratch build, Double hull Polynesian canoe (Holakea) scratch build
Finished
Waka Taua Maori War Canoe, Armed Launch-Panart, Diligence English Revenue Cutter-Marine  Model Co.
36 minutes ago, John Allen said:
Patrick,
Thanks John
I got dizzy myself!  Shadow was a certainly complex beast, but Genesis is a real doozie!
I’m using Balsa wood for the hull, but don’t worry, I’m going to cover the balsa with something like plasticard, to stiffen it up.  The other thing is that 99% of the balsa wood will be carved away leaving an empty shell, (thereby allowing the interior to be built).
Well, that’s the plan, anyway!
Thanks for coming onboard.
Cheers.
Patrick
Edited by Omega1234
Count me in, Patrick.  I love your subject choices and then the execution. Genesis looks to be a huge challenge and I daresay that you'll be up to it.
Hi Mark
Welcome onboard and thanks for the well-wishes!
Cheers.
Patrick
Hi Patrick!
Excited to see the ‘genesis’ of this project!(...sorry, I can show myself out...)
In all seriousness, it looks like you’re off to a great start. I like the approach of tackling the side hulls as their own assembly. That said, how are you ensuring they stay securely joined as you carve away to fair them into the main hull? I suppose a strong glue might be enough given how soft balsa is.
Also, the main hull looks great - I think you’ve nailed the bulb and the entry/flare of the forward sections. Plus you’ve got that combination of smooth and angular that makes this hull stand out. Looking forward to seeing the progress!
~ Ben
___________________________________________________________________________________________________
Current Builds:
'Doll-Boat' - 1:12 scale 40' Cruising Sailboat
S.S. Edmund Fitzgerald - 1:350 plastic kit w/ Photo Etch Parts (On Hold)
An interesting build Omega.  As this is so far out of my modelling domain it will be a very informative build to follow.
cheers
Pat
Super ... Patrick, I see you are a man whom likes his curves ;) :)
I'm ready anxious and waiting on al those magnificent steps in this build. You always seem to pull a rabbit out of a hat at some point ... curious what you'll come up with this time ... when I look at it's size compared to shadow, you'll have your hands full with the size of your interior decorating ... I would like to see a golden tap in the bathroom if you have the time ;)
Carl
Patrick, they don’t make them like they used to. Can’t wait to see what you imagine to be inside. Perhaps warp engines with dilithium fuel bunkers.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
8 hours ago, BenF89 said:
Hi Patrick!
Hi Ben.  Woohoo!  Thanks for the vote of confidence and letting me know that I’m on the right track.  I’m not sure about the side hulls as yet, because so much of this build will be a ‘suck it and see it’ approach..... I guess I’ll just work it out along the way.  Nothing like a totally organic approach to boat building, hey?😏
cheers
Pat
Thanks Pat - Great to have you onboard!
8 hours ago, dvm27 said:
Great start, Omega. Curious web site for this yacht. Only exterior photos. Usually, there are numerous photos of the staterooms and cabins with yachts such as these.
Thanks dvm27. As Mark said below, there’s a surprisingly large amount of photos on the Net.  In fact, everything except the actual hull plans...sadly😩
6 hours ago, mtaylor said:
Thanks Mark!  Greatly appreciated 😀
Hi Carl.  Many thanks.  Like you, I’m also keen to see how well I can pull this one off.  Challenging and fun; that’s for sure.  Also, that’s an interesting comment about Shadow, because Genesis is actually slightly shorter in length than Shadow.  Good things come in small packages, hey?
Hi Keith - you’re absolutely right!  My first love will always be yachts and sailing ships (as witnessed by my previous sailing models such as Ingomar, Dorade, the J Class Rainbow, etc, etc), but, these modern mega yachts are just mesmerising and captivating in my opinion.  They are a true testament to what ‘imagination, money, dreaming and pushing the boundaries’ can achieve.  I guess, I’m hooked!!!
Thanks also to everyone who hit the Like button😀😀😀
Cheers.
Patrick
Edited by Omega1234
Well that will make the tap a lot easier to construct :) :D
Carl
Just crazy...:huh::D
-Elijah
Current build(s):
Completed build(s):
Model Shipways Phantom
Member of:
The Nautical Research Guild
huff'in and puff'in to catch up!    what an ambitious project you have going on here.........I look at the shape of the hull and right away,  I think James Bond! :)  I'll just take any seat.......no matter where you sit...it's ringside  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hey Denis
Thanks and welcome to the party.  I have a feeling that this party may be a rollercoaster of ups and downs, and twists and curves.  Who said boat building wasn't meant to be fun?
Also, I reckon you've hit the nail on the head with your James Bond comment!  Even 007 would be proud to own this baby.
Have a great week.
Cheers
Patrick
it will be.........until you see the direction it wants to go in  ;)   I think your going to like where that hull takes you .
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi folks
Oh my lord!!!!  I’ve done it!  Well, at least the general shape of Genesis’ hull has been done (and that was by and large the biggest headache for me, what with her crazy mixture of complex curves and hard chines...).
Now, I’m going to concentrate on fine tuning, puttying and sanding the hull, to bring out the true beauty of this unique design.
C9D29196-51DE-48AF-A7BC-F89B1D801FB9.thumb.jpeg.4b78496f62334461e4ef64691c7b4cda.jpeg9E9C80DB-2B09-4D0F-8373-CB420AE90980.thumb.jpeg.59035a824dca7e16ad223afc4128d964.jpeg5CE6ADD2-E705-4EA9-BB94-90AFAAC4FD77.thumb.jpeg.0f198041af06d655a83060259b7c072d.jpeg7BC11592-F3ED-4919-BC06-2E0304ADA5B0.thumb.jpeg.83bbb0d70319f5754c4aff37cfe7073e.jpegLots of work still to go, but I hope you’ll still come along for the ride.
Thanks to all for your comments and Likes.  Much appreciated.
Cheers.
Patrick
37 minutes ago, IgorSky said:
WOW! You started new project!!! My congratulations. Patrick!
Hi Igor
Thanks!  I was itching to get “Shadow” finished so that I could start this boat.  Now that I’ve started, it’s been full steam ahead this week.
Have a great weekend.
Cheers.
Patrick
Edited by Omega1234
