Coming along nicely for sure.  Love the attention to detail in the hull construction.
Love clippers..nice to see yours progressing so well.
I'll be following.
Rob
Current build:
Finished build:
Current build(On hold):
So here's how the deadeyes and chainplates come together. First you need to bend the chainplate:
Then you have to put some .010 wire in the upper u-bend, crimp it in, and then wrap the wire around the deadeye, and CA glue the wire :
And finally you can nail it in place with a couple of pins.
Edited by MrBlueJacket
spelling
The Red Jacket instructions call for cutting the stern caprail out of bass sheet, and fitting it into place. I've always had trouble doing that, because it is difficult to get an even width. Mine always look a little "off."  Taking a hint from the bow caprail on the Charles Notman, I decided to laminate it. The rail is 1/8" x 1/16" so I used 4 pieces of 1/32" x 1/16." A simple 5-minute soak in water made them pliable and I taped them around the stern overnight. The next night it was very easy to lay them down. The finished product looks nice and even.IMG_2798.thumb.jpg.4c609c3b87187a35bef585a957eec061.jpg
You are coming along very well.
Current Builds:  Revell 1:96 Thermopylae Restoration
                           Revell 1:96 Constitution COMPLETED
                           Aeropiccola HMS Endeavor IN ORDINARY
Planned Builds: Scientific Sea Witch
                            Marine Models USF Essex
So the masking didn't work out the way I wanted. I forgot to run a seal coat of clear after I masked it off, and the paint bled. You can look at October 2018 newsletter (www.bluejacketinc.com - newsletter archive) to see the technique. So on Sunday I re-sprayed the waterline where it bled. (*sigh*)
I wonder about the use of a ponce wheel on the decking as a detail. It seems as many times as not the marks made don’t line up with the deck planks at all. To my opinion ( which is just that, mine probably alone) takes away from the model, more than if it was not done at all. All I notice is that it doesn’t match up. If it wasn’t there, I wouldn’t even think about it.
Kurt
Fantastic job for sure..well done.
Very clean
Rob
Current build:
Finished build:
It's time to do the figurehead and stern carving. They are of Sagoyewatha, the Seneca chief of the Wolf clan. His nickname Red Jacket is because of the red coat a British army officer gave him during the American Revolution.
One of the problems in painting is to mix the flesh color of an American Indian. A google search yielded plenty of advice from miniature figure painters, but they involved colors in acrylic and/or oil that I never head of. What I finally settled on is a mix of Burnt Sienna and cream. I think it came out OK.
