21 minutes ago, DORIS said:
Beautiful carvings, your work is very inspirational and neat. Thank you for sharing wit us.
Best regards,
Doris
Thank you very much Doris.
for Your attention to my work, it so pleasant to hear such kind words form The Professional of Your level.
My best regards.
I really like those extra details you added with your carvings. Very sharp too
Edited by cog
Carl
Yes, this absence of straight lines for reference would be a real challenge for a cartesian mind and hand like mine ... quite strange actually in a country that was dominated by rational thinking and calvinist religion.
Edited by wefalck
But a square hull would never do :)
Although: most working ships tend to be rather box-like: the main frame of a tjalk, fluit or aak, all tend to be rather square.
and it is a mis-conception that dutch calvinists did not like beautifull (and expensive) stuff. Quite a lot of expensive houses around.....
jan
beautifully done Kortes.
Michael
    A fairly recent Clint Eastwood movie called: Trouble With the Curve, is something that you apparently have no such problem with!
Dave
“You’ve just got to know your limitations”  Dirty Harry
Current Builds:  Modified MS 1/8” scale Phantom, and modified plastic/wood hybrid of Aurora 1:87 scale whaling bark Wanderer.
Past Builds: (Done & sold) 1/8” scale A.J. Fisher 2 mast schooner Challenge, 1/6” scale scratch built whaler Wanderer w/ plans & fittings from A.J. Fisher, and numerous plastic kits including 1/8” scale Revell U.S.S. Constitution (twice), Cutty Sark, and Mayflower.
                  (Done & in dry dock) Modified 1/8” scale Revell U.S.S. Constitution w/ wooden deck and masting [too close encounter w/conc. floor in move]
Hope to get to builds: MS 3/16” scale Pride of Baltimore II,  MS 1/2” scale pinky schooner Glad Tidings,  a scratch build 3/16” scale  Phantom, and a scratch build 3/16" scale Denis Sullivan.
Very difficult part executed perfectly. Really excellent work.
The impression I get is among this community of builders, wood bending is the standard by which skill is measured, so he who can do more bends and more difficult bends than the other guy, wins. So we have parts like the cabin roof bent into multiple smooth curves for no functional reason, and a hull shape that is closing in on being a circle :)
it seems for some most of life is defined as a contest, others just like pleasing lines ... a certain flow. I particularly like the cabin's roof as it breaks the rigid lines of the caulked planks
Carl
