I finished and installed the foremast pin-rails.  The bow platform test fitted successfully.  I measured off and cut out the bowsprit pin-rail.  I also made the cap for the bowsprit.  I’m going to make the dolphin striker, jib boom and flying jib here shortly.
The original masting dimensions are on Plate 3 across from page 236 of The Search For Speed Under Sail.  I’m using those for my dimensions.
Building:
I just installed the bow platform, the bow pin-rail and the chain-plates.  I also put a strip of card over the channels to hold them in place.  This means that the hull is done, except for some minor touch ups and a little bit of paint work.
I’m pretty excited because I’ve never scratch built a model ship before.  Making the hull is the difficult part for me.  I’ve never really had any difficulty once I got to  the point of fitting out the hull.  Although, it’s a different ballgame when you have to make your own fittings.
This has been a lot of fun.
Building:
Hi Phil,
I never saw this thread until your question about mast tops came in yesterday.
Congratulations with your build. I'm proud to read that I have inspired you to give paper as the main material a try.
You did not make it easy for yourself, choosing a sharp ship with very stretched lines. As you can see on several places the hull looks a bit wobbly. Next time you build a ship like this I advise you to use some extra materials to avoid dents and bulbs. In this case you might consider to use some thin (2 x 2 mm) pieces of wood to support the outline of the deck over its length. Or you might consider to use plastic card to paste your deck-planks on. These materials might help to get sharper hull lines and flatter decks. Don't feel a prisoner of the material you chose. Not everything in a paper model needs to be made out of paper.
I want to compliment you on your detailing. A stunning result for a first try.
I'm sure your next paper model will benefit a lot from what you have learned in this build. You are an example of a model builder who is open for new challenges, prepared to take risks and keeps improving his skills.
Good luck with this build.
Ab
Thank you, much appreciated!
Next time I do this, among my lessons learned is that I’m going to use 1/16th inch basswood for my underdecking to prevent the waves that are in the deck.  I’m also going to reinforce the bulkheads better to prevent the warping that occurred.  I discovered that the entire hull has a slight twist in it, after I had painted it.  I started putting large books on drying pieces after that.
I made a mistake in my tracing of the bulkheads related to the spacing of the midships frames, in part because of the spine of the book, that I did not discover until after I had covered the hull, which caused the bulges around midships.
I’m also going to try and not rescale images, from multiple sources, with multiple scales unless I am drawing up my own complete set of plans, which I did not do for this build.  That caused me some problems as well.
I’ve learned a lot on this build.  It’s been a learning curve, but it’s been a lot of fun.
Edited by GrandpaPhil
Building:
The hull is done.  The base is done.  I made the parts for the foremast.  I made the main mast, itself, I still have to make the main top mast.  I made the parts for the bowsprit, including jib boom, flying jib and spritsail yard.
 I am waiting on the mast tops and caps to dry so I can laminate them onto another piece of cardstock, then I will assemble the masts, paint them and install them.
 I measured it out, the model will be about 36” long by about 24” tall and 16” wide, with studding sails run out.
Building:
I got some work done on the Prince de Neufchatel today.  😃
I made some more cleats for the masts and the main boom.  I installed the ones for the masts (I haven’t made the main boom yet).
 I also permanently installed and rigged the bowsprit.
Building:
An interesting subject Phil - and so full of character.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Hi Phil
I’ve finally caught up with your ship.  Man, you’ve done a lot of work since I last looked in.
I’ve said it before, but I’ll say it again...I love the way you just get in there and do it.  The result is lots of detail, lots of intricate parts being fashioned and most of all, 18 really impressive carronades/cannons.  Now, there’s just the masting and rigging....
Well done!
Cheers.
Patrick
Thanks for all the comments and the likes!
I’ve been having a lot of fun with this build!  It’s been a learning curve, but I’ve been building up my skill set and I’ve gotten a lot better than I was when I started!
I’ll be ready to get back to the Victory when I finish, and finish it.
Building:
16 hours ago, CPDDET said:
Your progress on these ships just amazes me. Don't know where you find the time. But your progress inspires me to spend more time on mine.
Thank you!  I make time at least one day per weekend (more if we have nothing else going on) to spend a significant amount of time on the model.
I’m looking forward to seeing progress on your Bluenose.  It’s coming along nicely.
Building:
The lower foremast ratlines on the starboard side are on.
I know that people usually hate ratlines.  It’s always just been part of the process for me.  I just sit down and tie them on.  I use Elmer’s glue to secure the knots.
The hardest part of the rigging, for me, is making all of the deadeyes on the shrouds and backstays line up right.
If you look at my first ship models, the Sultana and a Mamoli Endeavour, my deadeyes are all over the place.  I’ve finally been getting the spacing issues figured out.
I am using a piece of steel wire to set the distance between the deadeyes.
Building:
